Page 8 of 10
Re: STICKY: HOWTO: Create Custom HDMI modes
Posted: Wed Apr 04, 2018 3:43 pm
by dom
steinerlein wrote:
Wed Apr 04, 2018 11:10 am
So far so good, the backlight switches on and it doesn't seem to fail right away. However, I am having some issues with displaying an image on the display. It always shows only the topmost line. My suspicion is that the pixel clock frequency is too high for the display. The datasheet specifies 9Mhz typ and 15Mhz max.
You do seem to be hitting a firrmware bug when frequencies below oscillator frequency (19.2MHz) come out as zero.
I have a test firmware you could try that allows your hdmi_timings line to boot with what appears to be the correct frequency:
$ vcgencmd measure_clock pixel
frequency(29)=9600000
Can you test it?
EDIT: This fix is now included in rpi-update firmware.
Posted: Mon Apr 09, 2018 9:07 am
by steinerlein
Can you test it?
I didn't give an update last week, but I have gotten the pixel clock clock to be what I want. With these settings in config.txt I can measure 9Mhz on the clock line.
hdmi_ignore_edid=0xa5000080
hdmi_timings=480 0 2 41 43 272 0 2 12 2 0 0 0 60 0 9000000 3
hdmi_group=2
hdmi_mode=87
In hindsight, the display simply didn't turn on with 9.6Mhz pixel clock, but it did with 9Mhz.
I am now experiencing another problem: The display turns on fine and then slowly goes black around the edges, much like vignetting in photography. I am not sure what the cause is.. I'd be thankful for any hints!
Posted: Thu Apr 12, 2018 11:05 am
by steinerlein
hey dom
I am posting here again, because I am not having much success with the display I am trying to drive.
I'm pretty certain that the timings are not correct yet. Here is what is provided in the datasheet:
Item			MIN	TYP	MAX	Unit
DCLK frequency: 		9	15	Mhz
DCLK Period:		66.7ns	111.1		ns
Horizontal frequency: 		17.14		KHz
Vertical frequency:	50	59.94	70	Hz
H Pulse Width:		2	41	41	DCLK
H Back Porch:		4	43	82	DCLK
H Front Porch:		2	2	82	DCLK
H Blank Period HBP+HFP:	45	45	125	DCLK
H Display Area:		480	480	480	DCLK
H Cycle:		525	525	605	DLCK
V Pulse Width:		1	10	11	HCycle
V Back Porch:		2	12	22	HCycle
V Front Porch:		1	2	227	HCycle
V Blanking Period VBP+VFP:	14		HCycle
V Display Area:		272	272	272	HCycle
V Cycle:		285	286	399	HCycle
And these are the timings I am using right now:
hdmi_timings:480 0 2 41 43 272 0 2 10 12 0 0 0 60 0 9000000 3
Unfortunately, the image quality is very bad:
As you can see, the image has horizontal striping and gets darker from the outside inwards. This darkening effect happens over time and can get "inverted" after a reboot of the pi.
I'd be thankful for thoughts or ideas on how to improve this.
Re: Custom HDMI modes
Posted: Fri May 04, 2018 5:37 am
by frankievalentine
shookis wrote:
Sat Apr 01, 2017 10:10 pm
darseneau wrote:
dom wrote: 2560x1080 is not possible. 1920x1200 is the maximum resolution supported.
Is that a firmware limitation at present, as I had supposed, or a hardware limit of the gpu?
I have an LG 2560x1080 display and I was able to get it working using the following:
hdmi_timings=2560 0 48 32 80 1080 0 7 20 12 0 0 0 52 0 159838855 7
hdmi_group=2
hdmi_mode=87
hdmi_drive=2
framebuffer_width=2560
max_framebuffer_width=2560
framebuffer_height=1080
hdmi_pixel_freq_limit=160000000
I know this hdmi_timings from a somewhat painful experience in getting the same display to work with a somewhat older mac mini (mid 2011) which didn't support it out of the box.
Thank you!!!! You saved me with this one shookis. Much appreciated for posting these setttings.
Posted: Tue May 22, 2018 9:18 pm
by rfried
Thanks for the config.txt info by frankievalentine and all others.
