dariuszb
Re: Encrypted swap crashes all system
Thu Oct 17, 2019 11:31 am
jamesh wrote:
Thu Oct 17, 2019 11:21 am
sudo cryptdisks_start cryptswap
Is there a problem with using ext4 (or vfat)?
[warn] Starting crypto disk...cryptswap (starting)...[....] cryptswap: the precheck for '/dev/mmcblk0p2' failed: - The device /dev/mmcblk0p2 contains a filesystem type ext4. ... (warning).
failed.
I am talking about encrypting swap partition not ext4.
if /dev/mmcblk0p2 is indeed partition you intend to use (all data will be deleted) run before
sudo mkswap /dev/mmcblk0p2
at this stage you can enable it as not encrypted swap:
sudo swapon /dev/mmcblk0p2
and see that
stress -m 2  --vm-bytes 500M
works
then you can disable it
sudo swapoff -a
and try encryption
Thu Oct 17, 2019 11:54 am
Ah, OK, so encrypting an entire partition, not just a swap file. My mistake. Sounds like a load of effort to go to for very little benefit.
Kendek
Thu Oct 17, 2019 12:00 pm
You can try it with a SWAP file, I've just described the steps. It's a minute, including the stability test, just a little effort. :)
Thu Oct 17, 2019 12:03 pm
Have you tried ditching the swapfile and creating a TYPE82 swap parition? Then encrypting that.
I'll do your homework for you for a suitable fee.
Thu Oct 17, 2019 12:19 pm
OK, will do that.
Thu Oct 17, 2019 12:56 pm
So, got some sort of kernel crash dump via serial console, not yet sure what it all means.
[  143.156303] swapper/0: page allocation failure: order:0, mode:0x480020(GFP_ATOMIC), nodemask=(null)
[  143.156310] swapper/0 cpuset=/ mems_allowed=0
[  143.156324] CPU: 0 PID: 0 Comm: swapper/0 Tainted: G         C        4.19.75-v7l+ #1270
[  143.156327] Hardware name: BCM2835
[  143.156349] [<c0212d10>] (unwind_backtrace) from [<c020d530>] (show_stack+0x20/0x24)
[  143.156359] [<c020d530>] (show_stack) from [<c097fb20>] (dump_stack+0xd4/0x118)
[  143.156367] [<c097fb20>] (dump_stack) from [<c0344638>] (warn_alloc+0xcc/0x170)
[  143.156376] [<c0344638>] (warn_alloc) from [<c03457dc>] (__alloc_pages_nodemask+0x104c/0x1180)
[  143.156382] [<c03457dc>] (__alloc_pages_nodemask) from [<c0345b00>] (page_frag_alloc+0x14c/0x160)
[  143.156391] [<c0345b00>] (page_frag_alloc) from [<c0854d44>] (__netdev_alloc_skb+0xb4/0x158)
[  143.156403] [<c0854d44>] (__netdev_alloc_skb) from [<c073d1a4>] (bcmgenet_rx_refill+0x44/0x264)
[  143.156412] [<c073d1a4>] (bcmgenet_rx_refill) from [<c073d900>] (bcmgenet_rx_poll+0x254/0xa3c)
[  143.156419] [<c073d900>] (bcmgenet_rx_poll) from [<c086f890>] (net_rx_action+0x310/0x494)
[  143.156427] [<c086f890>] (net_rx_action) from [<c0202410>] (__do_softirq+0x190/0x3f0)
[  143.156435] [<c0202410>] (__do_softirq) from [<c0228308>] (irq_exit+0xfc/0x120)
[  143.156445] [<c0228308>] (irq_exit) from [<c0280e08>] (__handle_domain_irq+0x70/0xc4)
[  143.156453] [<c0280e08>] (__handle_domain_irq) from [<c0202244>] (gic_handle_irq+0x4c/0x88)
