Captain_Andy
Rpi 4 Wifi issue
Sat Apr 11, 2020 8:46 pm
Just received a brand new Rpi 4B, installed the latest Rasbian Desktop. Did all the usual updates/upgrades
Rpi would not connect to my wireless network. My router is a Billion BiPac 5200G R4 and the wifi is operating on 2.4Ghz.
After much head scratching, realised that the Rpi may need a 5Ghz wireless connection, so I borrowed a BT Hub 4 which has this capability.
The Rpi connects with the wireless of the BTHub 4 and is assigned an ip address and works ok.
Surely it must be possible for the Rpi 4B to work with 2.4Ghz wireless routers such as my Billion router. I have previous versions of the Rpi and they all work with my Billion router.
Could someone explain what might be going on and have i missed something about configuring the Rpi 4B to use 2.4Ghz.
wpballa1
Re: Rpi 4 Wifi issue
Sat Apr 11, 2020 9:44 pm
It should work just fine on either 2.4 or 5 GHz bands. Your most likely problem is a typo in the SSID or password so try going to the wireless icon and selecting the desired SSID and reentering the password. If you don't see the network at all, I would suspect a defective Raspberry Pi.
ejolson
Sat Apr 11, 2020 9:48 pm
Did you set the country code? I don't think WiFi can will work at all without that, for fear of local broadcasting rules.
wpballa1
Sat Apr 11, 2020 9:52 pm
Yes, the country code could be the problem as well. Did you set it in localization options through raspi-config?
I generally put a working copy of wpa_supplicant.conf in the boot partition of a new SD image to avoid worrying about the configuration setup, but I think this only works on first boot.
Captain_Andy
Sat Apr 11, 2020 10:00 pm
Have re-entered my password multiple times without success when trying to connect on 2.4Ghz wifi. Only suspicion is that the password contains 2 spaces. Would be very unlucky to have received a faulty Rpi 4B, but possible.
Have checked the wpa_supplicant.conf file and it shows the country code set to GB which is correct for the United Kingdom.
Last edited by Captain_Andy on Sat Apr 11, 2020 10:34 pm, edited 2 times in total.
wpballa1
Sat Apr 11, 2020 10:16 pm
Maybe try resetting/rebooting your router and see if that works.
Return to “Advanced users”