I adapted it for my screen and got working 3840x1600 @30Hz
on a LG Electronics 38UC99-W 21:9 monitor connected to
a Raspberry Pi 3 Model B+.
config.txt:
hdmi_drive=2
hdmi_group=2
hdmi_mode=87
hdmi_aspect_21_9=7
hdmi_pixel_freq_limit=400000000
hdmi_cvt=3840 1600 30 7 0 0 1
max_framebuffer_width=3840
max_framebuffer_height=1600
(24Hz was also ok)
Posted: Thu Jun 14, 2018 2:43 am
by cnlohr
Does anyone know what the new maximum pixel clock is for the 3B+'s? Based on many other posts, it's definitely not 140 MHz anymore. But, I am trying to find out if it can get up to the 297 for the Vive. If not it certainly can come close.
EDIT: Apparently it's right at the edge, and requires overclocking the pi, but, the 297MHz dot clock of the vive is totally achievable.
Yamaski Catleap
Posted: Thu Aug 02, 2018 4:06 am
by felixre7
Just wanted to post here with my working config.txt for a 2k yamaski catleap monitor. I think they are sold under some other names but it took many hours of research, never finding a datasheet, to figure out what settings i needed. In the hopes of sparing someone from that same fate here they are:
# For more options and information see
# http://rpf.io/configtxt
# Some settings may impact device functionality. See link above for details
# uncomment if you get no picture on HDMI for a default "safe" mode
#hdmi_safe=1
#hdmi_edid_file=1
#disable_overscan=1
# uncomment the following to adjust overscan. Use positive numbers if console
# goes off screen, and negative if there is too much border
overscan_left=0
overscan_right=0
overscan_top=0
overscan_bottom=0
# uncomment to force a console size. By default it will be display's size minus
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
framebuffer_depth=24
framebuffer_ignore_alpha=1
max_framebuffer_height=1440
start_x=1
gpu_mem=192
hdmi_force_hotplug=1
# uncomment to force a specific HDMI mode (this will force VGA)
hdmi_force_mode=1
hdmi_cvt=2560 1440 59 3 0 0 1
hdmi_group=2
hdmi_mode=87
edid_content_type=0
hdmi_pixel_freq_limit=260000000
#this is yamaski catleap magic right here
hdmi_timings=2560 1 48 32 112 1440 0 3 10 65 0 0 0 59 0 237670880 3
# uncomment to force a HDMI mode rather than DVI. This can make audio work in
# DMT (computer monitor) modes
hdmi_drive=1
# uncomment to increase signal to HDMI, if you have interference, blanking, or
# no display
config_hdmi_boost=7
# uncomment for composite PAL
#sdtv_mode=2
#uncomment to overclock the arm. 700 MHz is the default.
#arm_freq=800
# Uncomment some or all of these to enable the optional hardware interfaces
#dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
# Uncomment this to enable the lirc-rpi module
#dtoverlay=lirc-rpi
# Additional overlays and parameters are documented /boot/overlays/README
dtparam=audio=on
I tried so many things i think most of this doesn't matter except for:
hdmi_force_mode=1
hdmi_group=2
hdmi_mode=87
this successfully runs the catleap at 59Hz on my rPi 2 B+, i had to divine the porch sizes and other settings. here are the websites that really helped me learn what was going on and might help other people in the future figuring out weird monitors:
how the hdmi timings line works: https://www.raspberrypi.org/documentati ... /README.md
THIS: <pixel_freq> = clock frequency (width*height*framerate)
nice config.txt explainer: https://github.com/raspberrypi/documen ... /video.md
yamaski specific info that helped me figure out the timings line, you can find the back porch size by subtracting the total pixel count by the resolution and the front porch. in addition windows could display on this monitor because it was magically figuring out the settings, you can steal some info from there (like the sync pulse widths).
https://forums.overclockers.com.au/thre ... s.1184364/
https://www.overclock.net/forum/44-moni ... b-113.html
Posted: Tue Aug 07, 2018 4:31 pm
by ibeeby
Right, I know that there has been a lot of traffic on this topic but I may have a new query (or not)...
I am trying to re-use an old Apple PowerBook Titanium LCD panel. It has a VGA input and the native resolution is 1280x854 at 24 bits per pixel.
Any thoughts as to the config.txt configuration for such a display?
The connection is via the RPi HDMI connector and an HDMI to VGA adapter (a cheap eBay unit).
I get a display at 1280x800 but the top part of the screen is duplicated at the bottom. Also, there are some severe colour rendition issues (using default 16-bit or 24-bits per pixel). I am satisfied that the display was working perfectly before I scrapped the computer which was obsolete.
I also have a PowerBook Aluminium lcd panel which is a later model and although it has the same resolution I should be able to get an HDMI driver for it. However, first job is to get the earlier panel working if possible.
