trejan
Re: Moving Linux Kernel to 5.4
Wed May 20, 2020 7:33 pm
rcfa wrote:
Wed May 20, 2020 7:04 pm
I got two machines a 3B and 3B+, both of which should be 64-bit capable, but as can be seen here, rpi-update doesn't download the necessary files:
Is this an old Stretch install you upgraded to Buster? rpi-update won't automatically copy the kernel7l.img and kernel8.img kernels if this was an old Stretch install as the /boot partition is too small. The Buster image has a /boot partition that is 4x as big. You can force it by creating an empty /boot/kernel7l.img before running rpi-update but you risk running out of space for future updates.
cjan
Wed May 20, 2020 10:39 pm
dom wrote:
Wed May 20, 2020 12:41 pm
cjan wrote:
Tue May 19, 2020 6:00 am
dtoverlay=vc4-kms-v3d on Pi2, no analog audio.
last update to 5.4.40.
There is no arm side analogue driver. You probably want:
dtparam=audio=on
dtoverlay=vc4-kms-v3d,audio=off
Also note this post about separate alsa devices.
did not work.
sorry forgot to say, boot into CLI-console.
rcfa
Wed May 20, 2020 11:11 pm
Ah, thanks! That’s exactly what it is!
How big are the new boot partitions?
This is on SSDs, so I can resize them with some tools, hopefully...
Also, since I’m already on the latest kernel, is there a way to force the update to run again?
trejan
Wed May 20, 2020 11:23 pm
/boot is 256MB on the Buster images.
branchus
Thu May 21, 2020 8:10 am
looking forward to this
once the usb boot is practical usable, I will rebuild my system, hope the new kernel is available at that time.
dom
Thu May 21, 2020 9:54 am
sudo rm /boot/.firmware_revision
Then run rpi-update again.
PhilE
Thu May 21, 2020 10:03 am
@DougieLawson Did you ever get your MAX7219 display working? I ask because I finally got round to hooking mine up, and it's running fine with 5.4.42 and the hacked test programme (although I had to delete those two leading spaces to get all 8 digits displayed).
dom
Thu May 21, 2020 10:28 am
did not work.
"did not work" is not really useful. What exactly did you run and how did it fail (just silent, or with an error message).
Is the alsa device present? Report output of "aplay -l"
dickon
Thu May 21, 2020 11:14 am
I'm stuck, and I don't really know where to begin. arm_64bit=1 in /boot/config.txt results in no wifi interfaces appearing, although everything else seems OK. Pertinent bits of dmesg are:
(64b:)
[   13.351321] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[   13.352779] usbcore: registered new interface driver brcmfmac
[   13.366037] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.raspberrypi,4-model-b.txt failed with error -2
(32b:)
[   13.138493] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[   13.160688] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Mar  2 2020 23:30:41 version 7.45.202 (r724630 CY) FWID 01-72f6ece2
and, indeed, I see that that file is missing. Copying the brcmfmac43455-sdio.* to brcmfmac43455-sdio.raspberrypi,4-model-b.* and rebooting didn't help.
Any ideas?
PhilE
Thu May 21, 2020 11:20 am
The Pi4-specific .txt file isn't meant to be there, but you've trimmed too much of the log to be useful - "dmesg | grep brcmfmac" would be better.
dickon
Thu May 21, 2020 11:26 am
Apologies. 64b:
[   12.753082] brcmfmac: F1 signature read @0x18000000=0x15264345
[   12.770171] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[   12.770712] usbcore: registered new interface driver brcmfmac
[   12.786774] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.raspberrypi,4-model-b.txt failed with error -2
vs. 32b:
[   12.834477] brcmfmac: F1 signature read @0x18000000=0x15264345
[   12.845454] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[   12.846064] usbcore: registered new interface driver brcmfmac
[   12.860141] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.raspberrypi,4-model-b.txt failed with error -2
dickon
Thu May 21, 2020 11:39 am
This look pertinent, too:
[   23.007277] mmc1: Timeout waiting for hardware interrupt.
