rjalex
Webmin showing CPU and GPU temps anyone?
Fri Jan 31, 2020 5:23 pm
I have Webmin running on a Raspbian lite Buster OS.
Is there a way to get the CPU and GPU temps shown on Webmin's dashboard?
This is what I use on the commandline:
for the CPU
awk '{printf("\nrPI Temperature = %.1f °C\n\n",$1/1e3)}' /sys/class/thermal/thermal_zone0/temp
output -> rPI Temperature = 45.3 °C
for the GPU
vcgencmd measure_temp
output -> temp=43.0'C
Is there a way to integrate them into Webmin's dashboard?
andi29
Re: Webmin showing CPU and GPU temps anyone?
Fri May 22, 2020 4:52 pm
Hey there,
is any posibility to add CPU temp to webmin dashboard. Has anybody add it successfull?
LTolledo
Sun May 24, 2020 12:32 am
wow, a 7-year necro..... :o
have not used webmin on the RPi servers lately
RPiMonitor probably might be better
Some people be like:
FTrevorGowen
Sun May 24, 2020 8:19 am
Or possibly try glances (in its "server" mode):
GLANCES(1)                          Glances                         GLANCES(1)
>>>>>>> master
NAME
       glances - An eye on your system
SYNOPSIS
       glances [OPTIONS]
DESCRIPTION
       glances  is a cross-platform curses-based monitoring tool which aims to
       present a maximum of information in a minimum of space, ideally to  fit
       in a classical 80x24 terminal or higher to have additional information.
       It can adapt dynamically the displayed  information  depending  on  the
       terminal size. It can also work in client/server mode.  Remote monitor‐
       ing could be done via terminal or web interface.
       glances is written in Python and uses the psutil library to get  infor‐
       mation from your system.
Trev.
Return to “Advanced users”
