email atachment
Posted: Tue Aug 13, 2019 9:46 am
by hawkesley
i want to send an email where the attachment will vary.
I am trying to use a variable to hold the file name and add that to directory path.
This fails with the error
File "/home/pi/email scripts/tony.sh", line 47, in <module>
attachment =open(filename,'rb')
TypeError: invalid file: PosixPath('/home/pi/Pictures/latest')
any suggestions appreciated.
This is the code in question
path = "/home/pi/Pictures/"
files =os.listdir(path)
latest = files[0]
for key in files:
    if os.path.getctime(path+key) > os.path.getctime(path + latest):
        latest = key
print(latest)
filename = latest
start_path = Path('/home/pi/Pictures')
final_path = start_path /'filename'
filename= final_path
This is the full script
#!/bin/bash
import smtplib
from email.mime.text import MIMEText
from email.mime.multipart import MIMEMultipart
from email.mime.base import MIMEBase
from email import encoders
import os
import os.path
from pathlib import Path
print("preparing to mail")
email_user = 'your email'
email_password = 'password'
email_send = 'send to email'
subject = 'send mail test'
msg = MIMEMultipart()
msg['From'] = email_user
msg['To'] = email_send
msg['Subject'] = subject
body = 'Hi there, sending this email from Tony,sent from photo module!'
msg.attach(MIMEText(body,'plain'))
latest = files[0]
for key in files:
        latest = key
print(latest)
filename = latest
part = MIMEBase('application','octet-stream')
part.set_payload((attachment).read())
encoders.encode_base64(part)
part.add_header('Content-Disposition',"attachment; filename= "+filename)
msg.attach(part)
text = msg.as_string()
server = smtplib.SMTP('smtp.gmail.com',587)
server.starttls()
server.login(email_user,email_password)
server.sendmail(email_user,email_send,text)
server.quit()
print("sending email from tony")
Re: email atachment
Posted: Tue Aug 13, 2019 10:04 am
by pcmanbob
Looking at the error message it would appear that your program can't find a file called latest which it is expecting to find in the directory
/home/pi/Pictures
So is your file called latest ? I suspect not.
Try adding a print statement before the error line and have it print the contents of the filename variable so you can see what it contains.
And you should not have #!/bin/bash as the first line in your program as this is a python program not a bash script.
Re: email atachment
Posted: Tue Aug 13, 2019 10:10 am
by scotty101
Firstly you can get the most recently updated file in a single line.
latest = max(glob.iglob('Results\*.txt'), key=os.path.getctime)
Secondly look at this line of code
You are creating the final path to include the start_path and the string "filename" not the contents of the variable filename.
I suspect this will be causing some issues for you.
Re: email atachment
Posted: Tue Aug 13, 2019 10:26 am
by hawkesley
Yes that is the problem so my question is how to add the variable latest contents to start_path?
Re: email atachment
Posted: Tue Aug 13, 2019 10:47 am
by pcmanbob
Assuming the path will never change
filename = "/home/pi/Pictures/" + str(latest)
which would mean these lines are not needed.
Re: email atachment
Posted: Tue Aug 13, 2019 11:06 am
by hawkesley
Thanks for that the script now runs as intended.
