jb63
How to Differentiate RPI4 - 1 vs. 2 vs. 4 GB ?
Sat Jan 11, 2020 1:34 am
I bought few RPI 4's ... but after opening them (and mixing them) I can't differentiate the 1GB from the 4GB ... any clue?
There are a couple of Youtube movies, but they talk about production date, which to me is not very 'reliable'
trejan
Re: How to Differentiate RPI4 - 1 vs. 2 vs. 4 GB ?
Sat Jan 11, 2020 1:53 am
Look at the revision code in /proc/cpuinfo or run "free -h". Some of the memory will be used by the GPU so you'll get something around 3.7GB even though it is a 4GB Pi 4.
You can look at the part number of the memory chip but we don't have a full list so it isn't exhaustive.
4GB: Micron D9WHV or Samsung 4HMMGCJ
2GB: Micron D9WHZ
1GB: Samsung 4HBMGCJ
andrum99
Sat Jan 11, 2020 10:03 pm
There are a couple of Youtube movies, but they talk about production data, which to me is not very 'reliable'
Easy - boot them, find out which is which, then put a sticker on them. You might also be able to figure out the memory size from what is printed on the top of it.
HermannSW
Sat Jan 11, 2020 11:54 pm
This expression results in 1, 2 or 4:
$ echo $((`grep -i MemTotal /proc/meminfo | cut -f1 -dk | cut -f2 -d:` / (1024*1024) + 1))
4
⇨https://stamm-wilbrandt.de/en/Raspberry_camera.html
https://stamm-wilbrandt.de/github_repo_i420toh264
https://github.com/Hermann-SW/fork-raspiraw
https://twitter.com/HermannSW
cjan
Sun Jan 12, 2020 12:45 am
weigh its weight.
Imperf3kt
Sun Jan 12, 2020 1:14 am
I simply boot them and type top.
This tells me what model I gave via the total ram capacity.
I really should put a sticker or some other identifying mark on them (like maybe a silkscreen)
55:55:44:44:4C
52:4C:52:42:41
klricks
Sun Jan 12, 2020 1:29 am
I set my hostname to something like: RPi4B4G
GlowInTheDark
Sun Jan 12, 2020 1:45 am
It's pretty obvious that it is trivial to tell them apart from software. I.e., once you're booted up.
I think it's pretty obvious the point of the thread is how can you tell just by looking at it. I.e., w/o powering it up.
And it sounds like the answer is: You can't.
GitD's list of things that are not ready for prime time:
1) IPv6
2) 64 bit OSes
3) USB 3
4) Bluetooth
trejan
Sun Jan 12, 2020 1:56 am
You look at the part number written on the RAM...
GlowInTheDark
Sun Jan 12, 2020 2:05 am
There you go. I thought there was probably a way.
1) IPv6
2) 64 bit OSes
3) USB 3
4) Bluetooth
PeterO
Sun Jan 12, 2020 7:24 am
As detailed in the second post in THIS thread ! :roll:
PeterO
buja
Sun Jan 12, 2020 8:00 am
A bit stupid really that RAM size is not printed on the board, it's useful information and there is plenty of space for it.
The markings on the memory chip are hard to read and just a code, no indication of the size (unless you look up the type of course).
PeterO
Sun Jan 12, 2020 8:36 am
I expect that maintaining and making three versions of the board (even if the only difference is the screen print) would cost more.
PeterO
Sun Jan 12, 2020 10:51 am
PeterO
Exactly right. And also a recipe for confusion. Make production process more complicated, and if production gets it wrong you have a load of mislabelled boards.
Always worth remembering that we spend a lot of time thinking about stuff. If you think something could be done better, we have almost certainly thought about it already, and decided not to do it for some reason; might be production complexity, might be cost, might be technically unfeasible. The amount of work that goes in to taking a design to production is extraordinary. Which is why so many kickstarters fail, they do not realise the complexities involved.
jb63
Sun Jan 12, 2020 2:19 pm
Thank you all. Like one user answered above, I'm primarily after ways to identifying them from just looking at the (non-connected) hardware. I'll boot them up both and simply attach a small sticker.
Thanks.
bls
Contact: Twitter
Sun Jan 12, 2020 3:06 pm
4
Slick!
GlowInTheDark
Sun Jan 12, 2020 5:10 pm
I wouldn't exactly say "slick". Whenever you see multiple invocations of what I call the "basic Unix tools" (things like cat, grep, cut, sed, join, comm, etc), you know that somebody just kinda cobbled it together on the command line without any real design.
Anyway, ...
mawk '/MemTotal/ { print "Memory size in Gb:",int($2/(1024*1024)) + 1 }' /proc/meminfo
Same basic algorithm. Should work with any version of AWK (note that "mawk" is the default AWK in Debian systems, including Raspbian).
1) IPv6
2) 64 bit OSes
3) USB 3
4) Bluetooth
PeterO
Sun Jan 12, 2020 5:24 pm
Anyway, ...
But for a command you are going to run once ...... does it matter ?
PeterO
bls
Contact: Twitter
Sun Jan 12, 2020 5:28 pm
Anyway, ...
It’s one line. It does the job. Perhaps you didn’t have your coffee this morning? :lol:
Also...your updated version is slick also! ;) ;)
HermannSW
Sun Jan 12, 2020 6:19 pm
That is what the basic *nix tools are made for, and for basic tasks like determining memory size OK in my eyes.
Anyway, ...
awk is for me a level above "basic *nix tools", and you are right that because of its pattern matching power is preferable for this task.
But adding all the text makes its result harder to use for other tools.
So I prefer this minimal length code living inside your code:
$ awk '/MemTotal/{print int($2/(2^20))+1}' /proc/meminfo
4
GlowInTheDark
Sun Jan 12, 2020 6:26 pm
Heh heh...
Well, it obviously matters to me, since I took the time to post.
So, the operative question is: Does it matter to you?
And, the answer is that it seems it does, since you took the time to post.
1) IPv6
2) 64 bit OSes
3) USB 3
4) Bluetooth
PeterO
Sun Jan 12, 2020 7:25 pm
Heh heh...
What matters to me is not "is it perfect?" but "does it do the job?".
PeterO
Imperf3kt
Sun Jan 12, 2020 8:49 pm
Sorry, but I don't buy this.
You still print three different versions of the box the device comes in... What if production puts them in the wrong box? You've got a bunch of mislabelled Pi (and substantially more problematic than a misprinted silkscreen)
55:55:44:44:4C
52:4C:52:42:41
PeterO
Sun Jan 12, 2020 9:18 pm
Ask yourself "Which of the two is easier to correct ?"
PeterO
Imperf3kt
Sun Jan 12, 2020 9:23 pm
PeterO
The misprinted silkscreen?
People will get the correct Pi they ordered, but with some incorrect and unimportant words written on it.
If you get the box wrong, and you've shipped people who bought a Pi4 4GB, a 2GB model, you need to determine which batch was in the wrong boxes, where those boxes went, recall them, hope they aren't mixed with millions of other identical boxes in a warehouse etc...
My point is that the chance of a Pi receiving a misprinted silkscreen, is the same as a Pi ending up on the wrong box and being sold as a Pi model it isn't, so I don't really see any reason not to do it based on that particular reasoning.
55:55:44:44:4C
52:4C:52:42:41
Return to “Advanced users”
