Mark_F
Contact: Website Facebook
Need help with permissions after automount of usb storage?
Sat Aug 31, 2019 12:48 am
Hi folks,
First post here and first Pi which is only a week out of the box.
Got my NEW Pi 4 4GB all happening. Buster, Apache, MySQL, php, wordpress, samba and stuff all working very nicely indeed. Then I threw a spanner into the works...
I thought it'd be a great idea to press a Sandisk SSD (500GB) into service so I followed the VERY nice and easy to follow HOWTO I found on this very site. That went well and I now have plenty of space and a bit of a perceived performance improvement. All good, BUT....
Before the SSD I could plug a USB stick in and it'd be presented on the (username) pi desktop and be accessible by all and sundry - just what I wanted. Now, however, the plugged in USB stick is ONLY accessible to "root" and for the user "pi" to be able to get at it it needs to be unmounted and remounted with -o uid=pi, gid=pi.
With Slackware, which I'm familiar with, I'd just edit the udev rules and reload them and we'd be all OK. Since implementing the SSD /dev/sda is taken and the USB stick is now /dev/sdb or /dev/sdc. I can find no udev rules that are relevant. So....
Does Buster use udev or some other mechanism and if so, what? What do I need to "fix" to get it working as it did when the USB stick was coming up on /dev/sda ? I know this is just something that I don't understand just yet..:-)
If someone could please tell me where I can find the /dev/sda stuff I can then seek to understand it and fix it for /dev/sdb and /dev/sdc.
Mark F
http://jandmf.com
Vk3KW / VK3ZMF
LTolledo
Re: Stooopid newbie non understanding
Sat Aug 31, 2019 3:30 am
try changing ownership of the SSD mount
usually its seen in /media/pi/xxxxx-xxxx-xxx (if auto-mounted)
sudo chown -R pi:pi /media/pi/xxxx-xxxx-xxx
in addition you may
sudo chmod -R 775 /media/pi/xxxx-xxxx-xxx
use
lsblk
to check where the SSD is mounted
better to have it mounted properly using /etc/fstab
there are quite a number in the forum....
Some people be like:
Mark_F
Sat Aug 31, 2019 10:44 am
in addition you may
Good solution but it requires privilege which I'd rather not give my 12 year old grandson.
use
lsblk
The SSD is mounted by proper use of fstab :-
proc            /proc           proc    defaults          0       0
PARTUUID=a207fce3-01  /boot           vfat    defaults          0       2
PARTUUID=a207fce3-02  /               ext4    defaults,noatime  0       1
# a swapfile is not a swap partition, no line here
#   use  dphys-swapfile swap[on|off]  for that
The SSD is the ext4 partition mounted at /.
What I'm after is the automount mechanism. If it's udev I can't find the rule to tweak and if it isn't I don't know how the automount is done.
Cheers,
Mark F...
Mark F
http://jandmf.com
Vk3KW / VK3ZMF
Sat Aug 31, 2019 10:55 am
What's the filesystem format on your SSD?
If it's NTFS then sudo apt install ntfs-3g is needed to allow read/write access. Then ownership is done on the mount (or automount) for the drive (can be overridden with umask=000 to give every file 777 permission bits).
This is a doctor free zone.
FTrevorGowen
Sat Aug 31, 2019 4:49 pm
Cheers,
Mark F...
It's usually (often) performed by the (desktop) file manager and, unless things have changed, there should be an option to "turn it off":
http://www.cpmspectrepi.uk/raspberry_pi ... Auto-mount
Trev.
Still running Raspbian Jessie or Stretch on some older Pi's (an A, B1, B2, B+, P2B, 3xP0, P0W, 2xP3A+, P3B+, P3B, B+, A+ and a B2) but Buster on the P4B's. See: https://www.cpmspectrepi.uk/raspberry_pi/raspiidx.htm
bjtheone
Sat Aug 31, 2019 5:33 pm
Humm... You have gacked something up in your installing/configuring. I have an almost identical setup (4B, with boot on the SD, rootfs on an SSD), with a very similar fstab. Automounting USB sticks works just fine.
I did manage to break fuser in my mucking about such that it broke automounting USB sticks (gave an error) but I brute forced that via a forced reinstall of fuser rather than sorting exactly what I broke. Just tweaking fstab to mount rootfs from an SSD will not break automounting. Be default it will happily mount sticks on sdb, sdc, etc if sda is used by the SSD. Sorry that it is not a solution, but at least its confirmation that it should just work.
As noted, permissions to the automounted file system is another thing and is totally dependent on what file system type you are mounting. But given the questions you are asking I suspect you already know that.
Mark_F
Sun Sep 01, 2019 1:05 am
Yep I somehow managed to mess up udev. Last night I put the backup SD card from BEFORE I added the SSD and tried things out and as expected it worked properly. Added a USB memory stick for the root partition using the same process as I did before and again, it all worked properly. Went back to the current SD and SSD and it's still not working properly. Took a punt and uninstalled UDEV and reinstalled it. Viola and it all worked properly again.
The clue pointing to UDEV was in /var/log/messages where it says "mounted on behalf of uid 1000" While it was "gacked" it was saying mounted on behalf of uid ????????.
It's now all fixed but I don't know why or how it got messed up. Maybe the rsync from the SD to the SSD ? Dunno...:-)
Cheers and thanks for all the help.
Mark F...
Mark F
http://jandmf.com
Vk3KW / VK3ZMF
bjtheone
Re: Need help with permissions after automount of usb storage?
Sun Sep 01, 2019 4:09 pm
Did you switch from default user "pi" to something else during the config process? 1000 is the uid of the default user.
Return to “Advanced users”
