Botspot
What file is responsible for the 'pi@raspberrypi'?
Thu Jun 04, 2020 4:38 pm
I'm trying to debug a strange problem with my RPi virtual machine script.
When opening a terminal, it just looks like this:
  • Pressing Enter doesn't do anything.
  • It ignores anything I type in. (no text appears as I'm typing)
  • Strangely enough, running 'sudo lxterminal', that will work fine. And from there I can login as user pi and I get pi@raspberrypi like normal.
What to check first?
PS. This problem only occurs if I boot a RPiOS image. Raspbian Buster images didn't have this problem IIRC.
Want to make your own Raspbian image?
  • Hard way: Mess with confusing terminal commands.
  • Easy way: Let Pi-Power-Tools do it all for you!
Boot your image in a VM, Flash from the Internet at top speed, Mount (to drop files in), Edit partitions, Shrink/Expand, Repair, and more. Enjoy! :)
https://github.com/Botspot/Pi-Power-Tools
thagrol
Re: What file is responsible for the 'pi@raspberrypi'?
Thu Jun 04, 2020 10:50 pm
Assuming what you actualy want to know is what file sets the prompt to user@hostname the answer is: probably /etc/profile
However that may not be the question and answer you need.
At log in a number of scripts are run all of which call other commands. Any of which could be the problem.
Have a look at the following:
/etc/profile
All files in /etc/profile.d
The following files in your user's home directory: .profile, .bashrc, .bash_aliases
There may be others, especially if you're using a different shell. I've no idea if systemd fires anything on login.
Attempts to contact me outside of these forums will be ignored unless signed in triplicate, sent in, sent back, queried, lost, found, subjected to public enquiry, lost again, and finally buried in soft peat for three months and recycled as firelighters
Botspot
Fri Jun 05, 2020 12:27 am
Oh, I should have considered that. :roll:
Vdesktop mounts a customized version of /etc/profile to start the X session. Looks like time for a redesign. :roll:
Another question: chromium-browser works perfectly in the VM, as long as the host device is a Pi 3.
On a Pi4 running vdesktop, chromium-browser shows a "Aw, Snap!" error on every website. No idea why. Any pointers on what to check first? Thanks.
thagrol
Fri Jun 05, 2020 12:48 pm
No idea. Don't use the desktop or chromium. Sorry.
Botspot
Fri Jun 05, 2020 12:50 pm
No problem. So far nobody has had the slightest idea of what the problem could be.
pidd
Fri Jun 05, 2020 12:57 pm
Do you have to specify what to run inside the terminal eg bash or whatever you want? ie the terminal has to know what to connect to?
Botspot
Fri Jun 05, 2020 1:00 pm
I don't understand your question.
Are you asking how my virtual machine script works?
Return to “Advanced users”
