Power station for PI4
Posted: Tue Aug 20, 2019 5:36 am
by mullcom
Anyone that have found a power station with more then one usb port to power more then one Raspberry PI4 ?
I have try to search on E-bay but dont find any that have output 3A
Re: Power station for PI4
Posted: Wed Aug 21, 2019 2:20 am
by kilograham
there don't seem to be many; best i could find were 2 ports: https://www.amazon.com/gp/product/B07M5K9X7W
Posted: Wed Aug 21, 2019 6:38 am
by mullcom
I have try on my own to find some. But seems that there are not any out there.
Hope in fiuter there coming out some. Perfect to power several Pi to save Power slots.
Posted: Wed Aug 21, 2019 6:56 am
by Imperf3kt
You can use a standard ATX power supply (designed for PC's and small workstations) to power a Pi. It won't be through the MICRO-USB / USB-C, but rather via Pin 2 or 4 and any ground pin or suitable ground point (most metal shields, for instance) on a Pi.
Adding a polyfuse is suggested but not entirely necessary.
Just be sure to get the polarity correct and do not use the 12v wires (usually yellow), use the 5v wiring (usually red)
Posted: Wed Aug 21, 2019 9:07 am
by Paul Webster
Also ... Pi4 does not need the full 3A for itself.
So if you are not planning to add power hungry USB peripherals to your Pi4 then lower power is fine.
See the specs for more detail.
