mitu
Re: Pi4 64-bit raspbian kernel for testing - Focus on Pi4
Thu Jun 04, 2020 6:32 pm
Both kernels (4.19.x and 5.4.x) have changed how the on-board sound module is loaded (snd_bcm2835), resulting in a sightly different ALSA configuration. Use raspi-config to configure your sound output and it should work afterwards.
mahjongg
Fri Jun 05, 2020 8:13 am
please post any further feedback about PiOS64 in the sticky here: viewtopic.php?f=63&t=275372
now locking this thread, so there will be just one thread for developers to follow.
dom
Re: Pi4 64-bit raspbian kernel for testing - Focus on Pi4 [now defunct thread]
Fri Jun 05, 2020 10:05 am
Unlocking as this thread is still useful for reporting issues with the 64-bit kernel unrelated to PiOS64.
The users here are mostly running a 32-bit buster image with just the kernel updated to 64-bit and it's
useful to note regressions when switching between 32 and 64-bit kernels. (Something not possible on PiOS64).
mahjongg
Fri Jun 05, 2020 1:02 pm
agreed, I was already wondering if that would be the case.... :mrgreen:
dickon
Fri Jun 05, 2020 5:45 pm
Possibly, like this one...
Pi 4, 2G:
arm_64bit=1
gpu_mem=256
dtoverlay=vc4-fkms-v3d
omxplayer, as root, playing H.264:
pi4 login: [  352.850885] Unable to handle kernel paging request at virtual address ffffff7fb0170e40
[  352.858976] Mem abort info:
[  352.861815]   ESR = 0x96000144
[  352.864936]   EC = 0x25: DABT (current EL), IL = 32 bits
[  352.870354]   SET = 0, FnV = 0
[  352.873459]   EA = 0, S1PTW = 0
[  352.876665] Data abort info:
[  352.879606]   ISV = 0, ISS = 0x00000144
[  352.883520]   CM = 1, WnR = 1
[  352.886548] [ffffff7fb0170e40] address between user and kernel address ranges
[  352.893822] Internal error: Oops: 96000144 [#1] PREEMPT SMP
[  352.899490] Modules linked in: aes_neon_blk crypto_simd cryptd bnep rpcsec_gss_krb5 evdev v3d gpu_sched raspberrypi_hwmon vc4 cec bcm2835_v4l2(C) videobuf2_vmalloc bcm2835_isp(C) drm_kms_helper drm drm_panel_orientation_quirks w1_gpio snd_soc_core snd_compress snd_pcm_dmaengine syscopyarea sysfillrect sysimgblt fb_sys_fops uio_pdrv_genirq uio rpivid_mem snd_bcm2835(C) snd_pcm snd_timer binfmt_misc snd bcm2835_codec(C) videobuf2_dma_contig v4l2_mem2mem bcm2835_mmal_vchiq(C)  videobuf2_memops videobuf2_v4l2 videobuf2_common videodev mc brcmfmac brcmutil sha256_generic libsha256 cfg80211 8021q garp hci_uart btbcm serdev bluetooth ecdh_generic ecc rfkill vc_sm_cma(C) w1_therm wire cn ip_tables x_tables bridge stp llc ipv6 nf_defrag_ipv6
[  352.965494] CPU: 2 PID: 85 Comm: vchiq-slot/0 Tainted: G         C        5.4.44-v8+ #1320
[  352.973899] Hardware name: Raspberry Pi 4 Model B Rev 1.1 (DT)
[  352.979827] pstate: 00000005 (nzcv daif -PAN -UAO)
[  352.984704] pc : __dma_inv_area+0x28/0x58
[  352.988777] lr : arch_sync_dma_for_cpu+0x3c/0x50
[  352.993467] sp : ffffffc011c63bd0
[  352.996832] x29: ffffffc011c63bd0 x28: ffffffc010eff130
[  353.002230] x27: ffffff807b551c00 x26: ffffffc0112d3000
[  353.007628] x25: ffffffc0112d300c x24: 0000000000000002
[  353.013027] x23: 0000000000000002 x22: 000000000000021c
[  353.018424] x21: 0000000000000002 x20: 000000000000021c
[  353.023823] x19: ffffffffb0170c60 x18: 0000000000000000
[  353.029221] x17: 0000000000000000 x16: 0000000000000000
[  353.034618] x15: 0000000000000000 x14: 0000000000000000
[  353.040016] x13: 0000000000000000 x12: 0000000000000000
