Hilo
multiple BT connection
Wed May 27, 2020 4:33 pm
I would like to connect to my raspberry multiple BLE devices. using nRF connect I can connect just with one smartphone. I started with the code from this repo https://github.com/Douglas6/cputemp. any suggestion on how to do that?
topguy
Re: multiple BT connection
Wed May 27, 2020 5:22 pm
What is your usecase ?
Are the Pi going to read data from other BLE devices or report data to clients ?
Hilo
Fri May 29, 2020 9:17 am
what to read data (in this case CPU temperature) with multiple device from the Pi. ATM if I connect with nRF Connect to the PI with a smartphone I can't connect another smartphone without disconnect before the first one
topguy
Fri May 29, 2020 9:58 am
It might be a limitation in the GATT server example code you are using..
Maybe send the Author a question on GutHub to see if this is the case.
PiGraham
Fri May 29, 2020 10:17 am
I don't know, but is that a general limitation of Bluetooth devices? I can't connect more than one phone at once to a Bluetooth speaker or headset. Many BT devices are either in connectable state or a connected state.
What BT devices allow multiple clients to connect at once?
Could you use Wi-Fi. That definitely allows multiple connections by design.
Hilo
Fri May 29, 2020 1:20 pm
The limitation for standard BT is 7 device to a master (in BLE it is teorically 65k). you can't connect your phone to multiple speaker not for BT limitation but just cuz in phones is implemented like this (and this is not entirelly true cuz you can connect to the PI and listen music with speaker at the same time). Using a BT server on Raspberry PI teorically speaking it is possible but I don't know how..
PiGraham
Fri May 29, 2020 2:20 pm
I read your post to be RPi as slave and you want to connect multiple Master devices to it at the same time to read the temp.
Clearly you can connect a phone to multiple BT devices at the same time, and given the right app I suppose you could pipe music to multiple speakers. But can slaves connect to many masters at once?
Or have I misunderstood your objective?
meeriino
Mon Jun 01, 2020 5:10 pm
hey, I'm interesting in something similar. I wanna play music from my RPi 4B to multiple slave speakers...
What about that? Have anybody any idea?
fanoush
Mon Jun 01, 2020 6:15 pm
You don't need connection for that, you can put temperature and more information directly to advertising packet or to scan response packet.
PiGraham
Mon Jun 01, 2020 6:32 pm
Good idea! Do you have any pointers on how do that?
PiGraham
Mon Jun 01, 2020 6:35 pm
deepo
Mon Jun 01, 2020 6:41 pm
The Eddystone beacon specification describes that.
https://github.com/google/eddystone
Specifically the TLM (telemetry, unencrypted) specification allows you to put a temperature in an advertisement message. There are probably other specifications that does that too, but here it is.
https://github.com/google/eddystone/blo ... m-plain.md
This guide tells you how to have a Raspberry Pi sending those advertisements:
https://pimylifeup.com/raspberry-pi-eddystone-beacon/
/Mogens
fanoush
Tue Jun 02, 2020 8:26 am
You can put almost anything into advertising packet just be aware of size limitation - 31 bytes. There are some assigned ids here https://www.bluetooth.com/specification ... s-profile/ e.g. name is 0x09, structure is sequence of length,type,value,.. Good is to use nrfconnect on your phone, pick device from list and click "RAW" and you will see advertising packet structure.
Advertising packet is broadcast to anyone, scan response is for those who ask back and scan your device (still without connection). Also it is possible to keep some part of packet fixed (e.g. name if you want any) and vary the rest (e.g. manufacturer data) if one needs to send more data. Then the receiving device must collect more packets over time.
I am not sure how exactly this can be done on the PI, this is generic BLE knowledge. Personally I use it with Espruino on nrf52 smartwatches - the api description https://www.espruino.com/Reference#l_NRF_setAdvertising explains a lot of possibilities or there are examples e.g. here https://www.espruino.com/BLE%20Advertising or here http://forum.espruino.com/conversations/306687/ to get more info what should be possible on the Pi too.
BTW if you are into BLE, current best choice for hackable BLE smartwatch that can run your Arduino or Espruino code without taking it apart is probably the P8 for ~US$18 or F07 fitness tracker for $14-$16 see e.g. https://hackaday.com/2020/05/02/cheap-s ... -own-code/ or Espruino for P8 here , for F07 here
Also the Pinetime watch is very similar/same to P8 (same manufacturer, mostly same hardware inside) but P8 is better choice IMO.
deepo
Tue Jun 02, 2020 5:17 pm
If one were to follow a standard, the GATT Specifications for Health Thermometer Profile and Health Thermometer Service could be a way to send a temperature. But I don't know enough about Bluetooth to implement such a thing. Maybe others with more Bluetooth knowledge could comment?
https://www.bluetooth.com/specifications/gatt/
/Mogens
Return to “Advanced users”