Grateful for any thoughts.
Ian
Posted: Tue Aug 07, 2018 4:52 pm
by jamesh
What are your current config settings?
Posted: Tue Aug 07, 2018 4:58 pm
by davidcoton
Congrats Jamsh on reaching 20K posts. Keep up the good work (sorry if this is too off-topic)!
Posted: Tue Aug 07, 2018 5:05 pm
by jamesh
Arghhh. Missed it!
Thanks!
Posted: Thu Aug 09, 2018 6:25 pm
by ibeeby
I'm using the standard config.txt settings - I have tried to set the resolution to 1280x854 but it doesn't seem to do anything - so tried 1280x900 and 1280x800 but the position has not improved.
I think that there must be some setting to give actual 1280x854 out of the device or the display will not work properly - its an LCD panel with fixed native resolution of 1280x854.
Ian
Posted: Tue Aug 14, 2018 2:32 pm
by ibeeby
Folks,
Thanks for the input.
I have just received the driver board for my second display which is from a 15" Aluminium PowerBook G4. The displays have, allegedly, the same resolution. However, the later panel requires different driver hardware and this hardware includes an HDMI connector. On a quick assessment I can report that the newer display panel works right out of the box, so to say, with my Raspberry Pi.
I don't have time to do it now but I think that the best approach will be to see what the HDMI data is for the newer panel and see if I can replicate that on the older panel via the VGA adapter route. I hope, since the native resolutions are the same, that this ought to work.
It seems that the HDMI resolution being used on the newer panel is 1280x900 (panel is 1280x854) but I cannot see any part of the display missing and the colours etc are just as they are on a 'normal' display.
More when I have time...
Ian
Posted: Wed Aug 22, 2018 5:40 pm
by Hiles
hey dom
Hello steinerlein ,
Your case looks very similar to mine. So far I guess you are using a display which is more or less a clone of the LCD module of the Sony PSP. I have the same device and the same symptoms.
You say something about "inverted" but I'm not sure to understand clearly. In my case the entire display seems to start randomly in a "reverse video" mode.
Do you have a "Data enable" signal on your display ? (none in my case). I suspect something related to this detail :(.
I also noticed the following. Increasing the V pulse width to very high values (e.g. 5000) virtually slows down the refresh rate. Doing this shows clearly that one line out of 2 stays grey. And this changes every frame. On one frame, the odd lines are ok, the other ones grey. One the next frame, the even lines are ok.
Strange na ?
Posted: Mon Oct 08, 2018 12:17 pm
by hussaa1
Hi fellows;
I am new to RPi world from other programming languages and trying to do an LCD project in 24bit RGB DPI mode to dynamically display big font eight ASCII characters received over the Ethernet port to the active region of the display.
I am using Raspberry Pi 3 Model B v1.2 with all the latest Linux updates and upgrades performed and RPi updated as well.
This post is a really useful place to come to I must say but however for some reason I couldn't find a specific information I needed to know.
I did find some very useful information too which was extremely helpful and I managed to get going my intended LCD this far. A big thanks to all the supporters. :)
RPi LCD in Action-1.jpg (200.12 KiB) Viewed 17429 times
My problem;
I can't shift or shrink the image to fit my LCD resolution of 480x272 active pixel area.
I am using the dt-blob.dts from here https://github.com/raspberrypi/firmware ... t-blob.dts
And here's my config settings;
hdmi_safe=1
dtdebug=1
dtparam=i2c_arm=off
dtparam=spi=off
#overscan_left=0
#overscan_right=0
#overscan_top=0
#overscan_bottom=0
#framebuffer_width=525
#framebuffer_height=286
enable_dpi_lcd=1
display_default_lcd=1
dtoverlay=dpi24
dpi_group=2
dpi_mode=87
#---- For Densitron LCD -----#
dpi_timings=480 0 2 41 2 272 0 2 10 2 0 0 0 100 0 32000000 3
dpi_output_format=459031
disable_touchscreen=1
dtparam=audio=on
hmdi_force_hotplug=1
According to the LCD ( driver chip HX8257-A - 480X272 TFT ), http://www.phoenixdisplay.com/wp-conten ... 8257-A.pdf
the recommended typical frequency is 9 MHz. The only settings that my RPi DPI port clock pin works for is 32 MHz. If I try any other value than 32000000 in the DPI timing section, the clock just turns off and obviously I don't get display. The desktop menus are working with a guessed click in the off screen top area. Could someone please let me know how may I use 9 MHz or close to that clock frequency and still have my display working? Plus any idea why the screen would not shift or shrink etc. even when I alter the overscan values or change the framebuffer H/V sizes?
