timothyy
Headless RasPi running Python script
Mon Sep 23, 2019 5:05 pm
I have a headless Raspberry 3 which i am planning to put in a exhibition for 2 months. So, how to tell the headless Raspberry Pi to run a python script that i wrote at the beginning and keep it running without stopping for 2 months (yes, no monitor)?
Timothy
pcmanbob
Re: Headless RasPi running Python script
Mon Sep 23, 2019 5:22 pm
Seeing as its headless I guess there is no output to a display required so you could just use cron to run your python program at boot .
so using the command
crontab -e
at the command line
add this line to the end of the displayed lines
@reboot python3 /home/pi/myprogram.py
this assumes you program is running using python 3, the program is saved in the /home/pi directory and the file is called myprogram.py,
you can change any of those if you need to use another directory or a different file name.
Kendek
Mon Sep 23, 2019 5:25 pm
/etc/rc.local
while : ; do script.py ; done &
So the script will be restarted immediately even if exited unexpectedly.
jbudd
Mon Sep 23, 2019 6:26 pm
You can set up a systemd service so that it automatically restarts.
Do you have any way to verify that the pi itself stays alive unattended, eg the hardware watchdog, sending occasional "I'm still alive" messages etc.?
timothyy
Fri Sep 27, 2019 1:45 pm
Hi, i also got a writetotxtfile("something","text1.txt"), everytime i reboot it the data doesn't write to the textfile. Any help?
B.Goode
Fri Sep 27, 2019 2:43 pm
In which directory(ies) are you looking for "text1.txt" ?
Hint: it probably will not be written in the Home directory for the default pi user.
timothyy
Fri Sep 27, 2019 2:45 pm
/home/pi/Desktop/Testing/text1.txt
B.Goode
Fri Sep 27, 2019 2:48 pm
"Hint: it probably will not be written in the Home directory for the default pi user."
pcmanbob
Fri Sep 27, 2019 2:53 pm
So how is the program writing to this text1.txt , is it accessing the file from within the proram or are you redirecting output from the file when you all it ?
How are you calling the file on boot.?
timothyy
Fri Sep 27, 2019 2:56 pm
def writetotxtfile(texttowrite,filename):
    file = open(str(filename), 'a')
    file.write(str(datetime.datetime.now()) + " " + str(texttowrite) + '\n')
    file.close()
I call the file on boot is /home/pi/Desktop/Testing/Text1.txt
B.Goode
Fri Sep 27, 2019 3:03 pm
    file.close()
That will work as you expect if you run the script while you are the default pi user and /home/pi/Desktop/Testing/ is your Current Working Directory.
(Apart from the issue of the difference in case between text1 and Text1.)
But for a script started during the system start-up process neither of these things is the case.
Have a think about which user runs the system startup, and where its default filestore is kept...
pcmanbob
Fri Sep 27, 2019 3:05 pm
Yes but how are you calling the file on boot ?
are you using cron, rc.local or some other way.
which you use affect the environment in which you file is run, and were the output is sent.
your filename variable probable needs to have the full path in it as well as the file name, so the file goes to the directory you want.
timothyy
Fri Sep 27, 2019 3:08 pm
i typed this at the end of the command
@reboot sudo python /home/pi/Desktop/Testing/Testing.py
B.Goode
Fri Sep 27, 2019 3:22 pm
writetotxtfile("something","/home/pi/Desktop/Testing/Text1.txt")
pcmanbob
Fri Sep 27, 2019 3:31 pm
Do you really need to call this program with sudo ?
jbudd
Fri Sep 27, 2019 5:32 pm
Does the directory /home/pi/Desktop/Testing with a capital T exist?
What does ls -l /home/pi/Desktop/Testing show you?
Return to “Advanced users”