[  242.659272] INFO: task kworker/0:1:31 blocked for more than 120 seconds.
[  242.659289]       Tainted: G         C        5.4.42-v8+ #1319
[  242.659297] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this
message.
[  242.659308] kworker/0:1     D    0    31      2 0x00000028
[  242.659344] Workqueue: events request_firmware_work_func
[  242.659357] Call trace:
[  242.659374]  __switch_to+0xc4/0x248
[  242.659388]  __schedule+0x3dc/0x780
[  242.659399]  schedule+0x44/0xc8
[  242.659412]  schedule_timeout+0x244/0x370
[  242.659423]  wait_for_completion+0xa8/0x128
[  242.659439]  mmc_wait_for_req_done+0x48/0x150
[  242.659452]  mmc_wait_for_req+0xa0/0xe0
[  242.659465]  mmc_io_rw_extended+0x2d8/0x308
[  242.659479]  sdio_io_rw_ext_helper+0x180/0x1e8
[  242.659492]  sdio_memcpy_toio+0x44/0x58
[  242.659546]  brcmf_sdiod_skbuff_write.isra.14+0x48/0x98 [brcmfmac]
[  242.659589]  brcmf_sdiod_ramrw+0x120/0x250 [brcmfmac]
[  242.659630]  brcmf_sdio_firmware_callback+0x194/0x840 [brcmfmac]
[  242.659671]  brcmf_fw_request_done+0x98/0xf8 [brcmfmac]
[  242.659685]  request_firmware_work_func+0x50/0x90
[  242.659698]  process_one_work+0x158/0x4b8
[  242.659710]  worker_thread+0x50/0x498
[  242.659721]  kthread+0xfc/0x128
[  242.659734]  ret_from_fork+0x10/0x1c
which repeats every two minutes or so.
cjan
Thu May 21, 2020 11:42 am
did not work.
alsa headphone device present, but silent.
Thu May 21, 2020 1:25 pm
I've got three MAX7219 devices (two with the 8-digit LEDs, one with an 8x8 matrix).
Works OK on a 3A+ (64-bit), works OK on a 3B (64-bit)
Still does NOT work on a Raspberry Pi Zero Rev 1.2 (tested it with 5.4.42+ yesterday, back on 4.19.118 today)
I'll move one of those displays to an old RPi1B and give that a go.
PhilE
Thu May 21, 2020 1:35 pm
@dickon That's peculiar. The 64-bit kernel I just built has no problem with WiFi:
pi@raspberrypi:~$ uname -a
Linux raspberrypi 5.4.42-v8+ #209 SMP PREEMPT Thu May 21 13:45:07 BST 2020 aarch64 GNU/Linux
pi@raspberrypi:~$ dmesg | grep brcmf
[    6.585966] brcmfmac: F1 signature read @0x18000000=0x15264345
[    6.599090] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[    6.599969] usbcore: registered new interface driver brcmfmac
[    6.621499] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.raspberrypi,4-model-b.txt failed with error -2
[    6.838296] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[    6.857011] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Mar  2 2020 23:30:41 version 7.45.202 (r724630 CY) FWID 01-72f6ece2
[    8.829051] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
Are you testing by adding "arm_64bit=1" and making no other changes? What do you have in your config.txt?
dickon
Thu May 21, 2020 1:46 pm
I am. Just commenting and uncommenting that line. Contents (and I apologise; it's a fairly long-lived thing, so has accumulated some cruft):
root@rtr-dickonh:~# cat /tftpboot/pi4/config.txt
# For more options and information see
# http://rpf.io/configtxt
# Some settings may impact device functionality. See link above for details
arm_64bit=1
gpu_mem=256
initramfs initrd.gz
hdmi_enable_4k=1
dtoverlay=w1-gpio
hdmi_ignore_cec_init=1
# Enable audio (loads snd_bcm2835)
dtparam=audio=on
bootloader_update=1
[pi4]
# Enable DRM VC4 V3D driver on top of the dispmanx display stack
dtoverlay=vc4-fkms-v3d
# dtoverlay=vc4-kms-v3d-pi4
max_framebuffers=2
enable_uart=1
dtoverlay=uart5,uart0
start_x=1
[all]
#dtoverlay=vc4-fkms-v3d
hdmi_enable_4kp60=1
root@rtr-dickonh:~#
I've also tested this on an SD card, so it isn't an artifact of netbooting it. I'm attempting to test it on a spare 3B as I type. The initramfs is present to get the NFS root on the bridge device, which it does with a script in nfs-top, which NFS mounts the eventual filesystem, runs 'chroot /root modprobe bridge', does a couple of brctl calls, umount, and continues. As there are no version-specific modules in that, it shouldn't be making any difference.
