Fast boot on Pi-Zero with C library and GPIO access
Posted: Wed May 22, 2019 6:12 pm
by nlebouthillier
I scoured the internet for an answer/how to and did not find what I needed.
Simply put I need to boot as fast as possible. All I need is the C libraries and access to the GPIO with the SPI turned on and maybe UART for debug.
I'm not experienced enough to re-compile the kernel so let's not go there if possible.
I don't need video, network, audio, ete, etc.
I basically need the pi to act as an embedded system. Boot time right now is closer to 40s... anything close to 10 would be great.
A basic list of services that I don't need or any other little tricks would be greatly appreciated or even just pointers on where to start.
I'm currently running the latest version of Raspbian Stretch Lite but I willing to install any os.
Thanks!
Re: Fast boot on Pi-Zero with C library and GPIO access
Posted: Wed May 22, 2019 10:54 pm
by hippy
You haven't completely explained what you do need to support, exactly what needing "the C libraries " amounts to. You could look at BuildRoot and similar, bare metal, Ultibo, or even coding for the VC4 and running in the GPU.
Posted: Thu May 23, 2019 3:29 am
by TimG
It's been a while since I worked on fast-booting, but on a Pi Zero it's possible to start running code within 2 - 2.5 seconds.
I used a systemd service file to launch my script as early as possible, like this:
# example.service
# run as early as possible
[Unit]
Description=Example Service
DefaultDependencies=no
[Service]
ExecStart=/usr/local/bin/example
[Install]
#WantedBy=basic.target
WantedBy=sysinit.target
I disabled all non-essential services:
systemctl set-default basic.target
systemctl disable console-setup kbd keyboard-setup networking
systemctl mask plymouth-read-write plymouth-start systemd-fsck-root
systemctl enable example
...and I think that's about it. No kernel recompilation. According to my notes the kernel took 1.3-1.5s to start, and my service was run 0.8-0.9s later. The complete boot took 5.6-6.2s, depending on what was attached to the USB port.
For testing I switched the on-board LED on at power-on with config.txt:
boot_delay 0
enable_uart=0
dtparam=act_led_trigger=default-on
dtparam=act_led_activelow=on
and off again to indicate when my script was running:
#!/bin/sh
#/usr/local/bin/example
# just an example service to do something
echo 0 >/sys/class/leds/led0/brightness # LED-off = service started
Note that undoing these changes is awkward, since you've disabled networking and keyboard. I wrote a second service script to restore normal operation:
# restore.service
# run when boot is complete
[Unit]
Description=Restore normal boot
After=default.target
[Service]
ExecStart=/usr/local/bin/restore
[Install]
WantedBy=default.target
#!/bin/sh
#/usr/local/bin/restore
# --- log boot performance
systemctl list-dependencies
systemd-analyze critical-chain --fuzz 30
systemd-analyze blame
systemd-analyze critical-chain example.service
systemd-analyze
} >/boot/bootlog.txt
systemd-analyze plot >/boot/bootlog.svg
systemctl set-default multi-user.target
systemctl enable console-setup kbd keyboard-setup networking
systemctl unmask plymouth-read-write plymouth-start systemd-fsck-root
systemctl disable restore
