Hello Everyone,
I'm using a CMIO board V1.2 fitted with CM V1.1 with raspbian updated these days (4.19.98+ #1294).
I'm struggling to get my CM to work with the raspberry pi camera. I've been following this tutorial:
https://www.raspberrypi.org/documentati ... -camera.md
So I downloaded the dualcam dts source and compiled it.
I copied the compiled stb to /root/overlays and declared at the end of /root/config.txt.
But.. it has no effect. I mean I can see the read operation in 'sudo vcdbg log msg' but my configuration is not used (mainly the configuration of GPIO29-31). I get the same result with or without the added line in config.txt.
Does anyone can give me a clue?
Thanks in advance.
