Botspot
Pi Power Tools: General Purpose Disk Image & SD Card Manager
Wed Mar 04, 2020 5:21 pm
Pi Power Tools is a GUI tool that manages Raspbian .img files.
Key features:
  • Boot - Powered by Vdesktop. Runs the disk image in a virtual machine.
  • Flash - Speed-tuned. Can flash Raspbian directly from the Internet to the selected device.
  • Mount - In one click, view & edit the contents of a Raspbian disk image.
  • Edit - Creates a virtual usb device for the disk image, then opens it with Gparted.
  • Resize - Expand or shrink a disk image, thanks to RonR's Image-utils.
  • More features, such as advanced mountpoint control, filesystem repair & diagnostics, and incremental backups.
A few screenshots:
You want to give it a try?
To run the graphical installer:
Paste this in the terminal, then press Enter.
wget -O - https://raw.githubusercontent.com/Botspot/Pi-Power-Tools/master/update | bash
GitHub page & instructions right here.
If you have any questions, just reply to this forum or open an issue on GitHub.
I've had a total blast developing this powerful tool for my own benefit. Feel free to play with it too. ;)
Want to run Minecraft Java on your RPi? Easiest way is with Pi-Apps - just click Install.
https://github.com/Botspot/pi-apps
Pi-Apps also includes Zoom, Visual Studio, Tor browser, Windows 10 theme, and 33 more.
Over 50,000 users!
RonR
Re: Pi Power Tools: General Purpose Disk Image & SD Card Manager
Wed Mar 04, 2020 11:14 pm
Botspot,
You should let users know that you are distributing outdated and modified versions of my Image File Utilities in opposition to my request and against my wishes.
Thu Mar 05, 2020 9:45 am
If RonR can confirm his issues have been dealt with, I will delete posts as necessary.
Botspot
Thu Mar 05, 2020 1:06 pm
Although RonR has not confirmed (yet), I have dealt with the issue on my end and am no longer "distributing outdated and modified versions or Image File Utilities."
The PPT installation script now downloads Image-utils directly from RonR's latest download link and does not modify them at all.
Furthermore, I have reached out to RonR four times now. See here, here, here, and here. Still waiting for a response. :?
Edit: As of 3/16/2020, I've decided to completely remove RonR's image-utils from Pi Power Tools. And so, I've developed a replacement to image-shrink, called shrinkimage. It's built from scratch, and doesn't copy RonR's code design at all. More details here.
Over 50,000 users!
neal1
Fri Aug 14, 2020 9:24 am
Hi I tested Pi power tools, thanks a lot for this wonderful tool,
I am facing a little issue, i can see in your github repo snapshots your instance is connected to internet possibly by LAN, but i am unable to connect to internet inside instance, it keep on searching for wifi but never found.
Though it connect pi localhost.
Also i cant find any email to contact you.
Botspot
Fri Aug 14, 2020 2:27 pm
That's one thing I haven't been able to test for. I use LAN, not WiFi, so I haven't been able to test how a container will behave under those conditions.
I would like to ensure it works though, so would you be willing to try some tests for me?
Over 50,000 users!
neal1
Sat Aug 15, 2020 6:10 am
Count me in, let me know what to test.
One strange behavior i found yesterday,
two days before it work perfectly.
yesterday after two power outages, my pi got off without shutdown.
Now when i boot Pi power tool image.
Icon on top disappears, i can use then but can't see
I am not sure about partition thing, i clicked Reset PT, didn;t solved issue.
I am using Raspberry pi 4 b 4 gb RAM, 128 Gb Card, i didn't tried WLAN, will try. Though best will be if it work on wifi for my needs.
I am trying to use it as a Xorg + Light DM + Xpheyper alternative (as i do not know well and can;t find easy instructions to setup)
As a multi user setup using 1 pi board with 2 monitors + 2 keyboards + 2 mouse (two cursor, still need to find how to enable or make visible two cursors)
I did tried your 11.5 Gb vdesktop image on same card, but it was not booting for 8 minutes (first boot), i gave u trying
Botspot
Sat Aug 15, 2020 1:05 pm
I've noticed all the icons disappear in my testing. Think it's related to the icon cache or something. Usually, I just shutdown the vdesktop container and then restart it. It's rare enough that I've never had it happen twice on the same day, and because of that it's been a hard bug to track down.
