ag123
Mixing 64 bits shared libraries on Raspbian buster
Thu May 28, 2020 10:49 am
As i'm running the 64 bit kernel in Raspbian Buster i.e.
/boot/config.txt
[all]
arm_64bit=1
i used the sysroot shared library distribution from linaro
https://www.linaro.org/downloads/
created a directory
/usr/lib64
and placed the libc.so in there
libc-2.25.so  libc.so.6  libgcc_s.so.1
and placed the dynamic linker ld.so in /lib
/lib/ld-linux-aarch64.so.1
created an entry for /etc/ld.so.conf
/usr/lib64
ran sudo ldconfig
then i compiled a little c code aarch64 binary and ran it on the Pi4. apparently it seemed to work.
is this an appropriate way to setup both 64 bit shared libraries and 32 bits shared libraries in Raspbian Buster?
is there a better way to do it?
apparently when the 64 bit test binary ran, it gives a message
ERROR: ld.so: object '/usr/lib/arm-linux-gnueabihf/libarmmem-${PLATFORM}.so' from /etc/ld.so.preload cannot be preloaded (wrong ELF class: ELFCLASS32): ignored.
but otherwise the program ran ok, producing a 'hello world'.
satadru
Re: Mixing 64 bits shared libraries on Raspbian buster
Thu May 28, 2020 3:23 pm
Perhaps now is the time to try the Raspberry Pi OS (64 bit) beta test version announced today?
viewtopic.php?f=117&t=275370
Return to “Advanced users”
