dineshlama
How can i use pci card with raspberry pi?
Fri Aug 30, 2019 4:26 am
Is it possible to use custom PCI card with raspberry pi somehow? I need ntel Pro/1000 GT : e1000e driver PCI card to use RTnet alsong xenomai in raspberry pi, but since raspberry pi don't have this pci card, i'm searching for method to connect it with RP somehow.
W. H. Heydt
Re: How can i use pci card with raspberry pi?
Fri Aug 30, 2019 5:31 am
The only PCIe interface a Pi4B has is tied to the USB ports. No other Pis have any form of PCI interface.
Imperf3kt
Fri Aug 30, 2019 6:49 am
PCI to usb adaptor?
55:55:44:44:4C
52:4C:52:42:41
drgeoff
Fri Aug 30, 2019 7:56 am
PCI to usb adaptor?
https://superuser.com/questions/1182079 ... ters-exist
Quis custodiet ipsos custodes?
RaTTuS
Contact: Twitter YouTube
Fri Aug 30, 2019 8:00 am
why do you want that card ?
the raspberry 4 has a nice NIC
if you want more NIC then use a USB 3 to Ethernet adaptor
Covfefe
pcmanbob
Fri Aug 30, 2019 8:47 am
Even if you could connect a PCI card to your pi , which you can't,
Were are you going to get a driver for said PCI card ? any drivers will be written for x86/64bit based PC's and their motherboard PCI slots.
Idea falls flat on its face at both hardware and software levels.
LTolledo
Sat Aug 31, 2019 8:58 am
you can use that pci card with raspberry pi, as an angled stand for your raspberry pi in a case :D
other than that.... just a waste of time.... better sell it off and get some of your money back....
Some people be like:
hippy
Sat Aug 31, 2019 11:54 am
I imagine the important part for the OP is not so much using that card but being able to "use RTnet" which only works with a limited number of NIC devices, and requires OS support for that.
http://www.rtnet.org
Return to “Advanced users”
