digitalwiz
kernel option in config.txt doesn't work
Wed May 08, 2019 6:09 pm
I built a new kernel for my R Pi 3 and copied it over to the boot partition of the SD card as zImage and edited config.txt to change #kernel="" to kernel="zImage". Reboot and it's still the original kernel7.img.
BespokeTech
Re: kernel option in config.txt doesn't work
Thu May 09, 2019 11:09 am
Have you tried following the official guide? Works fine for me.
https://www.raspberrypi.org/documentati ... uilding.md
stuartiannaylor
Thu May 09, 2019 11:44 am
Dont you have to update the initramfs also?
sudo mkinitramfs -o /boot/initramfs.gz 4.14.98-v7+
That might be me using arch too much of late
6by9
Thu May 09, 2019 12:31 pm
Have you got the quotes in there? You shouldn't have.
kernel=zImage
digitalwiz
Tue May 14, 2019 8:55 pm
OK, removing the quotes did the trick. I must say though that I find it somewhat misleading to have the quotes in the default config.txt if they really shouldn't be there.
Return to “Advanced users”
