gubertoli
Re: Pi4 64-bit raspbian kernel for testing - Focus on Pi4
Sat Oct 19, 2019 6:10 am
Kendek wrote:
Fri Oct 18, 2019 7:31 am
Compile 64-bit kernel on Raspbian:
Prepare for compilation:
Compile and install the kernel:
Followed the instructions but after reboot...
mice, keyboard, wireless adapter and sound is not working, so I got a freeze Desktop :cry:
Comments to the instructions: mount required sudo to successfully be performed.
Kendek
Sat Oct 19, 2019 8:50 am
hawk_ing wrote:
Sat Oct 19, 2019 5:37 am
[email protected]:~ $ sudo dpkg --add-architecture aarch64
pkg-config-dpkghook: Warning: Architecture aarch64 not defined in architecture tables, ignored
sudo dpkg --add-architecture arm64
But there are no arm64 packages in the Raspbian repository. So the libc6 and other arm64 libraries cannot be installed.
ShiftPlusOne
Sat Oct 19, 2019 10:44 am
Kendek
Sat Oct 19, 2019 11:29 am
Yeah, sorry. I just edited my post, added some missed commands and package. Please try again, this time I tested it. :)
incognitum
Sat Oct 19, 2019 12:00 pm
Seems something up with USB when running 64-bit kernel on model 3B+
If I attach Pi Zero and rpiboot gpioexpander image, rpiboot does complete, but gadget Ethernet network interface never shows up afterwards.
[email protected]:~ $ uname -a
Linux raspberrypi 4.19.79-v8+ #1273 SMP PREEMPT Fri Oct 11 18:35:44 BST 2019 aarch64 GNU/Linux
[email protected]:~ $ sudo rpiboot -d /usr/share/rpiboot/gpioexpand/
Waiting for BCM2835/6/7
Sending bootcode.bin
Successful read 4 bytes
Second stage boot server
File read: config.txt
File read: start.elf
File read: fixup.dat
File read: kernel.img
File read: gpioexpand.img
File read: bcm2708-rpi-0-w.dtb
File read: overlays/dwc2.dtbo
Second stage boot server done
Last dmesg:
[   26.492449] usb 1-1.1.2: USB disconnect, device number 8
[   27.739472] usb 1-1.1.2: new full-speed USB device number 9 using dwc_otg
[   27.842888] usb 1-1.1.2: not running at top speed; connect to a high speed hub
[   27.853405] usb 1-1.1.2: New USB device found, idVendor=0a5c, idProduct=2764, bcdDevice= 0.00
[   27.853431] usb 1-1.1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=1
[   27.853447] usb 1-1.1.2: Product: BCM2710 Boot
[   27.853463] usb 1-1.1.2: Manufacturer: Broadcom
[   27.853478] usb 1-1.1.2: SerialNumber: Broadcom
With 32-bit kernel on same device it does work properly.
[  120.047007] usb 1-1.1.2: USB disconnect, device number 8
[  121.367750] usb 1-1.1.2: new full-speed USB device number 9 using dwc_otg
[  121.501086] usb 1-1.1.2: not running at top speed; connect to a high speed hub
[  121.511088] usb 1-1.1.2: New USB device found, idVendor=0a5c, idProduct=2764, bcdDevice= 0.00
[  121.511106] usb 1-1.1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=1
[  121.511116] usb 1-1.1.2: Product: BCM2710 Boot
[  121.511127] usb 1-1.1.2: Manufacturer: Broadcom
[  121.511136] usb 1-1.1.2: SerialNumber: Broadcom
[  137.711014] usb 1-1.1.2: USB disconnect, device number 9
[  139.027527] usb 1-1.1.2: new high-speed USB device number 10 using dwc_otg
[  139.158657] usb 1-1.1.2: New USB device found, idVendor=f055, idProduct=0001, bcdDevice= 4.04
[  139.158677] usb 1-1.1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[  139.158686] usb 1-1.1.2: Product: Pi Zero - GPIO expansion board
[  139.158695] usb 1-1.1.2: Manufacturer: Raspberry Pi
[  139.158706] usb 1-1.1.2: SerialNumber: 000000006099b31e
[  139.223038] cdc_acm 1-1.1.2:1.0: ttyACM0: USB ACM device
[  139.223946] usbcore: registered new interface driver cdc_acm
[  139.223959] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[  139.232433] cdc_ether 1-1.1.2:1.2 usb0: register 'cdc_ether' at usb-3f980000.usb-1.1.2, CDC Ethernet Device, fa:00:60:99:b3:1e
[  139.233605] usbcore: registered new interface driver cdc_ether
Just Pi 3+ with 64-bit kernel that has this problem, so probably specific to dwc module.
