Schorschi
To much of a good thing? Using a AMS1117-3.3 regulator?
Tue Apr 02, 2019 1:40 am
To much of a good thing? Using a AMS1117-3.3 regulator? I have a DC fan that is rated for 12v, but I am only feeding the fan 5v from a separate power supply. I have been monitoring the voltage from the tachometer pin, and it varies from about 1.7 volts to zero. It never seems to go above 1.7 volts as long as I only use a 5v source. The current load does not seem to be relevant at all, it never is above .02ma. When I add a AMS1117-3.3v regulator the voltage drops so low the GPIO input does not register. But now I am questioning if I need the AMS1117 at all? Given I am never feeding more than 5v to the fan, and logic pin/line is never above 1.7 volts? the logic bin drive by a hall sensor or pulse induction, I just don't see ever being an issue, or am i missing something here? I have a bi-directional logic leveler ordered, but that now seems like over kill as well. I figure someone will suggest an opto-coupler, but that seems like over kill as well?
klricks
Re: To much of a good thing? Using a AMS1117-3.3 regulator?
Tue Apr 02, 2019 2:32 am
You can't measure the voltage of square wave or other waveform with a standard volt meter. The reading will be average and show much lower than it really is. Measure with a scope.
The 0.02ma figure you wrote makes no sense.
NGC6543
Tue Apr 02, 2019 3:18 am
I'm not sure exactly what you are doing but...
The tachometer output on fans is usually an open collector or open drain, but might have an internal pull-up to the fan supply voltage. The transistor pulls the tach output to ground to give 1, 2 or 4 pulses per revolution (depends on the fan). The output is not a variable voltage but is a train of pulses that your meter is reading an 'average' of in some non-useful way.
It sounds like your fan has the internal pull-up if you are reading a voltage between the tach wire (with it not connected to anything else) and ground.
What do you want to do with the tach output? You don't have to do anything with it (just leave it unconnected). If you are thinking of trying to read the speed by connecting the tach to the Pi, then, if it does have the internal pull-up, you'll need to convert the level to 3.3V. You could do that with a potential divider (two resistors) to drop the fan voltage down, or with a diode and pull up. The diode cathode connects to tach, anode to a 1k resistor to 3.3V and the anode/resistor junction to the GPIO.
If it didn't have the pull up (so is a pure open collector output like the one I was using earlier today) then it's easy to connect to the Pi with just an external pull-up or even the Pi's internal one on the GPIO pin.
ETA: Some fans' tachometers already have a potential divider inside, but will be set probably for 5V or 3.3V assuming they are 12V fans. To know which, you'll need to find the datasheet for the fan, or measure the tach signal with an oscilloscope (not a voltmeter).
Return to “Advanced users”
