VNC on Buster 64-bit
Posted: Fri Jun 05, 2020 7:12 pm
by mache
I installed the latest beta of Raspberry Pi OS 64-bit (2020-05-27-raspios-buster-arm64.img) on my new RPi4/8GB and have been unable to get VNC working.
I followed the instructions on: https://www.raspberrypi.org/documentati ... ccess/vnc/
When I use the VNC Connect client from my Mac I get: The connection was refused by the computer
When I came to the instructions to modify /root/.vnc/config.d/vncserver-x11 I found that the file does not exist.
Can anyone suggest how to proceed forward?
Re: VNC on Buster 64-bit
Posted: Sat Jun 06, 2020 6:12 am
by MarkDH102
[EDIT]
NOTE: DO NOT use NoMachine. I am no expert on Linux and it has some very weird behaviour which has cause me no end of problems. Use X11VNC instead.
From thread
viewtopic.php?f=66&t=275225&hilit=nomachine
Re: Request for 64 bit raspbian.
Report this post
Sun May 31, 2020 5:36 pm
Given that VNC server doesn't work for connecting in to a headless Pi, I found that NoMachine for ARM - arm64
https://www.nomachine.com/download/down ... =109&s=ARM works just fine.
Its alpha software works nicely with raspios beta software.
And this is how I got the download onto the Pi from my WIn10 PC through SSH.
[FURTHER EDIT]
Persevered and got it running. Difficult! Used scp to get downloaded file (NoMachine) from Win10 over to Pi. Then followed instructions on link above. I have to say NoMachine seems to be very bloated and there are 10's of processes for it running on my Pi. And the PC installation took a while too for something so simple. Roll on RealVNC being available...
Then there are some issues with requiring passwords to shut down and mount USB drives.
Hope this all helps...
Posted: Sat Jun 06, 2020 9:01 pm
by b3lt3r
Seen lots of posts about issues with vncserver. I installed tightvnc on mine and it worked exactly the same as on my 32 bit versions - no issues at all. Tightvnc is part of my "standard" stack so didn't even try the shipped version.
Posted: Wed Jun 10, 2020 7:37 pm
by person1729
X11vnc seems to be the solution, https://github.com/raspberrypi/Raspberr ... -636544190, I had issues with tigntvnc and tigervnc as they didn't seem to start the desktop properly.
Posted: Wed Jun 10, 2020 7:59 pm
by fruitoftheloom
https://www.tomshardware.com/how-to/ins ... erry-pi-os
Posted: Wed Jun 10, 2020 9:29 pm
by bls
If you are happy with virtual desktops (not tied to the Pi console), https://github.com/gitbls/RPiVNCHowTo. Quick and easy, with multiple resolutions of your choice, if you wish.