Pi 4 with 64-bit kernel does work properly.
leggazoid
Sun Oct 20, 2019 3:54 pm
I noticed some apps don't work with 64-bit kernel.
Sonic-Pi
Minecraft-Pi (It quit working on 32-bit as well)
I realize this is a test and not meant for everyone.
gubertoli
Mon Oct 21, 2019 5:48 am
The build was fine... I was able to use the Raspbian.
I just had bad times to compile kernel modules once source and build folders on /lib/modules/4.19.79-v8 are not correctly linked.
Once I still require a functional 64-bit OS to work with eBPF and this approach did not worked, I decided to give a try to Ubuntu 19.10 (now with 64-bit support for RPi).
@Kendek, thank you so much! I learned a lot with these attempts.
Kendek
Mon Oct 21, 2019 7:56 am
Modules also can only be compiled within Ubuntu chroot. Just keep the ubuntu64 directory. :)
gishten
Tue Oct 22, 2019 2:04 pm
I'm having trouble running rtorrent 0.9.7 on this kernel. It crashes intermittently, though never running longer than ~4 hours.
Caught SIGBUS, dumping stack:
rtorrent() [0x1ed84]
/lib/arm-linux-gnueabihf/libc.so.6(__default_rt_sa_restorer+0) [0xf75a3130]
/usr/lib/arm-linux-gnueabihf/libtorrent.so.20(+0xb9f9c) [0xf7a39f9c]
/usr/lib/arm-linux-gnueabihf/libtorrent.so.20(_ZN7torrent9PollEPoll7performEv+0xdc) [0xf79af4e8]
/usr/lib/arm-linux-gnueabihf/libtorrent.so.20(_ZN7torrent9PollEPoll7do_pollExi+0xa8) [0xf79af69c]
/usr/lib/arm-linux-gnueabihf/libtorrent.so.20(_ZN7torrent11thread_base10event_loopEPS0_+0x17c) [0xf79e8b7c]
rtorrent() [0x1d8f4]
/lib/arm-linux-gnueabihf/libc.so.6(__libc_start_main+0x10c) [0xf758d718]
Error: Success
Signal code '1': Invalid address alignment.
Fault address: 0xe8ad91
The fault address is not part of any chunk.
Aborted
k3lt
Mon Oct 28, 2019 9:32 pm
On Raspberry pi3b+ is booting into blank screen, but i can connect with SSH. Any suggestions?
uname -a
Linux raspberrypi 4.19.80-v8+ #1274 SMP PREEMPT Mon Oct 21 16:45:40 BST 2019 aarch64 GNU/Linux
My /boot/config.txt
# For more options and information see
# http://rpf.io/configtxt
# Some settings may impact device functionality. See link above for details
# uncomment if you get no picture on HDMI for a default "safe" mode
#hdmi_safe=1
# uncomment this if your display has a black border of unused pixels visible
disable_overscan=1
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
#hdmi_force_hotplug=1
# uncomment to force a specific HDMI mode (this will force VGA)
#hdmi_group=1
#hdmi_mode=1
#hdmi_drive=2
# uncomment to increase signal to HDMI, if you have interference, blanking, or
# no display
config_hdmi_boost=4
# uncomment for composite PAL
#sdtv_mode=2
#arm_freq=800
# Uncomment some or all of these to enable the optional hardware interfaces
#dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
# Uncomment this to enable infrared communication.
#dtoverlay=gpio-ir,gpio_pin=17
#dtoverlay=gpio-ir-tx,gpio_pin=18
# Additional overlays and parameters are documented /boot/overlays/README
# Enable audio (loads snd_bcm2835)
dtparam=audio=on
[pi4]
# Enable DRM VC4 V3D driver on top of the dispmanx display stack
dtoverlay=vc4-fkms-v3d
max_framebuffers=2
[all]
#dtoverlay=vc4-fkms-v3d
arm_64bit=1
dickon
Mon Oct 28, 2019 9:41 pm
#hdmi_safe=1
Tried that? Why not?
