To this end I bought an already made 128 I2C GPIO Expander 8*MCP23017, and 8 * 16 Channel Relay Board.
The expander works as it should, the relays not so much, so I'm actually testing now using an 8 Channel Relay Board.
My problems come in programming the MCP23017, more exactly how to use just one specific pin.
I've managed to activate all the pins, but when it comes to just 1 - this eludes me completely.
Keep in mind that the relay board activates on LOW and deactivates on HIGH.
import smbus
import sys
import getopt
import time
bus = smbus.SMBus(1)
address = 0x20
bus.write_byte_data(0x20, 0x00, 0x00) #set Port-A as output
#Relay turns ON
time.sleep(1)
bus.write_byte_data(0x20, 0x12, 0xFF) #set Port-A to High
#Relay turns OFF
Thanks for reading this
Edit: http://ww1.microchip.com/downloads/en/d ... 01952c.pdf MCP23017 Datasheet
