altanhaligur
UART communication between Pis
Tue Jul 16, 2019 12:52 pm
I want to communicate two RPis with UART. I connect Rx-tx and tx-rx and grounds of two RPis. when im starting communication with ser = serial.Serial("........") which port should i use?
hippy
Re: UART communication between Pis
Tue Jul 16, 2019 1:32 pm
I believe it should be "/dev/serial0" for both sides. That will select the UART which is routed to GPIO pins 14 and 15 regardless of PI model and which UART is actually routed to those - /dev/AMA0 or /dev/ttyS0 otherwise.
You can use "ls -l /dev/serial*" to determine how things are routed on a particular Pi -
pi@Pi3B:~ $ ls -l /dev/ser*
lrwxrwxrwx 1 root root 5 Jul 12 10:54 /dev/serial0 -> ttyS0
lrwxrwxrwx 1 root root 7 Jul 12 10:54 /dev/serial1 -> ttyAMA0
pi@Pi3B:~ $
There was I recall a bug with Buster that /dev/serial* were not being created but, from the above, that seems to have been resolved. Run "sudo apt-get update", "sudo apt-get upgrade" to ensure you have the latest software installed.
altanhaligur
Tue Jul 16, 2019 1:38 pm
Oh okay i will try this, thanks
altanhaligur
Tue Jul 16, 2019 1:46 pm
GND pins RX and TX pins wired correctly.
I use this code for one RPi:
import serial
from time import sleep
port = serial.Serial("/dev/ttyAMA0", baudrate=115200, timeout=None)
while 1:
    pin = raw_input("Activate pin: ").strip("\r\n")
    port.write(pin)
    sleep(0.1)
And this code for another RPi:
import serial
while 1:
  try:
    data_chunk = port.read()
    time.sleep(0.1)
    remaining_bytes = port.inWaiting()
    data_chunk += port.read(remaining_bytes)
    print data_chunk
  except Exception, e:
    print str(e)
    pass
This codes doing nothing.
hippy
Tue Jul 16, 2019 2:08 pm
Maybe try "/dev/serial0" as suggested, or tell us which Pi model you are using so what else it should be can be determined.
I would also start with simpler code and slower baud rates, something like, untested ..
import serial
import time
transmitter = serial.Serial("/dev/serial0", baudrate=4800)
while True:
  for c in "ABCDEF":
    transmitter.write(c+"\n")
    time.sleep(1)
import serial
receiver = serial.Serial("/dev/serial0", baudrate=4800)
while True:
    c = receiver.read()
    if c:
      print("Got "+c)
altanhaligur
Tue Jul 16, 2019 2:27 pm
One is Pi4 one is Pi3B+, im using TXD0 RXD0 TXD0 RXD0
hippy
Tue Jul 16, 2019 2:38 pm
I am not familiar with the Pi 4B and its UART configurations. There may be additional things you need to do to get those working or changes which I am unaware of.
I would suggest using two pre-4B's to get things working with "/dev/serial0" so you know your software and wiring does work, then see what happens when you replace one with a 4B.
It will be far easier to resolve with a "this works but this doesn't" situation than trying to resolve things where one does not know what does and doesn't work.
RaTTuS
Contact: Twitter YouTube
Tue Jul 16, 2019 2:43 pm
not tested on Pi4
but this is what I used previously
https://www.raspberrypi.org/forums/view ... 25#p828064
it may or may not help but YMMV
Covfefe
altanhaligur
Tue Jul 16, 2019 4:37 pm
import serial
import time
while True:
  for c in "ABCDEF":
    time.sleep(1)
import serial
while True:
    c = receiver.read()
    if c:
      print("Got "+c)
When im using serial0, it gives me could not open serial0.
Then i run this code with sudo, and again code doing nothing.
Then i tried with ttyAMA0 and again does nothinh
altanhaligur
Tue Jul 16, 2019 4:55 pm
not tested on Pi4
Im not trying to do this, my goal is data transfer
Andyroo
Tue Jul 16, 2019 5:22 pm
I would start by checking:
1) Console is disabled using sudo raspi-config
2) UART is enabled using raps-config
3) Checking cabling - TX -> RX and RX -> TX
4) running Minicom on both machines and see if the basic serial link is working
Only then look to the program aspect of the problem.
hippy
Tue Jul 16, 2019 5:46 pm
What does "ls /dev/serial*" report ? If /dev/serial0 is not there then it won't be able to open it.
