smarties
[SOLVED] Turning Off Zero ACT LED
Sat May 11, 2019 11:13 am
Below used to work for me in order to turn the ACT LED off on a Zero. Not any longer. I'm at a loss to understand why.
There's a load of statements out there that say this works.
echo 255 | sudo tee /sys/class/leds/led0/brightness
If I cat the file afterwards I still see a 0.
The LED turns off for a fraction of second and then back on again. It's like the kernel overrides what I've done.
It's not working on a Zero with Jessie. Also not working on a Zero with Stretch.
Any thoughts? I'm at a loss.
(please, no suggestions about using tape ;) )
Thanks.
Andyroo
Re: Turning Off Zero ACT LED
Sat May 11, 2019 2:01 pm
I would NEVER suggest tape to cover an led - it may short it or burn up! Use a Sharpie when the power is off :lol:
Sorry - try:
echo none | sudo tee /sys/class/leds/led0/trigger
echo 1 | sudo tee /sys/class/leds/led0/brightness
You have to force the system to have no triggers on the LED first, then turn it off but the main issue with the above is that it only lasts till you reboot, so you can either script it and run via Cron or Systemd at restart or add:
dtparam=act_led_trigger=none
dtparam=act_led_activelow=on
into config.txt
edit: Above is on a Pi Zero W connected via USB running the April 2019 version of Stretch and untested in any other config.
smarties
Sat May 11, 2019 2:20 pm
Thanks Andyroo.
I wasn't dealing with the trigger then! Do'h! :roll: :roll: :oops: :oops:
Appreciated. All good now.
I assume if the trigger is left active, on the next trigger the brightness is reset.
I have a systemd service - see below.
Need to do something with the USB WiFi dongle so went for a systemd rather than config.txt.
Assumption being I have no control of the USB WiFi from config.txt.
I also get to turn the LEDs back on if needed.
Thanks again. Appreciated.
leds-off.service
[Unit]
Description=Turn Pi & WiFi LEDs Off
After=network.target
[Service]
Type=oneshot
ExecStart=/bin/bash -c "echo none | tee /sys/class/leds/led0/trigger && \
                        echo 255 | tee /sys/class/leds/led0/brightness && \
                        echo 0 | tee /sys/class/leds/rt2800usb-phy0::assoc/brightness"
RemainAfterExit=True
ExecStop=/bin/bash -c "echo mmc0 | tee /sys/class/leds/led0/trigger && \
                       echo 255 | tee /sys/class/leds/rt2800usb-phy0::assoc/brightness"
[Install]
WantedBy=multi-user.target
Return to “Advanced users”
