stevo_300
Persistant SSH connection
Tue Dec 04, 2012 2:02 pm
I am wanting to remote control my PI from work (the Pi is at home)
is it possible to set a command running via a SSH session, and ensure it keeps running even if the SSH window closes so I can come back to it later for instance if building code or downloading a file.
malakai
Re: Persistant SSH connection
Tue Dec 04, 2012 2:05 pm
My favorite is screen
sudo apt-get install screen
To start a new screen you type screen you can even name it
screen -S nameit
To disconnect and leave it running
CTRL+A then d
Then close ssh
To reconnect log in
Type
screen -ls
That shows what screens are running to connect to that screen say it is named 2986
screen -r 2986
Or just type screen -r 2 then hit the Tab key.
stevo_300
Tue Dec 04, 2012 2:52 pm
Fantastic, I will try this.
Thanks for your help
stevo_300
Tue Dec 04, 2012 3:27 pm
Reading package lists... Done
Building dependency tree
Suggested packages:
iselect screenie byobu
screen
0 upgraded, 1 newly installed, 0 to remove and 113 not upgraded.
Need to get 0 B/650 kB of archives.
After this operation, 923 kB of additional disk space will be used.
dpkg: error: parsing file '/var/lib/dpkg/available' near line 12236:
EOF after field name `'
E: Sub-process /usr/bin/dpkg returned an error code (2)
I am getting this error when trying to install screen. I know this is most likely a basic issue, unfortunately I'm new to Linux and just finding my feet.
malakai
Tue Dec 04, 2012 3:33 pm
try sudo apt-get update
stevo_300
Tue Dec 04, 2012 3:35 pm
I did, it didnt make a difference
malakai
Tue Dec 04, 2012 3:43 pm
sudo dpkg --clear-avail
then rebuild the file using the command:
sudo apt-get update
tedhale
Tue Dec 04, 2012 4:04 pm
If your program has a graphical interface, then you probably need screen (I prefer to use a VNC server on the Pi and a VNC client on my PC. Search this forum for instructions.)
If the program is text based, you can just use the nohup command to keep the program running after you log off.
When I have done this in the past I have always redirected output to a log file so I could see what the program was doing later.
- Ted B. Hale
http://raspberrypihobbyist.blogspot.com
stevo_300
Tue Dec 04, 2012 4:07 pm
you are a complete legend.
All working and screen does seem to do what I wanted.
Joe Schmoe
Tue Dec 04, 2012 8:09 pm
stevo_300 wrote:you are a complete legend.
screen is truly awesome. Many of us have been using it for decades.
And, remember, it's not only a screen multiplexer; it's also a serial communications program.
bulletmark
Tue Dec 04, 2012 10:51 pm
Note that screen has largely been superseded by tmux nowadays which looks slightly better, has better defaults, has horizontal screen split, etc. If you are learning something new then you may as well choose tmux.
BTW. I have used for screen for 10 years or so but use tmux almost exclusively now.
stevo_300
Wed Dec 05, 2012 9:54 am
interesting, I will give it a try as well
Return to “Advanced users”