Does nothing or gives an error message ? And is that on the transmitting or receiving side ?
You should not need to use sudo and that will not make it magically work.
On a Pi 3B, and I believe on the 3B+, that /ttyAMA0 goes to the Bluetooth chip. Probably the same for the Pi 4B but you would have to check.
You may have to run raspi-config or manually edit configuration files to enable the UART and disable the UART command console.
Take your Pi 3B+, connect its TXD to its own RXD, and run this -
#!/bin/usr/python2
import serial
import threading
import time
comPort = None
def TransmitThread():
  while comPort:
    for n in range(ord("A"),ord("Z")+1):
      if comPort:
        comPort.write(chr(n))
        time.sleep(1)
def ReceiveThread():
  while comPort:
    if comPort.inWaiting() > 0:
      n = comPort.read(1)
      print( n )
    else:
      time.sleep(0.1)
def LoopbackTest(comPortName):
  global comPort
  comPort = serial.Serial \
              port=comPortName,
              baudrate=4800,
              parity=serial.PARITY_NONE,
              stopbits=serial.STOPBITS_ONE,
              bytesize=serial.EIGHTBITS
  threading.Thread(target=TransmitThread).start()
  threading.Thread(target=ReceiveThread).start()
  try:
    while True:
      time.sleep(1)
  except KeyboardInterrupt:
    print("")
  finally:
    comPort = None
if __name__ == "__main__":
  LoopbackTest("/dev/serial0")
That works on my 3B and should work on anything else. Once it's working on your 3B+ try the same on your 4B -
pi@Pi3B:~/tmp $ python loopback.py
A
B
C
D
etc
altanhaligur
Tue Jul 16, 2019 7:04 pm
#!/bin/usr/python2
import serial
import threading
import time
comPort = None
  while comPort:
      if comPort:
        time.sleep(1)
  while comPort:
      n = comPort.read(1)
      print( n )
    else:
      time.sleep(0.1)
  global comPort
              port=comPortName,
              baudrate=4800,
  try:
    while True:
      time.sleep(1)
    print("")
  finally:
    comPort = None
A
B
C
D
etc
When i run your code i get this error:
https://hizliresim.com/Xb4b9D
Andyroo
Tue Jul 16, 2019 7:08 pm
Have you done steps one and two?
Can you post the output of
ls /dev
altanhaligur
Thu Jul 18, 2019 9:15 am
ls /dev
WhatsApp Image 2019-07-18 at 12.13.31.jpeg (202.29 KiB) Viewed 947 times
hippy
Thu Jul 18, 2019 11:22 am
/dev/serial0, /dev/serial1, /dev/ttyS0 and /dev/ttyAMA0 all appear to be there. You appear to be logged in as the default "pi" user. So it's not clear to me why you are getting "permission denied" errors. You could run the following commands and report back what you get -
uname -a
groups
ls -l /dev/serial*
ls -l /dev/ttyS0
ls -l /dev/ttyAMA0
For me, Pi 3B running Buster, I see -
pi@Pi3B:~ $ uname -a
Linux Pi3B 4.19.57-v7+ #1244 SMP Thu Jul 4 18:45:25 BST 2019 armv7l GNU/Linux
pi@Pi3B:~ $ groups
pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi
pi@Pi3B:~ $ ls -l /dev/serial*
lrwxrwxrwx 1 root root 5 Jul 16 18:39 /dev/serial0 -> ttyS0
lrwxrwxrwx 1 root root 7 Jul 16 18:39 /dev/serial1 -> ttyAMA0
pi@Pi3B:~ $ ls -l /dev/ttyS0
crw-rw---- 1 root dialout 4, 64 Jul 16 18:52 /dev/ttyS0
pi@Pi3B:~ $ ls -l /dev/ttyAMA0
crw-rw---- 1 root dialout 204, 64 Jul 16 18:39 /dev/ttyAMA0
pi@Pi3B:~ $
If you have done something we are not aware of, tried to set something up which uses the UART in some way, it may be worth starting from a fresh Buster install to see if that works any better.
Return to “Advanced users”