[  143.156459] [<c0202244>] (gic_handle_irq) from [<c02019bc>] (__irq_svc+0x5c/0x7c)
[  143.156463] Exception stack(0xc1001ed8 to 0xc1001f20)
[  143.156467] 1ec0:                                                       c0209a84 00000000
[  143.156472] 1ee0: 40000193 40000193 c1004dbc c1000000 c1004e04 00000001 c109641a c10a56c0
[  143.156477] 1f00: c0e67a38 c1001f34 c10051c4 c1001f28 00000000 c0209a88 40000113 ffffffff
[  143.156484] [<c02019bc>] (__irq_svc) from [<c0209a88>] (arch_cpu_idle+0x34/0x4c)
[  143.156491] [<c0209a88>] (arch_cpu_idle) from [<c099cd2c>] (default_idle_call+0x34/0x48)
[  143.156500] [<c099cd2c>] (default_idle_call) from [<c02542b4>] (do_idle+0xec/0x17c)
[  143.156509] [<c02542b4>] (do_idle) from [<c0254604>] (cpu_startup_entry+0x28/0x2c)
[  143.156516] [<c0254604>] (cpu_startup_entry) from [<c09963c0>] (rest_init+0xbc/0xc0)
[  143.156526] [<c09963c0>] (rest_init) from [<c0e00fe4>] (start_kernel+0x4b8/0x4e8)
[  143.156531] Mem-Info:
[  143.156539] active_anon:883724 inactive_anon:24732 isolated_anon:11
                active_file:17532 inactive_file:20998 isolated_file:37
                unevictable:4 dirty:0 writeback:73 unstable:0
                slab_reclaimable:4261 slab_unreclaimable:7671
                mapped:18022 shmem:12516 pagetables:2532 bounce:68
                free:7131 free_pcp:63 free_cma:5866
[  143.156547] Node 0 active_anon:3534896kB inactive_anon:98928kB active_file:70128kB inactive_file:83992kB unevictable:16kB isolated(anon):44kB isolated(file):148kB mapped:72088kB dirty:0kB writeback:292kB shmem:50064kB writeback_tmp:0kB unstable:0kB all_unreclaimable? no
[  143.156555] DMA free:28472kB min:16384kB low:20480kB high:24576kB active_anon:570980kB inactive_anon:0kB active_file:14824kB inactive_file:7100kB unevictable:0kB writepending:0kB present:786432kB managed:735740kB mlocked:0kB kernel_stack:1736kB pagetables:692kB bounce:272kB free_pcp:0kB local_pcp:0kB free_cma:23464kB
[  143.156558] lowmem_reserve[]: 0 0 3136 3136
[  143.156579] HighMem free:52kB min:512kB low:18388kB high:36264kB active_anon:2963500kB inactive_anon:98164kB active_file:56380kB inactive_file:77232kB unevictable:16kB writepending:292kB present:3211264kB managed:3211264kB mlocked:16kB kernel_stack:0kB pagetables:9436kB bounce:0kB free_pcp:252kB local_pcp:252kB free_cma:0kB
[  143.156581] lowmem_reserve[]: 0 0 0 0
[  143.156597] DMA: 188*4kB (UMEC) 46*8kB (UMEC) 32*16kB (UMEC) 18*32kB (UMEC) 10*64kB (UEC) 4*128kB (U) 0*256kB 2*512kB (EC) 0*1024kB 2*2048kB (EC) 5*4096kB (C) = 28960kB
[  143.156658] HighMem: 5*4kB (UM) 16*8kB (UM) 7*16kB (U) 1*32kB (M) 3*64kB (M) 1*128kB (M) 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 612kB
[  143.156709] 51199 total pagecache pages
[  143.156713] 115 pages in swap cache
[  143.156716] Swap cache stats: add 169, delete 54, find 0/0
[  143.156719] Free swap  = 625400kB
