Tobus
After rpi-update USB boot doesn't work
Sat Jun 01, 2019 2:13 pm
Hi all,
I'm using my Raspberry with an external SSD. After rpi-update and the reboot, USB-Boot doensn't work anymore.
After power on, it shows only an colored screen (see attached).
What can I do? I tried to boot with an new SD-Card. That worked fine, also the mounting of the SSD.
Tobias
pcmanbob
Re: After rpi-update USB boot doesn't work
Sat Jun 01, 2019 2:48 pm
Hi.
First question why did you run rpi-update ?
You should not run this unless you are instructed to by one of the raspberrypi org staff, to fix a specific problem.
Tobus
Sat Jun 01, 2019 3:09 pm
Oh that's new for me. Good to know! Thanks!
pcmanbob
Sat Jun 01, 2019 3:24 pm
It been like that for several years if memory serves my right,
You should only be running
sudo apt-get update
sudo apt-get upgrade
or
sudo apt-get full-upgrade
or
sudo apt-get dist-upgrade
If your pi was still bootable and had networking you could have tried
sudo apt-get install --reinstall raspberrypi-bootloader raspberrypi-kernel
https://www.raspberrypi.org/documentati ... pdating.md
But as you pi will no longer boot from the external SSD, I can't see how you are going to fix this without starting over with a new install on the external SSD.
hippy
Sat Jun 01, 2019 6:45 pm
There seems to be a fair number of people who misguidedly seem to use that and inevitably get themselves into a pickle having done so.
Maybe it's time to rename it to something else ? Pull the rug out from under the people who are being misled into doing that, save them from themselves, and from the bad advice which is leading them to do that.
Perhaps "rpi-update-and-i-know-the-risks" ?
incognitum
Sat Jun 01, 2019 10:07 pm
Sounds a bit drastic.
Since the TS mentions having a bootable SD card, I suggest booting from that and playing with chroot a bit first.
Among the lines of:
sudo bash
mount /dev/sda2 /mnt
mount /dev/sda1 /mnt/boot
mount -t proc none /mnt/proc
chroot /mnt /bin/bash
And then execute the apt-get or rpi-update commands you want to restore to a previous firmware release.
Alternatively, you can try just replacing the bootcode.bin, start*.elf and fixup*.dat files on the FAT partition of the SSD with the older version of the files you have on your SD card.
LTolledo
Mon Jun 03, 2019 12:45 pm
Never run rpi-update unless specifically instructed by the RPF engineer...
but if you still insist.... its up to you to dig out of your problem....
Some people be like:
hippy
Mon Jun 03, 2019 1:33 pm
That 'victim blaming' seems a bit harsh considering there are plenty of articles - including official RPF blog posts - which suggest rpi-update should be used or leads to a belief that it should, and naive users and those who don't know what they are doing cannot be expected to know that it is downright dangerous, and should only be used in specific circumstances.
Those suggestions to use rpi-update aren't going to go away. Users who don't know they're being misled will continue to be misled. The only way to stop people using it when they shouldn't is to remove it, rename it.
Mon Jun 03, 2019 1:44 pm
Actually, that is quite a sensible suggestion. Create a new script that displays a disclaimer message when run "This could break your system and if you don't know what you are doing and how to fix it yourself - don't run it!" and asks for confirmation "Yes, I really know what I'm doing and do have a tested and working backup of my system: Y/N?" and create another script called rpi-update that just echos a message to say "Don't run this, use apt instead".
Mon Jun 03, 2019 2:00 pm
There is nothing in the Official Help Page which states to use rpi-update, yet again no one reads the official website:
adieu
HP Envy 4500 Wireless Printer supported by HPLIP software in Raspbian Buster.
Raspberry Pi Model 2B v1.1
LTolledo
Mon Jun 03, 2019 2:24 pm
...Create a new script that displays a disclaimer message when run "This could break your system and if you don't know what you are doing and how to fix it yourself - don't run it!" and asks for confirmation "Yes, I really know what I'm doing and do have a tested and working backup of my system: Y/N?" and create another script called rpi-update that just echos a message to say "Don't run this, use apt instead".
