husudosu
Is the new Raspberry PI 4 capable to play 10BIT H264
Mon Jun 24, 2019 9:41 am
Hi!
Is the new model capable to play 720P, 1080P 10BIT H264 encoded contets? As I saw it's capable to do 4K, but I'm not sure about lower res 10BIT encoded contents. RPI 3 B were not capable to play it, that's why I'm asking.
Content example (FFPROBE output):
[STREAM]
index=0
codec_name=h264
codec_long_name=H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
profile=High 10
codec_type=video
codec_time_base=1001/48000
codec_tag_string=[0][0][0][0]
codec_tag=0x0000
width=1280
height=720
coded_width=1280
coded_height=720
has_b_frames=2
sample_aspect_ratio=1:1
display_aspect_ratio=16:9
pix_fmt=yuv420p10le
level=50
color_range=unknown
color_space=unknown
color_transfer=unknown
color_primaries=unknown
chroma_location=left
field_order=progressive
timecode=N/A
refs=1
is_avc=true
nal_length_size=4
id=N/A
r_frame_rate=24000/1001
avg_frame_rate=24000/1001
time_base=1/1000
start_pts=0
start_time=0.000000
duration_ts=N/A
duration=N/A
bit_rate=N/A
max_bit_rate=N/A
bits_per_raw_sample=10
nb_frames=N/A
nb_read_frames=N/A
nb_read_packets=N/A
DISPOSITION:default=1
DISPOSITION:dub=0
DISPOSITION:original=0
DISPOSITION:comment=0
DISPOSITION:lyrics=0
DISPOSITION:karaoke=0
DISPOSITION:forced=0
DISPOSITION:hearing_impaired=0
DISPOSITION:visual_impaired=0
DISPOSITION:clean_effects=0
DISPOSITION:attached_pic=0
DISPOSITION:timed_thumbnails=0
[/STREAM]
Thanks for your information!
Re: Is the new Raspberry PI 4 capable to play 10BIT H264
Mon Jun 24, 2019 9:47 am
No, the H264 decoder is the same.
The H265 HEVC decoder supports 10bit 4k.
husudosu
Mon Jun 24, 2019 10:09 am
Thanks for your response, have a nice day!
Imperf3kt
Mon Jun 24, 2019 8:18 pm
I was playing a 10bit h.264 encoded file just 5 minutes ago on my Pi3A+ though...
Is it really unsupported? Seems to work fine in the VLC that comes preinstalled.
Google is ubiquitous - Try it today, it's free!
https://opensource.com/life/16/10/how-ask-technical-questions
husudosu
Tue Jun 25, 2019 3:35 pm
I've tried only played by Kodi if I remember well.
I've a post from 2017 asking about the issue (After that I've switched to HTPC):
https://www.raspberrypi.org/forums/view ... p?t=172177
But thanks for suggestion, maybe I'll give it a try with VLC , at that time just used a "headless" debian with launching Kodi.
Tue Jun 25, 2019 4:25 pm
That would be software decoding, and would struggle with higher resolutions. The H264 decoder HW does not support 10bit.
Return to “Advanced users”
