mozcelikors
Raspberry Pi 4 "VCHI initialization failed" error
Fri May 29, 2020 8:27 pm
I am trying to update Raspberry Pi 4 (64-bit) bootloader eeprom using vcgencmd commands and rpi-eeprom-update. I am using a custom Yocto distro that uses dtoverlay=vc4-fkms-v3d. I have the following config.txt and /proc/cmdline;
root@raspberrypi4-64:~# cat /proc/cmdline
coherent_pool=1M 8250.nr_uarts=1 cma=64M cma=256M video=HDMI-A-1:1024x600@60
smsc95xx.macaddr=DC:A6:32:03:2E:E3 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000
dwc_otg.lpm_enable=0 root=/dev/mmcblk0p2 rootfstype=ext4 rootwait     rootflags=commit=120,data=writeback
elevator=deadline noatime nodiratime data=writeback  bootdelay=0   consoleblank=0  vt.global_cursor_default=0
splash  lpj=216000 loglevel=1 console=ttyS0,115200
root@raspberrypi4-64:~# cat /run/media/mmcblk0p1/cmdline.txt
arm_64bit=1
dtparam=i2c_arm=on
dtparam=i2c1=on
dtparam=spi=on
boot_delay=0
dtparam=audio=on
avoid_warnings=1
disable_splash=1
enable_uart=1
dtparam=uart0=on
boot_delay=0
gpu_mem=256
dtparam=audio=on
avoid_warnings=1
disable_splash=1
max_usb_current=1
hdmi_group=2
hdmi_mode=87
hdmi_cvt 1024 600 60 6 0 0 0
hdmi_drive=1
root@raspberrypi4-64:~# getent group video
video:x:44:root
root@raspberrypi4-64:~# vcgencmd help
root@raspberrypi4-64:~# dmesg | grep vc4-cma
root@raspberrypi4-64:~# dmesg | grep cma
[    0.000000] cma: Reserved 256 MiB at 0x000000001ec00000
[    0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 cma=64M cma=256M video=HDMI-A-1:1024x600@60 smsc95xx.macaddr=DC:A6:32:03:2E:E3 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  dwc_otg.lpm_enable=0 root=/dev/mmcblk0p2 rootfstype=ext4 rootwait     rootflags=commit=120,data=writeback elevator=deadline noatime nodiratime data=writeback  bootdelay=0   consoleblank=0  vt.global_cursor_default=0 splash  lpj=216000 loglevel=1 console=ttyS0,115200
[    0.000000] Memory: 3456472K/3866624K available (5950K kernel code, 390K rwdata, 1980K rodata, 512K init, 560K bss, 148008K reserved, 262144K cma-reserved)
When I issue any vcgencmd command, I get "VCHI initialization failed". My user is correctly set up, I am thinking maybe some feature is not integrated to the custom BSP I'm basing my work on. For example, there is no vc4-cma loaded, only vc4-drm is loaded.
Any ideas are greatly appreciated.
Let me know if anything else might be needed as info. Thanks.
swahren
Re: Raspberry Pi 4 "VCHI initialization failed" error
Sat May 30, 2020 9:15 am
Did you enabled CONFIG_BCM2835_VCHIQ in the kernel?
esvertit
Wed Jun 03, 2020 8:17 pm
Hi swahren, how to do this?
6by9
Thu Jun 04, 2020 10:38 am
You set it in the kernel config when you're building your kernel. It's in the standard Pi defconfigs. VCHIQ also needs to be enabled via device tree.
audas
Sun Nov 08, 2020 9:00 am
I am trying to get both HDMI ports using CEC commands. I updated to the 5.9 kernel however I am now unable to use wireless mouse etc. However it apepears TVSERVICE is not working now as well. I get the following error
"Failed to initialize VCHI (ret=-1)"
Perhaps hardware issues are the cause as per this thread. I am not sure how to go about adding this in ?
I followed the steps on changing the kernel found here
https://www.raspberrypi.org/documentati ... uilding.md
But everything seems broken now.
I changed this to
CONFIG_LOCALVERSION="rpi-5.9.y"
Any help or thoughts on where things went wrong ?
6by9
Sun Nov 08, 2020 9:23 am
Issues related to the 5.9 kernel should be reported on the 5.9 kernel thread
Return to “Advanced users”
