neuberfran
rpi3 B rev:1.2. I change ic LAN9514 - Pin 50 is with difference measurement
Tue Jan 21, 2020 8:11 pm
https://www.raspberrypi.org/forums/view ... p?t=241842
PIN 50 is measuring 0.000v in defective rpi 3 and measuring 1.272v in 2 other rpi 3 that are working ok (usb and ethernet ports)
My question is: According to the pdf below: 1. EXRES (pin 50) on the LAN9514 QFN should connect to digital ground through a 12.4K resistor with a tolerance of 1.0%. This pin is used to set-up critical bias currents for the
embedded 10/100 Ethernet Physical device.
http://ww1.microchip.com/downloads/en/D ... cklist.pdf
Where is the 12.4K resistor with a tolerance of 1.0% in the board?
Return to “Advanced users”
