jinja.fog
How to prefer wlan0 for Internet over eht0 without losing SSH
Wed Apr 24, 2019 8:39 am
Hi
I connect to the RPi via SSH from local network. Local network does not have Internet access.
Wi-Fi has Internet access and I would like to prefer wlan0 for Internet over eth0.
I tried adding the default route via wlan0 but I lost SSH connection to the RPi and could not connect again until reboot.
Also tried changing the metric of wlan0 to a lower value than eth0, same issue lost SSH cannot connect again.
Below is the default routing table.
[email protected]:~ $ route
Kernel IP routing table
Destination     Gateway         Genmask         Flags Metric Ref    Use Iface
default         10.31.7.62      0.0.0.0         UG    202    0        0 eth0
default         10.128.128.128  0.0.0.0         UG    303    0        0 wlan0
10.0.0.0        0.0.0.0         255.0.0.0       U     303    0        0 wlan0
10.31.7.56      0.0.0.0         255.255.255.248 U     202    0        0 eth0
Thanks for any help in advance.
epoch1970
Re: How to prefer wlan0 for Internet over eht0 without losing SSH
Wed Apr 24, 2019 9:48 am
Your networks overlap: 10.0.0.0/8 includes 10.31.7.56/29
This does not simplify route selection...
Run "ip route get <address>" to test what the routing layer thinks is the best route to a destination.
95bagus
Tue May 21, 2019 4:34 pm
did u try to delete the eth0 default route ?
just try with type "route del default"
the first default rout will remove and routing can goes trought via WLAN
BUT
if u reboot the device ,previosly route will come back again ,if u know how to save the routing list please inform me
Return to “Advanced users”