[  353.045414] x11: 0000000000000000 x10: 0000000000001980
[  353.050812] x9 : ffffff807b551c68 x8 : ffffff807cd15560
[  353.056210] x7 : 0000000000000001 x6 : 000000000000021c
[  353.061607] x5 : 0000000000000001 x4 : 0000000000000000
[  353.067005] x3 : 000000000000003f x2 : 0000000000000040
[  353.072403] x1 : ffffff7fb0170e40 x0 : ffffff7fb0170c60
[  353.077801] Call trace:
[  353.080284]  __dma_inv_area+0x28/0x58
[  353.084005]  dma_direct_sync_single_for_cpu+0x9c/0xa0
[  353.089139]  dma_direct_unmap_page+0xa4/0xa8
[  353.095954]  dma_direct_unmap_sg+0x58/0x80
[  353.102547]  vchiq_complete_bulk+0xb0/0x278
[  353.109247]  slot_handler_func+0xf6c/0x1580
[  353.115942]  kthread+0xfc/0x128
[  353.121581]  ret_from_fork+0x10/0x1c
[  353.127652] Code: d1000443 ea03003f 8a230021 54000040 (d50b7e21)
[  353.136299] ---[ end trace 119a545d2f9256d7 ]---
OTOH, as an unprivved user, it works fine. Not convinced that should happen, even so. Did an rpi-update at about 1730, so running whatever was current then.
As it is apparently board policy to disallow any criticism of anything, as it appears to criticise something is to criticise all the users of that something, I will no longer be commenting in threads which are not directly relevant to my uses of the Pi.
6by9
Fri Jun 05, 2020 7:23 pm
Pi 4, 2G:
arm_64bit=1
gpu_mem=256
There was a fix to vchi yesterday for a dma_unmap_sg being done against the wrong device. It may not have made it to rpi-update as yet.
dickon
Fri Jun 05, 2020 7:39 pm
Ta.
It isn't an issue -- works fine as a normal user, which is a bit surprising -- but thought I'd mention it.
jiapei100
Wed Jun 10, 2020 8:12 pm
I'm trying to run docker on the 32-bit Raspbian with 64-bit Kernel. Unlike the other 32-bit Raspbian with 32-bit kernel, when I try:
pi@pi01:~ $ docker run -it -d arm64v8/alpine
ccda6c95f81de8ac3bdb1aff69ac0a7e0059fc21f6b57206e8bb004d1e87ef5c
pi@pi01:~ $ docker ps -a
CONTAINER ID        IMAGE               COMMAND             CREATED             STATUS                       PORTS               NAMES
ccda6c95f81d        arm64v8/alpine      "/bin/sh"           9 seconds ago       Exited (159) 3 seconds ago                       nifty_gates
The running container is exited promtly, normally within 3 seconds.
This happens ONLY on this 64bit kernel Raspberry Pi4.
Did anybody have the same issue?
Cheers
Welcome to Vision Open
http://www.visionopen.com
jiapei100
Thu Jun 11, 2020 12:56 am
It looks with this P4 64-bit Kernel, raspistill and raspivid don't work properly. Even **^C** and **^Z** won't be able to halt the camera application. Did anybody meet the same issue?
pi@pi01:~ $ raspistill -o cam.jpg
Message from syslogd@pi01 at Jun 10 17:45:42 ...
 kernel:[  236.233099] Internal error: Oops: 96000144 [#1] PREEMPT SMP
 kernel:[  236.233916] Code: d1000443 ea03003f 8a230021 54000040 (d50b7e21)
 ^Cmmal: Aborting program
^C^C^C^C^C^Z^Z^Z^Z^Z
fanoush
Sun Jun 14, 2020 1:23 pm
yes, search this topic for 'docker'
fanoush
Sun Jun 14, 2020 1:25 pm
trabant wrote:
Thu Jun 04, 2020 6:48 am
Currently I am running the regular 4.19.97 kernel (as v8+ in 64bit mode) and everything works fine, as in 32bit mode. If I do an apt upgrade to the recently released 4.19.118 kernel video works fine, but analog audio is dead and I can't get it work again, despite numerous experiments. This applies to both 32 and 64 bit mode.
