markivanantha
How to copy files from SD Card to SD card for Raspberry pi 3b+
Tue Jun 18, 2019 1:10 am
How would I copy the contents of the Micro SD Card in the Raspberry Pi (Like OS, the files, etc.) to another Micro SD Card for the Raspberry Pi 3b+? I tried to turn the SD Card Files into an image and put it into the new SD Cardas countless many other tutorials told me to do that, but that apparently doesn't work for the 3b+ model.
Thanks!
FTrevorGowen
Re: How to copy files from SD Card to SD card for Raspberry pi 3b+
Tue Jun 18, 2019 11:27 am
Thanks!
The process** can work but only if the O.S. version on the current card is new enough (or sufficiently updated/upgraded).
What do these commands report?
uname -a
cat /etc/os-release
Trev.
**ie. the "SD Card Copier" tool.
Still running Raspbian Jessie on some older Pi's (an A, B1, B2, B+, P2B, 3xP0, P0W) but Stretch on my 2xP3A+, P3B+, P3B, B+, A+ and a B2. See: https://www.cpmspectrepi.uk/raspberry_pi/raspiidx.htm
LTolledo
Tue Jun 18, 2019 11:41 am
You must be running Raspbian Stretch, updated and upgraded.
Otherwise "...all bets are off..." as another prominent forum member used to post.
The SD Card Copier is usually available on the Desktop version of Raspbian.
Not seen that on Ubuntu or others (please correct me on this)
Some people be like:
markivanantha
Tue Jun 18, 2019 9:33 pm
Hi FTrevorGowen
When I run the 2 commands that you provided, I get:
[email protected]:~ $ uname -a
Linux raspberrypi 4.14.98-v7+ #1200 SMP Tue Feb 12 20:27:48 GMT 2019 armv7l GNU/Linux
[email protected]:~ $ cat /etc/os-release
PRETTY_NAME="Raspbian GNU/Linux 9 (stretch)"
NAME="Raspbian GNU/Linux"
VERSION_ID="9"
VERSION="9 (stretch)"
ID=raspbian
ID_LIKE=debian
HOME_URL="http://www.raspbian.org/"
SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
What can I do from this?
LTolledo
Tue Jun 18, 2019 9:47 pm
Just confirmed that you have Raspbian Stretch installed, however its not updated and upgraded to the latest
this is the output on my RPi3B+ updated and upgraded last weekend
Linux Raspi3BP1 4.19.42-v7+ #1219 SMP Tue May 14 21:20:58 BST 2019 armv7l GNU/Linux
yours is still 4.14.98-v7
it does not indicate that you have desktop version, is that the one that you installed?
HawaiianPi
Wed Jun 19, 2019 12:44 am
To fully upgrade your Raspbian Stretch install for use on the newer 3B+ model, run the following command on an older model Pi.
sudo apt update && sudo apt full-upgrade -y
After that it should work fine on the Raspberry Pi 3B+ system. You can use the SD Card Copier utility to duplicate the card.
markivanantha
Wed Jun 19, 2019 12:48 am
Thanks, HawaiianPi.
So once the update is done, then I can just make everything on the MicroSD Card an image and copy it to the new MicroSD Card?
markivanantha
Sun Jul 21, 2019 12:30 am
Hi
At first I thought you were talking about the "write the img to the we card" way that I tried before. But now, after doing some deeper digging, I realized that I didn't you mean the way you can do it on the Raspberry Pi itself, like in here:
https://www.raspberrypi.org/blog/anothe ... e-raspbian
I will try this method and make sure it works
Return to “Advanced users”
