Mausy5043
[SOLVED] The certificate of `archive.raspberrypi.org` has expired
Sat May 30, 2020 1:32 pm
$ wget https://archive.raspberrypi.org/debian/raspberrypi.gpg.key
--2020-05-30 15:31:30--  https://archive.raspberrypi.org/debian/raspberrypi.gpg.key
Resolving archive.raspberrypi.org (archive.raspberrypi.org)... 176.126.240.84, 176.126.240.86, 176.126.240.167, ...
Connecting to archive.raspberrypi.org (archive.raspberrypi.org)|176.126.240.84|:443... connected.
ERROR: The certificate of ‘archive.raspberrypi.org’ is not trusted.
ERROR: The certificate of ‘archive.raspberrypi.org’ has expired.
Anybody know how to fix this?
Mausy5043 - NL
trejan
Re: The certificate of `archive.raspberrypi.org` has expired
Sat May 30, 2020 1:40 pm
Looks like one of the mirrors has an expired certificate. If you flush your DNS cache then you might get a different one?
Mausy5043
Sat May 30, 2020 1:50 pm
Nope. DNS gives me different IPs. None of them seem to work. I tried switching upstream DNS, also no luck.
Mausy5043 - NL
trejan
Sat May 30, 2020 1:51 pm
Yeah. Something odd happening. I checked the certificates for all the IPs and they've all got valid expiry dates. Not sure what is going on with wget.
markhealey
Sat May 30, 2020 1:53 pm
It looks like the issueis upstream, as I get this with apt...
Certificate verification failed: The certificate is NOT trusted. The certificate chain uses expired certificate. Could not handshake: Error in the certificate verification. [IP: 176.126.240.84 443]
epoch1970
Sat May 30, 2020 1:58 pm
Local date wrong on the host?
Mausy5043
Sat May 30, 2020 2:01 pm
No problem with `timedatectl`
Mausy5043 - NL
trejan
Sat May 30, 2020 2:12 pm
Server side configuration issue. It is sending an expired CA certificate. The *.raspberrypi.org wildcard certificate is still valid but it has to use a different certification path.
Certificate:
    Data:
        Version: 3 (0x2)
        Serial Number:
            13:ea:28:70:5b:f4:ec:ed:0c:36:63:09:80:61:43:36
        Signature Algorithm: sha384WithRSAEncryption
        Issuer: C = SE, O = AddTrust AB, OU = AddTrust External TTP Network, CN = AddTrust External CA Root
        Validity
            Not Before: May 30 10:48:38 2000 GMT
            Not After : May 30 10:48:38 2020 GMT
        Subject: C = US, ST = New Jersey, L = Jersey City, O = The USERTRUST Network, CN = USERTrust RSA Certification Authority[/cpde]
Mausy5043
Sat May 30, 2020 2:17 pm
        Validity
So, we're back at the original question.
Who knows how to fix this?
Mausy5043 - NL
trejan
Sat May 30, 2020 2:20 pm
It has to be fixed by the server admins. If you just want the key then use curl.
curl https://archive.raspberrypi.org/debian/raspberrypi.gpg.key -o raspberrypi.gpg.key
ShiftPlusOne
Sat May 30, 2020 2:24 pm
On it, hang on.
ShiftPlusOne
Sat May 30, 2020 2:30 pm
Looks like it was already fixed, or are people still seeing this?
$ wget https://archive.raspberrypi.org/debian/raspberrypi.gpg.key -O /dev/null --prefer-family=IPv4
--2020-05-30 15:30:24--  https://archive.raspberrypi.org/debian/raspberrypi.gpg.key
Resolving archive.raspberrypi.org (archive.raspberrypi.org)... 176.126.240.84, 46.235.227.39, 93.93.135.118, ...
HTTP request sent, awaiting response... 200 OK
Length: 1719 (1.7K) [application/pgp-keys]
Saving to: ‘/dev/null’
/dev/null                                        100%[=========================================================================================================>]   1.68K  --.-KB/s    in 0s
2020-05-30 15:30:24 (419 MB/s) - ‘/dev/null’ saved [1719/1719]
ShiftPlusOne
Sat May 30, 2020 2:33 pm
Okay, I see the issue if I use wget on the pi.
trejan
Sat May 30, 2020 2:35 pm
It is still sending the expired CA certificate. No idea why wget is fixated on that path only though.
trejan
Sat May 30, 2020 2:38 pm
$ echo | openssl s_client -showcerts -connect archive.raspberrypi.org:443 2> /dev/null | grep -A100 "^ 2" | openssl x509 -text -noout
Certificate:
    Data:
        Version: 3 (0x2)
        Serial Number:
        Validity
Or use https://www.ssllabs.com/ssltest/analyze ... =on&latest but it'll take a few minutes to run so doing it manually with openssl will be a lot faster.
ShiftPlusOne
Sat May 30, 2020 2:41 pm
Ah makes sense. I've raised the appropriate ticket.
Thanks everyone.
girishprasanna
Sat May 30, 2020 3:29 pm
Any idea when this would be fixed?
i still get this error.
Mausy5043
Sat May 30, 2020 4:22 pm
I'm stuck with `wget` on the pi. I just traced the error to `wget` but the code isn't mine and I can't change it. So, I'll just wait till it's fixed.
Thanks @ShiftPlusOne! I'll give it another try tomorrow.
Mausy5043 - NL
Sat May 30, 2020 4:43 pm
Our net provider has been informed, so we a waiting for them to sort it out. I do not know how long that will take.
girishprasanna
Sat May 30, 2020 5:11 pm
ok thanks for the update.
ShiftPlusOne
Sat May 30, 2020 5:42 pm
Update from them is that they're on it. Keep in mind it's 6:40PM on a Saturday here, so the right person might not be available immediately.
trejan
Sat May 30, 2020 6:33 pm
I've poked about in the source and the issue is that wget is using gnutls which is validating every peer certificate. If you're sending a CA bundle then every single certificate must be valid or it immediately errors out. The quick fix if anybody has this problem on their own server is to delete the expired AddTrust certificate from the bundle on the webserver. gnutls will then use the preinstalled USERTrust RSA Certification Authority certificate and work like normal.
Is there a giant raspberry logo being projected on to the clouds above Cambridge?
ShiftPlusOne
Sat May 30, 2020 6:37 pm
trejan wrote: Is there a giant raspberry logo being projected on to the clouds above Cambridge?
Always
dickon
Sat May 30, 2020 6:43 pm
*Are* there any clouds over Cambridge today?
It's been gloriously sunny here all day...
ShiftPlusOne
Sat May 30, 2020 7:00 pm
Try wget now
Return to “Advanced users”