If you get the missing-icon error more regularly than I do, then I have a couple things I'd like to try to fix it.
I don't know how well that would work, or if doing a multi-seat with Vdesktop would even be possible.
The first screen would be easy, just plug in a mouse & keyboard like usual and there you go. The second screen (vdesktop) would be more difficult. Somehow, you'd have to plug in a second mouse & keyboard, and somehow make the host system ignore their existence.
If you could manage that, then it would be comparatively easy to mount those devices to the vdesktop machine by adding some lines to the vdesktop/nspawn file.
Oh boy. I've been meaning to remove that from the Vdesktop README since I do not maintain it. Thanks for the reminder as I removed it just now.
Over 50,000 users!
neal1
Sat Aug 15, 2020 4:28 pm
Missing icon is repetitive in my installation, snapshots i took today, after rebooting 2 times.
Also Wifi still not connecting
For multiple cursor i will try https://wiki.archlinux.org/index.php/Multi-pointer_X or https://wiki.ubuntu.com/X/MPX
https://manpages.debian.org/testing/gro ... .1.en.html
Though i am still learning to make this work.
I am planning to use Monitor extend capability to mimic multiseat setup
Once Vdesktop is boots i will move image to other monitor and multi pointer will control other keyboard and mouse
Botspot
Sat Aug 15, 2020 6:35 pm
Find the vdesktop folder. By default, the vdesktop folder is at /home/pi/vdesktop, or if you're using it within Pi Power Tools, it's in /home/pi/Pi-Power-Tools/vdesktop.
BTW, are you using Pi Power Tools to launch vdesktop? If so, you may prefer running vdesktop separately as shown in the README.
Anyway, once you find the folder, locate the file vdesktop/profile.
Open the file with a text editor.
Currently the last few lines should look like this:
export DISPLAY=:1
eval "while true;do
  /usr/bin/startlxde-pi
  sleep 10
done" &
sleep 10
eval "pcmanfm --desktop --profile LXDE-pi; sleep 20; pcmanfm --desktop --profile LXDE-pi" &
lxpanelctl restart
sleep 10
lxpanelctl restart
Change that to:
export DISPLAY=:1
eval "while true;do
  sleep 10
done" &
sudo gtk-update-icon-cache /usr/share/icons/*
sleep 10
lxpanelctl restart
sleep 10
lxpanelctl restart
Save the file and close the text editor. Next time you run vdesktop, please tell me if the problem is solved.
Let's figure out what's going on. You can't trust the WiFi indicator on the panel, because it's not meant to detect systemd-nspawn's form of internet tunneling. Also, you can't trust the browser, since it's a known issue that it always crashes on every website.
To see if the guest is getting any internet, in a in-guest terminal, run this:
ping google.com
Do you see messages back saying stuff like "64 bytes from dfw28s02-in-x0e.1e100.net", or do you get "ping: sendmsg: Network is unreachable"?
That's new to me. I'm afraid I won't be of much help, and won't know which /dev/ devices will need to be mounted to the guest to make it work.
Over 50,000 users!
neal1
Sun Aug 16, 2020 4:08 am
Your fix, didn;t solved issue.
Like always icons appears for first 2 or 3 seconds, then disappear.
You were right about internet, in terminal ping google.com responded.
Can you find a fix why all websites are crashing on chrome (but in strange way all local host addresses works perfectly)
Botspot
Sun Aug 16, 2020 7:57 pm
Your fix, didn't solved issue.
OK, try this: when the guest boots, open a terminal and type openbox --restart. (and press Enter of course)
If that doesn't work, then enter all these commands:
sudo update-icon-caches /usr/share/icons/*
lxpanelctl restart
openbox --restart
killall pcmanfm lxpanel
pcmanfm --desktop --profile LXDE-pi &>/dev/null &
lxpanel --profile LXDE-pi &
I've been trying to fix the Aw Snap error for a year now. Not made any progress, except noticing that the problem doesn't affect the Pi 3 for some reason. Also I've noticed that simple text-based websites load and display just fine. Like this one, even the videos.
