peppy.player
What is the best way to create compressed disk image?
Thu Mar 05, 2020 11:45 pm
What is the best way to create a compressed disk image which would not exceed 2GB? The requirement for 2GB file comes from the Github which allows to host files 2GB max. You can break it into chunks but that overcomplicates the task for people who will use that disk image.
My current process includes too many steps and I’m just wondering if it’s possible to simplify it somehow:
- Use 8GB SD card, install all required software on that card on Pi
- Remove card from Pi and insert it into my Windows 10 desktop
- Using Win32 Disk Imager create ‘img’ file
- Insert another 16GB SD card with ‘pishrink’ program into Pi
- Copy ~8GB img file from Windows to Pi using WinScp
- Run ‘pishrink’ which will compress ~8GB img file into ~4GB file
- Copy shrinked file back to Windows machine using WinScp
- Compress ~4GB shrinked file using zip. The file becomes about 1.8 GB
- Copy 1.8GB image file to Github
Is there any way to improve/simplify the process? It takes too much time right now.
Thank you!
Re: What is the best way to create compressed disk image?
Thu Mar 05, 2020 11:52 pm
Use parted or gparted to shrink your system down to the minimum possible size. You'll need your RPi booted from some other SDCard and the filesystem you want to shrink in a USB reader.
Steal the filesystem resize code (at first boot) stuff from Raspbian. So you can expand it back to full size.
Write an image file using a Linux system (you've got one of those on your RPi). Don't write the unused space beyond your shrunken partition.
peppy.player
Fri Mar 06, 2020 12:02 am
Thank you for reply!
I'm not sure where I can save time using your approach? I still need to create image file on my Windows machine and copy it to USB flash drive. Though probably copying to USB flash drive is faster than copying to Pi over SSH.
RonR
Fri Mar 06, 2020 12:14 am
Have you explored Image File Utilities
Fri Mar 06, 2020 12:18 am
I can't work out what you think you need on Windows. Everything can be done on that nice little Linux system that you own, including writing SDCards or USB sticks.
peppy.player
Fri Mar 06, 2020 12:27 am
How the system which I need to shrink will appear on USB drive?
peppy.player
Fri Mar 06, 2020 12:32 am
I use 'shrink' utility. Though I don't think it's from your library.
peppy.player
Fri Mar 06, 2020 6:21 pm
I have outlined my current procedure in the first post. Is it possible to do the same for any other approach which could save time? Anyone who does that in a different way please post your steps here. Thanks in advance!
Paul Hutch
Fri Mar 06, 2020 9:03 pm
I use basically the same process as you listed except I avoid moving the files and cards around by doing it all on a spare Pi running desktop Raspbian.
The spare Pi has a uSD card reader and extra USB storage for the files, and I use dd to do the read/write and 7Zip for the final compression.
peppy.player
Fri Mar 06, 2020 9:17 pm
That sounds interesting. Paul, could you describe the whole process? Thanks in advance!
Paul Hutch
Fri Mar 06, 2020 9:44 pm
I plagiarized your list as a starting point :-)
- Remove card from Pi and insert it into my desktop Pi's card reader
- Use dd to create an ‘img’ file on the USB storage (HDD or thumb drive depending on which extra Pi I'm using)
- Run ‘pishrink’ on the created image
- Compress the shrunken file using 7Zip.
- Copy file to Internet
peppy.player
Fri Mar 06, 2020 9:59 pm
Thank you! This approach can really save time by eliminating the time for transferring files back and forth. I believe instead of the second Pi the same one could be used but with different SD card, right?
Paul Hutch
Sat Mar 07, 2020 12:21 pm
Yes you could just use the same Pi with a second card setup for the image copy process. If you used an extra large second card you can even skip the external USB storage for storing the large disk images.
ConfuSomu
Sun Mar 08, 2020 5:33 pm
Compressing the image using the bzip2 compression algorithm is more efficient than using zip (with DEFLATE compression). You can compress a file with the bzip2 compression algorithm using the 7-Zip compression utility. Make sure to choose bzip2 in the interface.
Hope that helps.
If you are low on RAM, make sure to use zram! ;)
I found & use this zram setup script: https://github.com/novaspirit/rpi_zram
A post about zram: t=207304
Make sure to disable dphys-swapfile and mount the tmp folders in RAM. Also learn about SysRq!
peppy.player
Sun Mar 08, 2020 9:14 pm
Hope that helps.
Thank you for advice. Though that assumes that everyone who will use that compressed disk image should also install 7-zip.
Greg Erskine
Sun Mar 08, 2020 10:17 pm
hi peppy.player,
I think you need to use Linux to script the creation of your image. You need to make it a one step process for your sanity. :D
We compress pCP to a zip format compatible with Windows 10.
regards
Greg
* Raspberry Pi is a trademark of the Raspberry Pi Foundation
peppy.player
Mon Mar 09, 2020 1:25 am
Next time I'll try slightly modified approach suggested by Paul:
- Connect USB card reader to Pi
- Use 8GB SD card inserted into Pi, install all required software on that card on Pi
- Remove card from Pi and insert it into card reader
- Use dd to create an ‘img’ file from 8BG card inserted into reader on the 16GB card inserted to Pi
- Zip shrunken file ~4GB -> 1.8GB
3 steps in this procedure can be scripted: dd, pishrink, zip.
Zwartoog
Mon Mar 09, 2020 11:26 am
I am not sure why you keep on moving back-and-forth between Windows and the Pi.
I assume this is a process you do yourself to prepare a suitable image to prepare for the generic audience?
I would do something like this:
- by a USB-SD card reader
- prepare your distribution on SD card 1, i.e. SDPEPPY
- now boot your Pi with SD card 2, i.e. SDRASPBIAN
- insert SDPEPPY in USB-SD
- use dd to create an image from SDPEPPY, write this to SDRASPBIAN (or a generic USB-key, or network storage)
- use phishrink/zip/whatever you need on this image
Aside from swapping the SD cards to boot in Raspbian, you can script all the other steps.
peppy.player
Mon Mar 09, 2020 2:48 pm
I suspect you didn't see my last post. Thank you anyway.
Zwartoog
Mon Mar 09, 2020 9:34 pm
Ouch, that's embarrassing :oops:
Return to “Advanced users”