k3lt
Mon Oct 28, 2019 9:46 pm
#hdmi_safe=1
Yeah tried it, also config_hdmi_boost=4.. still blank screen unfortunately.
Is there something else i can try since i have SSH connection?
Edit:
I just tried switching to boot into CLI by default instead of Desktop in raspi-config and it works, CLI is displayed correctly.
startlxde-pi gives me following output:
** Message: 22:56:55.001: main.vala:101: Session is LXDE-pi
** Message: 22:56:55.001: main.vala:102: DE is LXDE
(lxsession:602): Gtk-WARNING **: 22:56:55.113: cannot open display:
startx output:
X.Org X Server 1.20.4
X Protocol Version 11, Revision 0
Build Operating System: Linux 4.15.0-48-generic armv8l Raspbian
Current Operating System: Linux raspberrypi 4.19.80-v8+ #1274 SMP PREEMPT Mon Oct 21 16:45:40 BST 2019 aarch64
Kernel command line: coherent_pool=1M 8250.nr_uarts=0 bcm2708_fb.fbwidth=1920 bcm2708_fb.fbheight=1080 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=5e3da3da-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait usbhid.mousepoll=0 quiet splash plymouth.ignore-serial-consoles
Build Date: 05 June 2019  12:49:54PM
xorg-server 2:1.20.4-1+rpt1 (https://www.debian.org/support)
Current version of pixman: 0.36.0
        Before reporting problems, check http://wiki.x.org
        to make sure that you have the latest version.
Markers: (--) probed, (**) from config file, (==) default setting,
        (++) from command line, (!!) notice, (II) informational,
        (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: "/home/pi/.local/share/xorg/Xorg.0.log", Time: Mon Oct 28 23:03:15 2019
(==) Using system config directory "/usr/share/X11/xorg.conf.d"
(EE)
Fatal server error:
(EE) parse_vt_settings: Cannot open /dev/tty0 (Permission denied)
(EE)
(EE)
Please consult the The X.Org Foundation support
         at http://wiki.x.org
 for help.
(EE) Please also check the log file at "/home/pi/.local/share/xorg/Xorg.0.log" for additional information.
(EE)
(EE) Server terminated with error (1). Closing log file.
xinit: giving up
xinit: unable to connect to X server: Connection refused
xinit: server error
cat /home/pi/.local/share/xorg/Xorg.0.log output:
[   595.985]
[   595.985] Build Operating System: Linux 4.15.0-48-generic armv8l Raspbian
[   595.985] Current Operating System: Linux raspberrypi 4.19.80-v8+ #1274 SMP PREEMPT Mon Oct 21 16:45:40 BST 2019 aarch64
[   595.985] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 bcm2708_fb.fbwidth=1920 bcm2708_fb.fbheight=1080 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=5e3da3da-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait usbhid.mousepoll=0 quiet splash plymouth.ignore-serial-consoles
[   595.985] Build Date: 05 June 2019  12:49:54PM
[   595.985] xorg-server 2:1.20.4-1+rpt1 (https://www.debian.org/support)
[   595.985] Current version of pixman: 0.36.0
[   595.985]    Before reporting problems, check http://wiki.x.org
[   595.985] Markers: (--) probed, (**) from config file, (==) default setting,
[   595.986] (==) Log file: "/home/pi/.local/share/xorg/Xorg.0.log", Time: Mon Oct 28 23:03:15 2019
[   595.988] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[   595.990] (==) No Layout section.  Using the first Screen section.
[   595.990] (==) No screen section available. Using defaults.