What kind of websites displayed fine on local host for you? Only real simple sites without CSS or javascript?
Over 50,000 users!
mtlynch
Sun Aug 16, 2020 9:29 pm
This is great! I'm excited about this project. I seem to be running into a crash:
  • Run Pi Power Tools
  • Click IMG Mode
  • Click Download New
  • Click Raspberry Pi OS Lite
  • Click Download
Expected: Pi Power Tools downloads the IMG.
Actual: Pi Power Tools abruptly closes with no additional information
Turn your Raspberry Pi into a KVM over IP with TinyPilot.
https://tinypilotkvm.com
Botspot
Sun Aug 16, 2020 9:41 pm
Thanks! I've put a lot of work into it, and it's nice to see others find it useful.
Do you have a Github account? If you do, it would keep this thread cleaner if you post your issue on my github page.
Still though, no big deal - I can help solve your issue here.
  • Click Download
How long did you wait afterwards? Before the next window can open, PPT has to do a bunch of calculations first. Sometimes it can take a few seconds before you see anything further.
If you did wait and nothing ever showed up, then please run this command in the terminal:
/home/pi/Pi-Power-Tools/img-mode
Click the same buttons as last time, and if the terminal shows any errors then please post them.
Over 50,000 users!
mtlynch
Sun Aug 16, 2020 9:45 pm
Oh, sure. I actually prefer Github but the terminal message directs users to post in this thread. I'll move to Github.
neal1
Fri Aug 21, 2020 2:11 pm
lxpanelctl restart
openbox --restart
Tested, It worked It worked, but didn;t completely solved the issue
1st step didn't did anything
Second brought back icons
Third made them disappear again
and last command brought back all icons.
When when i boot image again icons disappeared again, and i needed to use same accomand to bring icons back.
pi@raspberrypi:~ $ sudo update-icon-caches /usr/share/icons/*
pi@raspberrypi:~ $ lxpanelctl restart
pi@raspberrypi:~ $ openbox --restart
pi@raspberrypi:~ $ killall pcmanfm lxpanel
pi@raspberrypi:~ $ pcmanfm --desktop --profile LXDE-pi &>/dev/null &
[1] 800
pi@raspberrypi:~ $ lxpanel --profile LXDE-pi &
[2] 810
pi@raspberrypi:~ $ ** Message: 19:35:53.375: x-terminal-emulator has very limited support, consider choose another terminal
grep: /home/pi/.config/lxpanel/LXDE-pi/panels/*: No such file or directory
** Message: 19:35:53.669: Connecting ...
** Message: 19:35:53.670: Status changed to down
xrandr: Failed to get size of gamma for output default
Unit pt-device-manager.service could not be found.
** (lxpanel:810): WARNING **: 19:35:53.799: Battery 0 not found
(lxpanel:810): GLib-GObject-WARNING **: 19:35:53.803: invalid (NULL) pointer instance
(lxpanel:810): GLib-GObject-CRITICAL **: 19:35:53.803: g_signal_handler_disconnect: assertion 'G_TYPE_CHECK_INSTANCE (instance)' failed
(lxpanel:810): GLib-GObject-CRITICAL **: 19:35:53.803: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
rfkill: cannot open /dev/rfkill: No such file or directory
rfkill: cannot read /dev/rfkill: Bad file descriptor
(lxpanel:810): Gtk-CRITICAL **: 19:35:53.974: IA__gtk_image_set_from_pixbuf: assertion 'GTK_IS_IMAGE (image)' failed
** Message: 19:35:54.672: Status changed to opened
** Message: 19:35:54.672: Connected to dhcpcd-8.1.2
** Message: 19:35:54.673: Status changed to initialised
I can run webmin installed on my pi, but i need to run other websites too.