PhilE
Thu May 21, 2020 1:59 pm
There's nothing obviously wrong there. A few observations:
This can/should be:
provided you are using current firmware and have installed "overlay_map.dtb" into the overlays directory.
The use of uart0 there could confuse a simple person, since it is a global dtparam rather than a parameter of the uart5 overlay, but it isn't wrong.
I'd like to see a test without the initrd.gz, to rule that out as a potential cause.
dickon
Thu May 21, 2020 2:21 pm
Same problem with a direct, kernel-driven mount, only obviously the IP address is now on the wrong interface:
root@pi4:~# dmesg | grep brcmfmac
[    9.507505] brcmfmac: F1 signature read @0x18000000=0x15264345
[    9.530537] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[    9.531508] usbcore: registered new interface driver brcmfmac
[    9.551369] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.raspberrypi,4-model-b.txt failed with error -2
[  242.660849]  brcmf_sdiod_skbuff_write.isra.14+0x48/0x98 [brcmfmac]
[  242.660892]  brcmf_sdiod_ramrw+0x120/0x250 [brcmfmac]
[  242.660934]  brcmf_sdio_firmware_callback+0x194/0x840 [brcmfmac]
[  242.660975]  brcmf_fw_request_done+0x98/0xf8 [brcmfmac]
[  363.495601]  brcmf_sdiod_skbuff_write.isra.14+0x48/0x98 [brcmfmac]
[  363.495644]  brcmf_sdiod_ramrw+0x120/0x250 [brcmfmac]
[  363.495686]  brcmf_sdio_firmware_callback+0x194/0x840 [brcmfmac]
[  363.495728]  brcmf_fw_request_done+0x98/0xf8 [brcmfmac]
root@pi4:~#
PhilE
Thu May 21, 2020 2:42 pm
I have no idea what's causing the WLAN firmware to die as it is appearing to, but I have a feeling that starting with a clean Raspbian image you would see no such problem.
dickon
Thu May 21, 2020 3:35 pm
Yes, it does appear that I can boot the pi with another filesystem and it works, but I'm loathe to simply dump this one and start again because it's annoying to keep doing that, and I haven't done anything odd to it that I can think of that would cause this problem. The wifi works perfectly happily with the 32b kernels, and with the 64b 4.x.y (IIRC), so I'm not sure why it isn't with the 64b 5.x.y kernel. If I simply dump everything and start again, I run the risk of tripping over the same thing at some point in the future.
PhilE
Thu May 21, 2020 3:37 pm
Have you built your kernel with the standard arm64 bcm2711_defconfig, or have you made some changes?
dickon
Thu May 21, 2020 3:38 pm
This is a rpi-update kernel. I haven't rebuilt it.
PhilE
Thu May 21, 2020 3:41 pm
Good. I had to ask.
rcfa
Thu May 21, 2020 3:47 pm
Thanks! Great, that (almost) worked. Gparted refused to make a 256MB partition and “corrected” my input always back to 255MB, which should be big enough for the foreseeable future given that just about 22% of /boot are used now.
So aside from rpi-update bitching about the partition being 1MB too small, things are up and running, 64-bit kernel is alive.
Are there any non-kernel binaries that are in aarch64 that one should preferably install? Anything that should be added to /etc/apt/sources.list ?
rcfa
Thu May 21, 2020 3:49 pm
Thanks! That did it!
Return to “Advanced users”