[   595.990] (**) |-->Screen "Default Screen Section" (0)
[   595.990] (**) |   |-->Monitor "<default monitor>"
[   595.997] (==) No device specified for screen "Default Screen Section".
        Using the first device section listed.
[   595.997] (**) |   |-->Device "Allwinner A10/A13 FBDEV"
[   595.997] (==) No monitor specified for screen "Default Screen Section".
        Using a default monitor configuration.
[   595.997] (==) Automatically adding devices
[   595.997] (==) Automatically enabling devices
[   595.997] (==) Automatically adding GPU devices
[   595.997] (==) Max clients allowed: 256, resource mask: 0x1fffff
[   595.997] (WW) The directory "/usr/share/fonts/X11/misc" does not exist.
[   595.997]    Entry deleted from font path.
[   595.997] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[   595.998] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[   595.998]    Entry deleted from font path.
[   595.998] (WW) The directory "/usr/share/fonts/X11/Type1" does not exist.
[   595.998] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
[   595.998] (==) FontPath set to:
        /usr/share/fonts/X11/100dpi/:unscaled,
        /usr/share/fonts/X11/100dpi,
        built-ins
[   595.998] (==) ModulePath set to "/usr/lib/xorg/modules"
[   595.998] (II) The server relies on udev to provide the list of input devices.
        If no devices become available, reconfigure udev or disable AutoAddDevices.
[   595.998] (II) Loader magic: 0x1fcf80
[   595.998] (II) Module ABI versions:
[   595.998]    X.Org ANSI C Emulation: 0.4
[   595.998]    X.Org Video Driver: 24.0
[   595.998]    X.Org XInput driver : 24.1
[   595.998]    X.Org Server Extension : 10.0
[   596.005] (II) systemd-logind: took control of session /org/freedesktop/login1/session/c2
[   596.006] (II) no primary bus or device found
[   596.006] (II) LoadModule: "glx"
[   596.009] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[   596.070] (II) Module glx: vendor="X.Org Foundation"
[   596.070]    compiled for 1.20.4, module version = 1.0.0
[   596.070]    ABI class: X.Org Server Extension, version 10.0
[   596.070] (II) LoadModule: "fbturbo"
[   596.070] (II) Loading /usr/lib/xorg/modules/drivers/fbturbo_drv.so
[   596.074] (II) Module fbturbo: vendor="X.Org Foundation"
[   596.074]    compiled for 1.20.3, module version = 0.5.1
[   596.074]    Module class: X.Org Video Driver
[   596.074]    ABI class: X.Org Video Driver, version 24.0
[   596.074] (II) FBTURBO: driver for framebuffer: fbturbo
[   596.074] (EE)
Fatal server error:
[   596.075] (EE) parse_vt_settings: Cannot open /dev/tty0 (Permission denied)
[   596.076] (EE)
[   596.076] (EE)
 for help.
[   596.077] (EE) Please also check the log file at "/home/pi/.local/share/xorg/Xorg.0.log" for additional information.
[   596.078] (EE)
[   596.078] (WW) xf86CloseConsole: KDSETMODE failed: Bad file descriptor
[   596.078] (WW) xf86CloseConsole: VT_GETMODE failed: Bad file descriptor
[   596.080] (EE) Server terminated with error (1). Closing log file.
sudo startx:
(==) Log file: "/var/log/Xorg.0.log", Time: Mon Oct 28 23:07:14 2019
modprobe: FATAL: Module g2d_23 not found in directory /lib/modules/4.19.80-v8+
/usr/lib/xorg/Xorg: symbol lookup error: /usr/lib/xorg/modules/drivers/fbturbo_drv.so: undefined symbol: shadowUpdatePackedWeak
xinit: giving up
xinit: server error
k3lt
Tue Oct 29, 2019 10:45 am
I just fixed blank screen on boot by adding this into /boot/config.txt, now display works when booting to Desktop with Raspberry Pi 3b+.
[all]
max_framebuffers=2
framebuffer_priority=2
dom
Tue Oct 29, 2019 11:45 am
Can you describe exactly what you have been doing.