[  143.156722] Total swap = 626680kB
[  143.156725] 999424 pages RAM
[  143.156728] 802816 pages HighMem/MovableOnly
[  143.156731] 12673 pages reserved
[  143.156734] 65536 pages cma reserved
[  143.477671] swapper/0: page allocation failure: order:0, mode:0x480020(GFP_ATOMIC), nodemask=(null)
[  143.477677] swapper/0 cpuset=/ mems_allowed=0
[  143.477692] CPU: 0 PID: 0 Comm: swapper/0 Tainted: G         C        4.19.75-v7l+ #1270
[  143.477695] Hardware name: BCM2835
[  143.477716] [<c0212d10>] (unwind_backtrace) from [<c020d530>] (show_stack+0x20/0x24)
[  143.477727] [<c020d530>] (show_stack) from [<c097fb20>] (dump_stack+0xd4/0x118)
[  143.477736] [<c097fb20>] (dump_stack) from [<c0344638>] (warn_alloc+0xcc/0x170)
[  143.477745] [<c0344638>] (warn_alloc) from [<c03457dc>] (__alloc_pages_nodemask+0x104c/0x1180)
[  143.477751] [<c03457dc>] (__alloc_pages_nodemask) from [<c0345b00>] (page_frag_alloc+0x14c/0x160)
[  143.477760] [<c0345b00>] (page_frag_alloc) from [<c0854d44>] (__netdev_alloc_skb+0xb4/0x158)
[  143.477771] [<c0854d44>] (__netdev_alloc_skb) from [<c073d1a4>] (bcmgenet_rx_refill+0x44/0x264)
[  143.477780] [<c073d1a4>] (bcmgenet_rx_refill) from [<c073d900>] (bcmgenet_rx_poll+0x254/0xa3c)
[  143.477787] [<c073d900>] (bcmgenet_rx_poll) from [<c086f890>] (net_rx_action+0x310/0x494)
[  143.477795] [<c086f890>] (net_rx_action) from [<c0202410>] (__do_softirq+0x190/0x3f0)
[  143.477804] [<c0202410>] (__do_softirq) from [<c0228308>] (irq_exit+0xfc/0x120)
[  143.477814] [<c0228308>] (irq_exit) from [<c0280e08>] (__handle_domain_irq+0x70/0xc4)
[  143.477822] [<c0280e08>] (__handle_domain_irq) from [<c0202244>] (gic_handle_irq+0x4c/0x88)
[  143.477828] [<c0202244>] (gic_handle_irq) from [<c02019bc>] (__irq_svc+0x5c/0x7c)
[  143.477832] Exception stack(0xc1001ed8 to 0xc1001f20)
[  143.477836] 1ec0:                                                       c0209a84 00000000
[  143.477841] 1ee0: 40000193 40000193 c1004dbc c1000000 c1004e04 00000001 c109641a c10a56c0
[  143.477846] 1f00: c0e67a38 c1001f34 c10051c4 c1001f28 00000000 c0209a88 40000113 ffffffff
[  143.477853] [<c02019bc>] (__irq_svc) from [<c0209a88>] (arch_cpu_idle+0x34/0x4c)
[  143.477860] [<c0209a88>] (arch_cpu_idle) from [<c099cd2c>] (default_idle_call+0x34/0x48)
[  143.477869] [<c099cd2c>] (default_idle_call) from [<c02542b4>] (do_idle+0xec/0x17c)
[  143.477877] [<c02542b4>] (do_idle) from [<c0254604>] (cpu_startup_entry+0x28/0x2c)
[  143.477884] [<c0254604>] (cpu_startup_entry) from [<c09963c0>] (rest_init+0xbc/0xc0)
[  143.477894] [<c09963c0>] (rest_init) from [<c0e00fe4>] (start_kernel+0x4b8/0x4e8)
dariuszb
Thu Oct 17, 2019 1:11 pm
I have tried it. Actually this is the main purpose of my original post. For some mysterious reasons encrypted swap files do not work even when I try on latest Debian on desktop. Partitions do but not on raspbian.
Return to “Advanced users”