I am calculating the RPi clock frequency as follows but it doesn't work;
Full screen area
= H-Cycles x V-Cycles x the frame rate
= 525 x 286 x 60 = 9009000.
Many thanks in advance.
Posted: Tue Oct 09, 2018 3:28 am
by aBUGSworstnightmare
@hussaa1: please post lcd module data sheet. Looking at the foto let's me hardly believe it's 480x272 pixels.
Posted: Tue Oct 09, 2018 7:43 am
hussaa1 wrote: the recommended typical frequency is 9 MHz. The only settings that my RPi DPI port clock pin works for is 32 MHz. If I try any other value than 32000000 in the DPI timing section, the clock just turns off and obviously I don't get display. The desktop menus are working with a guessed click in the off screen top area. Could someone please let me know how may I use 9 MHz or close to that clock frequency and still have my display working? Plus any idea why the screen would not shift or shrink etc. even when I alter the overscan values or change the framebuffer H/V sizes?
Full screen area
btw: DPI clock is also working for dot clock < 32MHz (see this example https://www.raspberrypi.org/forums/view ... 1&t=166561)
Be sure to check your dpi_ouput_format command value.
Posted: Tue Oct 09, 2018 8:00 am
by hussaa1
Hello aBUGSworstnightmare
Thanks for your response;
I already linked the datasheet in my post. Here's the link;
Posted: Tue Oct 09, 2018 9:50 am
hussaa1 wrote: Hello aBUGSworstnightmare
Sorry to say, but the linked information is useless to you! What's you've linked is the displays timing controller (T-CON) data sheet, but not your display modules data sheet! Your right in saying 'it can be used up to 480x272pixels resolution, but this mustn't be your modules resolution.
So, what's the part number of your particular display module? Manufacturer?
Posted: Tue Oct 09, 2018 11:00 am
by hussaa1
Yes you are right,
This display is a Densitron part no 84-0254-000.
Posted: Tue Oct 09, 2018 11:03 am
by hussaa1
However the timing diagram they have listed in their datasheet is exactly the same as the one in the previous datasheet link I posted. It is a customised version to work in 1U panels.
Posted: Tue Oct 09, 2018 11:08 am
So, if the displays timing is 480x272pixels you need to decrease your framebuffer size to 480x128pixels.
Because your modules native resolution is 480x128pixels only.
Don't expect to end up with a functional desktop on 128pixels height. At least I did not manage with this module https://www.raspberrypi.org/forums/view ... 1&t=154571
Note: as nobody has access to the timing chart, nobody will be able to help you in finding the correct timing.
Posted: Tue Oct 09, 2018 12:09 pm
by hussaa1
I have played with framebuffer values to align the desktop now sort of in the middle which is beginning to look cool. What I am worried about is that although my screen is working at 32 MHz, it is a way too high frequency than the spec requires. This isn't appropriate for the LCD to run like that for long time is it? Whats your suggestions?
Plus what logic should I be thinking in my head when trying other frequency values.
e.g. from the post link you forwarded earlier, my board clock is now working at 19.2 MHz when I use Holo85 configs; Thanks holo85.
dpi_output_format=278549
hdmi_timings=960 0 20 50 70 160 0 10 10 30 0 0 0 60 0 19200000 1
However my display is now showing all white but the clock pin is reading 19.2 MHz on scope. H_Sync and V_Sync are both running at 36.64 KHz. So as you say, the relationship between the dpi_output_format and the hdmi_timings clock rate is very crucial.
Posted: Tue Oct 09, 2018 12:19 pm
hussaa1 wrote: dpi_output_format=278549
hussaa1, you can't expect your display to work with another displays timing. You have the spec, so you need to figure out your display timing and dpi_output_format value from it.
Look here https://www.raspberrypi.org/documentati ... /README.md for explanation of the values, this blog for more explantions http://blog.reasonablycorrect.com/raw-dpi-raspberry-pi/
and
your displays users manual for all the values!
Posted: Tue Oct 09, 2018 2:39 pm
by hussaa1
aBUGSworstnightmare - i'd like to thank you for your answers, you've been very helpful of course and obviously know something about the RPi.
Would you know the lowest frequency the RPi can go down to?
i.e. should it be able to work down to 9 MHz or am I going to be wasting my time trying to achieve that?
