ANDERCIAO
Install 2 os
Tue Jun 16, 2020 9:53 am
Hi everyone,
i ask if it's possible to install 2 os on raspberry and during the initial phase choose which start. Now i have installed debian on raspberry pi 4 with 2 Gb Ram and 64 Gb sd card.
do you have any suggestion?
aBUGSworstnightmare
Re: Install 2 os
Tue Jun 16, 2020 10:11 am
https://www.raspberrypi.org/downloads/noobs/
Isn't that exactly what NOOBS does?
BlackKnight_UK
Re: Install 2 os
Tue Jun 16, 2020 10:20 am
No, NOOBS just makes it easy for Newbies to get a choice of which OS to install.
BlackKnight_UK
Re: Install 2 os
Tue Jun 16, 2020 10:22 am
Hi everyone,
Search these forums for "dual boot", I found several threads, but as I haven't done it I wouldn't know what to suggest, but at least it'll give you some ideas until someone with more knowledge replies.
kerry_s
Re: Install 2 os
Tue Jun 16, 2020 10:43 am
Hi everyone,
it's better to have separate sd cards with what ever os you want & just swap them when you want to play with something else.
i have a 64bit beta & raspi lite + budgie desktop custom minimal install on 2 sd cards that i currently swap between.
currently using budgie.
Screenshot from 2020-06-16 00-40-51.png (99.25 KiB) Viewed 309 times
Re: Install 2 os
Tue Jun 16, 2020 10:44 am
Hi everyone,
There are 2 approaches, depends on your definition of dual boot!
BerryBoot is a Multiple Operating Systems Bootloader:
https://www.berryterminal.com/doku.php/berryboot
PiNN (NoobS on steroids) is an installer / chooser for multiple Operating Systems:
viewtopic.php?f=63&t=142574
B.Goode
Re: Install 2 os
Tue Jun 16, 2020 11:54 am
Wrong!
The NOOBS Installer does indeed support the installation of multiple Operating Systems on a single microSD card.
(It may not be advisable to do it, and NOOBS may not be the best tool, but it is certainly supported and documented.)
kartable
Re: Install 2 os
Tue Jun 16, 2020 7:27 pm
As far as I am concerned, Berryboot would be my choice if it allowed to install the OS on 1 or 2 partitions of a hard disk. But it takes the whole disk!
Return to “Advanced users”