try uninstalling pulseaudio, that solved it for me
user238424
Sun Jun 14, 2020 1:59 pm
After
sudo rpi-update
and after adding
arm_64bit=1
in config.txt, and after reboot (also hard reboot), i cant connect with Putty and FTP anymore. HDMI also outputs nothing. Any fix to this?
dom
Mon Jun 15, 2020 9:52 am
If you remove arm_64bit=1 (e.g. using a PC with sdcard reader) does it boot?
dom
Mon Jun 15, 2020 9:54 am
There is no mmal camera or video acceleration support currently. Only v4l2 is working with 64-bit. raspivid/raspistill uses mmal.
user238424
Mon Jun 15, 2020 4:36 pm
That worked, thanks a lot. By the way, that happened on Model 3b.
thatchunkylad198966
Mon Jun 15, 2020 4:42 pm
Maybe you missed the topic title:
:lol:
[NEW] Ubuntu - CM4/RPi4B custom image(s)! XFCE4, LXQt, i3-WM, WireGuard, Samba, Kodi, Latest MESA graphics drivers!
https://www.raspberrypi.org/forums/viewtopic.php?f=131&t=314419
dickon
Mon Jun 15, 2020 4:56 pm
It is still a little surprising that the VC bootloader will happily attempt to boot an aarch64 kernel on its 32b-only ARMs, on older Pis. Got bitten by that one myself.
Sgb999
Fri Jun 19, 2020 10:06 pm
how do i go back to 32-bit? having issues with linux headers
dom
Mon Jun 22, 2020 12:45 pm
Just remove "arm_64bit=1" from config.txt.
bizzymizzyb
Thu Jun 25, 2020 9:16 am
i'm getting this error when trying to run gadmin-openvpn-client though I'm uncertain whether or not its due to the 64-bit kernel.
Starting program: /usr/sbin/gadmin-openvpn-client
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/arm-linux-gnueabihf/libthread_db.so.1".
[Detaching after fork from child process 27390]
Program received signal SIGSEGV, Segmentation fault.
0xf7fac1dc in strlen () from /usr/lib/arm-linux-gnueabihf/libarmmem-v8l.so
dom
Thu Jun 25, 2020 11:08 am
Are you using 32-bit raspbian usespace with 64-bit kernel enabled as described in this thread?
If so just remove arm_64bit=1 from config.txt, reboot and check if issue still happens.
bizzymizzyb
Thu Jun 25, 2020 1:36 pm
ahhhh... that's too easy - why not run GDB on it and see exactly where the error occurs? ;-) lol ; honestly I'd hate to do that:
look at that uptime- 12 days - this system is solid as a rock. i'm not taking this baby down because of some silly, contained seg fault preventing me from running gtk config of openvpn ; the command-line version works.
But on a more serious note, there may be an issue with /usr/lib/arm-linux-gnueabihf/libarmmem-v8l.so running in 64-bit. I've never coded arm assmebly but looking at it:
   0xf7fac1c0 <+0>:	push	{r4, lr}
   0xf7fac1c4 <+4>:	mov	r1, r0
   0xf7fac1c8 <+8>:	tst	r0, #248, 30	; 0x3e0
   0xf7fac1cc <+12>:	tst	r0, #7
   0xf7fac1d0 <+16>:	bne	0xf7fac24c <strlen+140>
   0xf7fac1d4 <+20>:	bics	r3, r2, r0
   0xf7fac1d8 <+24>:	beq	0xf7fac24c <strlen+140>
=> 0xf7fac1dc <+28>:	vld1.8	{d0-d1}, [r0 :64]!
