thechosenginger
Enable/disable HDMI on times schedule
Wed Apr 08, 2020 3:59 pm
I am looking for some help and guidance. I would like to set a raspberry pi I use for work applications to enable and disable the HDMI port each workday at 7am and 7pm. I think I understand the build blocks for what I need, but I do not understand where to start within the pi applications.
Thank you for the help.
procount
Re: Enable/disable HDMI on times schedule
Wed Apr 08, 2020 4:03 pm
Can you just set 2 entries in cron, one for 7am, the other for 7pm, that respectively call "tvservice -p" and "tvservice -o" ?
trejan
Wed Apr 08, 2020 4:57 pm
It is better to use "vcgencmd display_power 0/1" as that only turns on/off the HDMI PHY. Using tvservice will shutdown the entire pipeline and you need to refresh the display when turning it back on or it'll only show a black screen.
klricks
Wed Apr 08, 2020 6:22 pm
Also note that depending on your monitors brand, model and OSD settings. The vcgencmd display_power 1 command may not wake the monitor from standby.
In my case issuing vcgencmd display_power 0 shuts off the HDMI output as expected. Then the monitor displays a "No Signal" banner for about 20 min. then goes into standby. So when in standby and after issuing vcgencmd display_power 1, I must also press the physical power button on the monitor or remote.
Return to “Advanced users”
