ImTheOrly
How to disable Alt-F4 on Rasperry
Tue May 21, 2019 5:07 am
Hi, I want to make a Web kiosk with my raspberry pi. I achieved that by modifying the autostart file (I added the chromium --kiosk command in it), and it works, but someone can simply press alt+F4 to get rid of the kiosk. My goal is to disable the alt-f4 shortcut so that people can't close the kiosk, but I've no clue on how to do that
I'm desperate, by the way, looking for hours into Google and nothing works.
PS: There's no openbox directory in the .config folder
topguy
Re: How to disable Alt-F4 on Rasperry
Tue May 21, 2019 11:31 am
Do you need to run openbox ? The app should be able to run borderless without any window manager.
klricks
Tue May 21, 2019 12:42 pm
I'mdesperate, by the way, looking for hours into Google and nothing works.
I don't know the answer but there are several other shortcuts as well:
[Ctrl] [Alt] t
[Ctrl] [Alt] [F2]
[Alt] [Tab]
[Super Key] (Windows logo key)
Probably some others...........
Unless specified otherwise my response is based on the latest and fully updated Raspbian Stretch w/ Desktop OS.
ImTheOrly
Fri May 24, 2019 5:28 pm
[Ctrl] [Alt] t
[Ctrl] [Alt] [F2]
[Alt] [Tab]
Well, I forgot to put the last sentence in my post. I probably deleted it accidentally.
My problem is pn how to disable the alt-f4 shortcut
Andyroo
Fri May 24, 2019 6:59 pm
The shortcut has nothing to do with Chromium (its window manager / OS somewhere but I have not got that far into the system yet) so I think you are going to have to tackle it this way (no Pi handy with a GUI at the mo):
Try using
xmodmap -pke
and see if you can find the code for left and right ALT keys, then use a couple of lines like
xmodmap -e "keycode xx = "
where xx is the data from above before starting Chromium in a script.
This then stops ALT-F4 from working by disabling the ALT keys
The other way (as seen in certain public buildings that shall remain nameless) is to use a keyboard where the ALT keys have been filled underneath with hot snot glue :lol:
klricks
Sat May 25, 2019 2:41 am
Try using
xmodmap -pke
These commands work for most Desktop applications such as Filemanager, LXterminal etc....
xmodmap -e "keycode 64 = "  # Disable Left Alt
xmodmap -e "keycode 108 = " # Disable Right Alt
xmodmap -e "keycode 133 = " # Disable Left "Super" Key
But [Alt] [F4] still persists in Chromium.... So [Alt] [F4] appears to be hardcoded into the Chromium browser software itself. Google turned up others asking the same question with no solutions.
Note that the above commands do prevent the "Super" key menu and prevents [CTRL][Alt] t from opening a terminal window on top of the browser....
Also note that the default keycodes will be restored on reboot.
Return to “Advanced users”
