RDPUser
GPIO access via bashscript and sysfs: Block until GPIO changes / interrupt handling
Sun Jul 14, 2019 12:43 pm
Via
cd /sys/class/gpio
sudo echo 26 > export
cd gpio26/
sudo echo in > direction
cat value
the state of the GPIO pin can be read.
Now I want that "cat value" or a similiar command blocks until the GPIO value changes.
Already tried
sudo echo rising > edge but after that cat value still doesn't block.
Any ideas how to to it with simple file system?
joan
Re: GPIO access via bashscript and sysfs: Block until GPIO changes / interrupt handling
Sun Jul 14, 2019 1:40 pm
I am fairly sure you can't with the sysfs interface. You will need to write a program.
RDPUser
Mon Jul 15, 2019 9:57 am
It is possible with sysfs interface https://raspberrypi.stackexchange.com/q ... terface-wi
But the question is is it possible with bash only?
joan
Mon Jul 15, 2019 10:25 am
Let me rephrase the answer. The sysfs interface (/sys/class/gpio) provides no way. You will have to write a program.
E.g.
/* 2014-07-06
   wfi.c
   gcc -o wfi wfi.c
   ./wfi [gpio]
#include <stdio.h>
#include <stdlib.h>
#include <fcntl.h>
#include <unistd.h>
#include <sys/time.h>
#include <poll.h>
#define GPIO 4
int main(int argc, char *argv[])
   char str[256];
   struct timeval tv;
   struct pollfd pfd;
   int fd, gpio;
   char buf[8];
      Prior calls assumed.
      sudo sh -c "echo 4      >/sys/class/gpio/export"
      sudo sh -c "echo in     >/sys/class/gpio/gpio4/direction"
      sudo sh -c "echo rising >/sys/class/gpio/gpio4/edge"
   if (argc > 1) gpio = atoi(argv[1]);
   else          gpio = GPIO;
   sprintf(str, "/sys/class/gpio/gpio%d/value", gpio);
   if ((fd = open(str, O_RDONLY)) < 0)
      fprintf(stderr, "Failed, gpio %d not exported.\n", gpio);
      exit(1);
   pfd.fd = fd;
   pfd.events = POLLPRI;
   lseek(fd, 0, SEEK_SET);    /* consume any prior interrupt */
   read(fd, buf, sizeof buf);
   poll(&pfd, 1, -1);         /* wait for interrupt */
   lseek(fd, 0, SEEK_SET);    /* consume interrupt */
   exit(0);
Return to “Advanced users”