   0xf7fac1e0 <+32>:	bics	r3, r2, r0
   0xf7fac1e4 <+36>:	beq	0xf7fac220 <strlen+96>
   0xf7fac1e8 <+40>:	vceq.i8	d0, d0, #0
   0xf7fac1ec <+44>:	vceq.i8	d1, d1, #0
   0xf7fac1f0 <+48>:	vmov	r3, s0
   0xf7fac1f4 <+52>:	vmov	r4, s1
   0xf7fac1f8 <+56>:	vmov	r12, s2
   0xf7fac1fc <+60>:	vmov	lr, s3
   0xf7fac200 <+64>:	teq	r3, #0
   0xf7fac204 <+68>:	teqeq	r4, #0
   0xf7fac208 <+72>:	teqeq	r12, #0
   0xf7fac20c <+76>:	teqeq	lr, #0
   0xf7fac210 <+80>:	bne	0xf7fac2d0 <strlen+272>
   0xf7fac214 <+84>:	vld1.8	{d0-d1}, [r0 :64]!
r0             0x0                 0
r1             0x0                 0
r2             0xff8               4088
r3             0xff8               4088
r4             0x7fa338            8364856
r5             0x0                 0
r6             0x851d60            8723808
r7             0x798ea0            7966368
r8             0x45d100            4575488
r9             0x7f85f8            8357368
r10            0x424c50            4344912
r11            0x0                 0
r12            0x424edc            4345564
sp             0xfffef560          0xfffef560
lr             0x40d548            4248904
pc             0xf7fac1dc          0xf7fac1dc <strlen+28>
cpsr           0x20000010          536870928
d0             {u8 = {0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0xff}, u16 = {0x0, 0x0, 0x0, 0xff00}, u32 = {0x0, 0xff000000}, u64 = 0xff00000000000000, f32 = {0x0, 0x0}, f64 = 0x8000000000000000}
d1             {u8 = {0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff}, u16 = {0xffff, 0xffff, 0xffff, 0xffff}, u32 = {0xffffffff, 0xffffffff}, u64 = 0xffffffffffffffff, f32 = {0x0, 0x0}, f64 = 0x0}
see anything? r0 looks suspicious but I don't know what vld1.8 does.
dom
Thu Jun 25, 2020 4:24 pm
libarmmem*.so is just an accelerated set of memset/memcpy style functions.
You can disable it by commenting out
/usr/lib/arm-linux-gnueabihf/libarmmem-${PLATFORM}.so
from /etc/ld.so.preload and then run "sudo ldconfig"
If it still crashes (but now libc) then it's the application at fault (presumably passing in a NULL or otherwise duff pointer).
If it works then there's a bug in libarmmem.
bizzymizzyb
Thu Jun 25, 2020 5:05 pm
still crashes
[Detaching after fork from child process 25362]
strlen () at ../sysdeps/arm/armv6/strlen.S:26
26	../sysdeps/arm/armv6/strlen.S: No such file or directory.
guess the problem is in gadmin-openvpn-client, same null value in r0
=> 0xf745f830 <+0>:	ldrb	r2, [r0]
   0xf745f834 <+4>:	and	r3, r0, #7
   0xf745f838 <+8>:	mov	r1, r0
   0xf745f83c <+12>:	rsb	r3, r3, #15
   0xf745f840 <+16>:	cmp	r2, #0
r0             0x0                 0
r1             0x5                 5
surprised no one noticed it before. As I recall, the KDE openvpn config was giving a segfault as well but I didn't investigate it.
22over7
Mon Jul 06, 2020 2:44 pm
dom wrote:
Wed Sep 04, 2019 1:18 pm
geev03 wrote:
Wed Sep 04, 2019 11:07 am
- Mathematica and Wolfram are not showing up :(
If you are daring, edit /opt/Wolfram/WolframEngine/12.0/Executables/mathematica
find lines:
				armv?l)
					SystemIDList="Linux-ARM";;
and add after:
				aarch64)
You can also make a comparable change to /opt/Wolfram/WolframEngine/12.0/Executables/wolfram
I know that this is an old post, but I wonder if we can apply this modification to the 64 bit raspberry OS to enable installing of mathematica? For my intended applications having 64 bit OS could be useful, but I need mathematica as well.
My pi has not yet arrived so I can't test this myself. Many thanks for your help!
Return to “Advanced users”