Did you start with a clean raspbian buster image, with no changes to config.txt which has a working display and display stopped working after rpi-update and adding arm_64bit=1? Does display work without arm_64bit=1?
If not, what did you start with.
k3lt
Tue Oct 29, 2019 11:53 am
I started with clean (full) image of buster image i got from https://www.raspberrypi.org/downloads/raspbian/ with no changes to config.txt , it booted fine and everything worked. (armv7 kernel)
Then i did rpi-update and added arm_64bit=1 to /boot/config.txt which resulted in blank screen on boot. Display works fine without arm_64bit=1.
But as i've said above i got it to work with arm_64bit=1 (armv8 kernel) after adding these lines to config.txt:
[all]
max_framebuffers=2
I found the solution here: https://github.com/raspberrypi/firmware/issues/1204 (i know it's not the same issue but it worked nonetheless)
dom
Tue Oct 29, 2019 12:01 pm
I found the solution here: https://github.com/raspberrypi/firmware/issues/1204 (i know it's not exactly the same issue but it worked nonetheless)
The comment on the link was:
Note, just setting max_framebuffers avoids the problem,
Is that enough to fix your issue?
k3lt
Tue Oct 29, 2019 12:07 pm
I'm getting blank screen with:
[all]
max_framebuffers=2
arm_64bit=1
Disply is working with:
[all]
max_framebuffers=2
arm_64bit=1
Not sure what framebuffer_priority=2 does, but i guess it's not required then.
dom
Tue Oct 29, 2019 12:22 pm
Is max_framebuffers=2 required?
k3lt
Tue Oct 29, 2019 12:26 pm
Tried without it and display is fine, so looks like just dtoverlay=vc4-fkms-v3d is required.
Here is my full config.txt which is booting with working display.
Edit:
Forgot to mention, the TV i'm using is LG 50UK6950PLB connected with HDMI if that makes any difference.
#hdmi_safe=1
disable_overscan=1
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# overscan.
#hdmi_group=1
#hdmi_mode=1
#hdmi_drive=2
# no display
#config_hdmi_boost=4
#sdtv_mode=2
#arm_freq=800
#dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
dtparam=audio=on
[pi4]
max_framebuffers=2
[all]
arm_64bit=1
dom
Tue Oct 29, 2019 1:08 pm
I've done a quick check and Pi3 with arm_64bit=1 and no fkms overlay has a display as expected here.
As this problem is probably unique to your setup (possibly the display), can you open as issue here:
https://github.com/raspberrypi/linux/firmware
(it's actually currently unclear if it's a firmware or kernel issue, but my initial guess is firmware)
Describe what we've tested and include the edid (tvservice -d edid.dat and attach a zip file of the edid to the issue),
and perhaps some of the other devs will have some ideas.
k3lt
Tue Oct 29, 2019 1:12 pm
I'm using Pi3 b+ not Pi3, https://github.com/raspberrypi/linux/firmware gives me 404. :)
Tue Oct 29, 2019 1:15 pm
k3lt
Tue Oct 29, 2019 1:39 pm
Ok done https://github.com/raspberrypi/firmware/issues/1278 , hopefully i didn't screw up something. ;)
f0rd0prefect
Fri Nov 01, 2019 12:38 pm
dom wrote:
Tue Sep 03, 2019 11:56 pm
Linux domnfs 4.19.69-v8+ #1261 SMP PREEMPT Tue Sep 3 20:27:16 BST 2019 aarch64 GNU/Linux
Is 'uname -a' the only method to detect the 64-Bit-Kernel? I would appreciate a kernelmessage, which can be parsed with dmesg, e.g.
dmesg | grep -i cpu
This is behaviour from current 32-Bit-Kernel:
 CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7)
When using 64-Bit-Kernel, I don't get any message like this.
dickon
Fri Nov 01, 2019 12:48 pm
dmesg has a limited buffer which makes it unsuitable for that sort of thing. You can trivially grep the 'CPU architecture' field of /proc/cpuinfo ('7' for 32b on a Pi 3B, '8' for the 64b kernel), however.
Return to “Advanced users”
