JosephPranu
Failed to start Bluetooth service
Tue Jan 21, 2020 6:12 am
Could someone help me rectify this error??
[email protected]:~ $ sudo service bluetooth status
● bluetooth.service - Bluetooth service
   Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled; vendor preset
   Active: failed (Result: exit-code) since Tue 2020-01-21 05:47:23 GMT; 42s ago
     Docs: man:bluetoothd(8)
  Process: 932 ExecStart=/usr/lib/bluetooth/bluetoothd --nonplugin=sap (code=exi
 Main PID: 932 (code=exited, status=1/FAILURE)
Jan 21 05:47:23 raspberrypi systemd[1]: Starting Bluetooth service...
Jan 21 05:47:23 raspberrypi bluetoothd[932]: Unknown option --nonplugin=sap
Jan 21 05:47:23 raspberrypi systemd[1]: bluetooth.service: Main process exited,
Jan 21 05:47:23 raspberrypi systemd[1]: bluetooth.service: Failed with result 'e
Jan 21 05:47:23 raspberrypi systemd[1]: Failed to start Bluetooth service.
LOUx2
Re: Failed to start Bluetooth service
Tue Jan 21, 2020 10:25 am
Your issue is a typo in the file /lib/systemd/system/bluetooth.service.
Edit it and replace "--nonplugin=sap" with "--noplugin=sap".
Regards.
JosephPranu
Tue Jan 21, 2020 2:37 pm
Thanks for the fast reply.
When I try to edit and replace "--nonplugin=sap" with "--noplugin=sap", the following error pops up.
"Error saving file", "Too many levels of symbolic links", "The file on the disk may be truncated"
WhatsApp Image 2020-01-21 at 7.59.48 PM.jpeg (96.32 KiB) Viewed 277 times
Tue Jan 21, 2020 2:55 pm
You need to be root to update that file.
Open an LXTerminal and run sudo leafpad.
This is a doctor free zone.
JosephPranu
Tue Jan 21, 2020 6:48 pm
Thanks!! Now my Bluetooth is on and running.
But, now it shows "Failed to set privacy: Rejected"
   Active: active (running) since Tue 2020-01-21 17:30:49 GMT; 4min 57s ago
 Main PID: 601 (bluetoothd)
   Status: "Running"
    Tasks: 1 (limit: 4915)
   Memory: 2.2M
   CGroup: /system.slice/bluetooth.service
           └─601 /usr/lib/bluetooth/bluetoothd --noplugin=sap
Jan 21 17:30:49 raspberrypi systemd[1]: Starting Bluetooth service...
Jan 21 17:30:49 raspberrypi bluetoothd[601]: Bluetooth daemon 5.50
Jan 21 17:30:49 raspberrypi systemd[1]: Started Bluetooth service.
Jan 21 17:30:49 raspberrypi bluetoothd[601]: Starting SDP server
Jan 21 17:30:49 raspberrypi bluetoothd[601]: Excluding (cli) sap
Jan 21 17:30:49 raspberrypi bluetoothd[601]: Bluetooth management interface 1.14
Jan 21 17:30:49 raspberrypi bluetoothd[601]: Failed to set privacy: Rejected (0x
Tue Jan 21, 2020 6:52 pm
Try using Google for your error messages. You won't be disappointed.
Return to “Advanced users”
