RaspbianUser1
Re: Pi Power Tools: General Purpose Disk Image & SD Card Manager
Mon Oct 19, 2020 9:49 pm
Yes of course
Running either Raspberry Pi OS desktop Full or Raspberry Pi OS MATE desktop
Overclocked at 2200MHz CPU and 700 MHz GPU with a over voltage of 7
Think before you delete something a stranger on the internet told you to.
Botspot
Mon Oct 19, 2020 10:34 pm
Yes of course
OK, and what about my other 2 questions?:
Once again: are you using my vdesktop beta version?
And what command do you have to run for this mate desktop to launch?
Also, does running x-terminal-emulator launch a terminal on your system? Or do you get "command not found"?
Want to run Minecraft Java on your RPi? Easiest way is with Pi-Apps - just click Install.
https://github.com/Botspot/pi-apps
Pi-Apps also includes Zoom, Visual Studio, Tor browser, Windows 10 theme, and 33 more.
Over 50,000 users!
RaspbianUser1
Mon Oct 19, 2020 11:16 pm
Sorry my mistake
I will answer all
Using beta, No
Desktop, mate-session however I retested and it doesn’t work on vdesktop, however when choosing a different tty than 7 on the the actual machine, running sudo lightdm | mate-session gives a terrible resolutioned DE
x-terminal emulator it does have it installed but im on CLI only on vdesktop
Botspot
Tue Oct 20, 2020 1:33 am
This is interesting. Do you know if there is an img with a mate desktop, that I could download, for testing on vdesktop?
If there aren't any images available, would you consider uploading your image so I can ensure it works?
Over 50,000 users!
RaspbianUser1
Tue Oct 20, 2020 8:48 am
Sorry there are no MATE raspbian images publicly available and I would not give you mine due to sensitive data I would have to find and remove
However its easy to get a basic install following a guide
https://www.raspberrypi.org/forums/vie ... p?t=133691
It takes about 20 minutes on a fast connection speed
Make sure you start it on Lite
Return to “Advanced users”