I vote for this! :D
Mon Jun 03, 2019 4:56 pm
I vote for this! :D
There's already a "How much would you like to destroy your system?" question in rpi-update
[email protected]:~ $ sudo rpi-update
*** Raspberry Pi firmware updater by Hexxeh, enhanced by AndrewS and Dom
 *** Performing self-update
 *** Relaunching after update
WARNING: This update bumps to rpi-4.19.y linux tree
Be aware there could be compatibility issues with some drivers
Discussion here:
https://www.raspberrypi.org/forums/viewtopic.php?f=29&t=224931
Would you like to proceed? (y/N)
That piece just needs some extra words to tell folks not to run it unless they have a backup and know how to rebuild their broken system in less than 20 minutes.
For the OP. The only way to solve their problem is to start with another SDCard, a fresh download of Raspbian, Etcher and a USB reader to read stuff from the broken SDCard (or chroot it to fix it).
The code for rpi-update is on Github at https://github.com/Hexxeh/rpi-update you could write some changes and do a pull request. [I can't be bothered because I know how to rebuild a system in less than 20 minutes.]
This is a doctor free zone.
hippy
Tue Jun 04, 2019 12:29 pm
I don't recall anyone saying there was.
What is actually worth noting is there's nothing there which says "do not use rpi-update", in any shape or form.
Nothing there which tells a reader that other articles and posts which suggest always using rpi-update as the correct path for upgrading are wrong.
hippy
Tue Jun 04, 2019 12:42 pm
There's already a "How much would you like to destroy your system?" question in rpi-update ... That piece just needs some extra words to tell folks not to run it unless they have a backup and know how to rebuild their broken system in less than 20 minutes.
Doing that merely better legitimises placing the blame on those who don't know what they are doing for doing what they have done.
It does little to protect naive and novice users from themselves. And we all know that people who don't know what they are doing will click-through most warnings even when they shouldn't.
The real problem is that there's so much out there which misleads people into thinking rpi-update is the thing to use.
B.Goode
Tue Jun 04, 2019 1:49 pm
That's demonstrably true in respect of that specific document.
But this 'official' Raspberry Pi Foundation documentation about the Raspberry Pi Camera Module does recommend rpi-update, with no caution or warning: https://www.raspberrypi.org/documentati ... /camera.md
If you've checked all the above issues and the Camera Module is still not working, you may need to upgrade the firmware on the Raspberry Pi. Use the following command to get the very latest (but experimental) firmware:
sudo rpi-update
(To be clear - I think the advice in Camera Troubleshooting is a lapse in proofreading, not evidence that rpi-update is 'safe'.)
incognitum
Tue Jun 04, 2019 2:37 pm
I don't think using rpi-update itself is a big problem.
If people would no longer use it, bugs may no longer be noticed early.
Could use some documentation on how to recover the system if things go wrong though.
Tue Jun 04, 2019 3:18 pm
The idea is that people who should be using rpi-update are those who will be checking for bugs and are experienced enough to be able to recover the system without help.
Once the bugs have been identified and fixed, the kernel and firmware/bootloader will be released as a package for general use.
incognitum
Tue Jun 04, 2019 3:30 pm
With all due respect to the "more experienced people", chances are high they will not be able to catch all bugs.
E.g. what if the USB boot bug mentioned in this thread, is timing specific, and only occurs with a particular model USB drive?!
Then the bug would remain undetected and be included in the next general use package...
So I do think it is good that rpi-update is used by a wide range of users.
If people do not know how to fix a bricked system, then that is a good opportunity to educate them how to do so, instead of saying that rpi-update is not for them.
hippy
Tue Jun 04, 2019 6:42 pm
In my opinion; prevention is better than cure.
No one is advocating removing the ability to run latest or other firmware, just making it more difficult for users to be misled into doing something which they will come to regret.
LTolledo
Wed Jun 05, 2019 10:29 pm
......just making it more difficult for users to be misled into doing something which they will come to regret.
yup that's the one!
most us "normal users" are not "bug-hunters"....(did you "invested" on the RPi just to find "software bugs"?)
lets leave the bug-hunting to the "experts"....
...and do rpi-update if (and only if) specifically instructed to do so by the RPF engineers/staff.
Return to “Advanced users”
