Hi ya. I have a pi zero w, brand new only 5hrs old. it was working till I put it into its new green pi zero w case which is a genuine pi case from pi hut.
This is my problem hope someone can help till I hear back from pi hut.
As the board was in place in the base of the new case it was working fine, the base has 2 4 legs to hold the board from moving and 2 fastening clips so when you close the lid it snaps into place. Here is where I have lost a component. If anyone has a pi zero w you have 2 small USB ports then to the right there is a little triangle with 2 components at its peak what do these components do? As when I put the top of the case on that's when the board lost power. I have the case apart and can see that the clip to hold the top case has ripped one component of the board completely and no I don't know where it is. What was it and is this some way related to my loss of power?