Botspot
Fri Aug 21, 2020 4:23 pm
I've been trying to fix that aw snap error for over a year. So far no leads unfortunately. If you need it to work, use a Pi3. (*because for some reason this doesn't happen on a Pi3)
Over 50,000 users!
neal1
Fri Aug 21, 2020 4:36 pm
check if it gives some hint to Aw snap error of chrome
pi@raspberrypi:~ $ sudo apt install firefox-esr
Reading package lists... Done
Building dependency tree
The following additional packages will be installed:
libjsoncpp1
Suggested packages:
fonts-stix | otf-stix fonts-lmodern pulseaudio
The following NEW packages will be installed:
firefox-esr libjsoncpp1
0 upgraded, 2 newly installed, 0 to remove and 0 not upgraded.
Need to get 41.3 MB of archives.
After this operation, 161 MB of additional disk space will be used.
E: You don't have enough free space in /var/cache/apt/archives/.
there seems some cache or memory problem, i think somehow vddesktop is running out of memory while trying running chrome.
I faced siilar issue when i used chrome on windows 10 with 4 gb RAM, once several excel and word files were open, all chrome tabs were giving Aw snap error
Botspot
Fri Aug 21, 2020 4:39 pm
That error is because the img has run out of free space. It's similar to a full hard drive.
You can expand it by clicking the 1GB Free button in PPT.
Over 50,000 users!
Botspot
Wed Oct 07, 2020 4:13 pm
Update:
I've found someone who seems to have gotten Chromium working within Vdesktop! (with full OpenGL support no less)
I have yet to get it working on any of my Pies though, so we'll see what happens.
If anyone here would like to monitor our progress or give suggestions, go see: https://github.com/Botspot/vdesktop/issues/3
Over 50,000 users!
Botspot
Thu Oct 15, 2020 2:35 am
Another update: I have released a beta version of Vdesktop that fixes all the "Aw, Snap!" errors!
Chromium no longer crashes, and even better: the VM has full access to OpenGL.
Now you can play Youtube from within vdesktop using Chromium! Now how wacky is that? ;)
Before I can add this new version to the repositories, I need feedback! Bug reports? Suggestions?
My announcement topic is here, and you can download this special release of vdesktop here.
Over 50,000 users!
RaspbianUser1
Mon Oct 19, 2020 8:36 pm
Hi Botspot
I have recently updated your tool and vdesktop actually does something for me
Because I am using MATE its not running LXDE which vdesktop is trying to run
I can fix this slightly by running
sudo lightdm | mate-session
But this really isn't good as the resolution is terrible
I think it would work perfectly fine if I was normal and used standard LXDE desktop
Also my installed desktop is broken and fixed with tape and glue
(to use wifi I have to run
sudo systemctl start wpa_supplicant.service
I will give you a further update on your tools when I am next using my standard raspberry pi install.
Overall the tools look very handy.
Maybe mention in the readme.md file that it is unstable on other desktop environments / OS
vdesktop for me has to be run in terminal so I can do things, but its working but using the desktop environment as it can't find /usr/bin/LXDE
vdesktop still allows me to run command so it doesn't matter :)
Running either Raspberry Pi OS desktop Full or Raspberry Pi OS MATE desktop
Overclocked at 2200MHz CPU and 700 MHz GPU with a over voltage of 7
Think before you delete something a stranger on the internet told you to.
Botspot
Mon Oct 19, 2020 8:46 pm
Hi Botspot
Are you using my vdesktop beta version? It may work better in your situation.
And, are you saying: "vdesktop does not work at all because my host system is mate", or are you saying "vdesktop does not properly display the VM's mate desktop"?
Over 50,000 users!
RaspbianUser1
Mon Oct 19, 2020 9:03 pm
Hi Botspot
Option 2.
Its because the vm img doesn't have the LXDE installed which vdesktop is asking for when run
-bash: /usr/bin/startlxde-pi: No such file or directory
Cant connect to display: :1
Cannot open display:
it does this 3 times then gives up trying to show a gui de and instead just gives me CLI access to the VM
Botspot
Mon Oct 19, 2020 9:31 pm
Once again: are you using my vdesktop beta version?
And what command do you have to run for this mate desktop to launch?
Also, does running x-terminal-emulator launch a terminal on your system? Or do you get "command not found"?
Over 50,000 users!
Return to “Advanced users”
