maximumwarp
Is been iptables substituted by nftables in Rasbpian Buster?
Mon Jul 01, 2019 8:03 am
on day one I bought a Pi 4 to use as home mail and web server. I would like configure a firewall with iptables but during some tests I noted all rules I write in /etc/iptables.firewall.rules are ignored. Is it only a my mistake in configuring iptables or it has been substituted by nftables in latest Raspbian version (like in Debian 10 Buster)?
Non è la fame ma è l'ignoranza che uccide.
Re: Is been iptables substituted by nftables in Rasbpian Buster?
Mon Jul 01, 2019 8:56 am
Raspbian Buster, which you are using on the Pi 4B, uses most of the same software as Debian Buster, so that would be a "yes".
Guess I'm going to have to learn how to use nftables now ;)
Unreadable squiggle
liderbug
Sun Jul 07, 2019 1:55 am
OK, find, grep, cut, etc... the example workstation.ntf and added 8088 and 8081 then:
nft -f /etc/nftables.conf and a reboot
# nft list ruleset | wc
401 2386 16107
# nft list ruleset | grep 8088 (grepping for just ' 80 ' returns same four lines)
meta l4proto tcp tcp dport 8088 counter packets 18 bytes 1080 accept
meta l4proto udp udp dport 8088 counter packets 0 bytes 0 accept
meta l4proto tcp tcp dport 8088 counter packets 0 bytes 0 accept
http://http://192.168.0.56/
 Apache2 Debian Default Page
This is the default welcome page used to test the correct opera... yada yada yada...
http://http://192.168.0.56:8088/
This site can’t be reached
192.168.0.56 refused to connect.
My nft looks to be correct (a lot I know) - I'm wondering if this is a firewall issue or something else? Nmap doesn't even show port 80 or 22 although they work - curl 80 & 22 work curl 8088 refuses to connect.
<frustrated>
Sun Jul 07, 2019 5:20 am
Sun Jul 07, 2019 6:00 am
This is FUD.
iptables and ip6tables are still there, still work and UFW still uses them.
incognitum
Sun Jul 07, 2019 9:12 am
They are now a frontend to nft though.
So better use nft directly.
If you want any iptables/nft rules loaded on startup you need to write your own startup script for that.
Don’t think it ever loaded anything from a file out-of-the-box.
Sun Jul 07, 2019 9:21 am
Why change the syntactical pain of a lifetime :mrgreen: :?: I'll stick with iptables (which I drive with fail2ban and ufw because it's so darned ugly).
liderbug
Tue Jul 09, 2019 12:32 am
> iptables and ufw are still there. I see that but I can not figure out how to open port 22 (or any others). Can someone post a few simple steps on how to open a port on a machine loaded with nftables.
thanks
liderbug
Tue Jul 09, 2019 9:09 pm
SOLVED :D :D :D :D
Stumbling around the net I came across this:
dnf remove openssh-clients openssh-server
dnf install openssh-clients openssh-server
systemctl restart sshd
and it's working like it should. So, I'm guessing that the buster-IMG build was created with the firewall enabled in lockdown mode.
Return to “Advanced users”
