rckanta
Unable to login
Sat Jun 20, 2020 6:17 am
I can not log in raspberry pi using user pi and user root.
Even if typing the right password.
I filled tired.
ssh, vnc server, apache, MySQL server and PHP they all working,
orico100
Re: Unable to login
Sat Jun 20, 2020 7:18 am
on fresh install without modification the standard login is user "pi" and password "raspberry".
rckanta
Re: Unable to login
Sat Jun 20, 2020 11:45 am
I have a very important project file in the sd card.
RonR
Re: Unable to login
Sat Jun 20, 2020 8:09 pm
Worst case, you can boot up a fresh copy of RaspiOS on a new SD card, mount the original SD card in a USB adapter, and copy your project file(s).
RamaSpaceShip
Re: Unable to login
Sun Jun 21, 2020 7:14 am
You can put the SD card in a PC (with an adapter) and copy the important files.
You can also use the PC to remove the password of the pi user to be able to login again once the SD card is back in the Pi
fbe
Re: Unable to login
Sun Jun 21, 2020 7:22 am
If your raspberry pi isn't running headless, you can add init=/bin/bash to the kernel parameters in cmdline.txt
After booting into the command line execute
mount -o remount,rw /
Then change the passwords and remove init=/bin/bash from the kernel parameters in cmdline.txt
Return to “Advanced users”
