Voltage reduction under thermal throttling
Posted: Fri Mar 29, 2019 5:33 pm
by guillaumekh
The Frequency management and thermal control chapter in documentation mentions the following (emphasis mine) :
As the device approaches the limit, various frequencies and sometimes voltages used on the chip (ARM, GPU) are reduced.
For Raspberry Pi 3 Model B+, [...] when the soft limit is reached, the clock speed is reduced from 1.4GHz to 1.2GHz, and the operating voltage is reduced slightly.
What's the range of that voltage reduction ? How low can it go ?
Re: Voltage reduction under thermal throttling
Posted: Fri Mar 29, 2019 7:40 pm
by jahboater
I am seeing 0.1V drop roughly when the CPU freq drops from 1.4GHz to 1.2GHz.
This is the log when running the pathological stress test cpuburn53. Unfortunately the thermal management of the Pi3B+ is so good that it barely gets to throttle with the limit set to 70.
Note the 1.2V reading is at idle.
temp_soft_limit=70
Time      Temp    CPU          Health         Vcore
19:27:10 36.5'C  600MHz 00000000000000000000 1.2V
19:27:20 39.2'C 1400MHz 00000000000000000000 1.3312V
19:27:31 42.9'C 1400MHz 00000000000000000000 1.3312V
19:27:41 44.0'C 1400MHz 00000000000000000000 1.3312V
19:27:51 45.6'C 1400MHz 00000000000000000000 1.3312V
19:28:02 47.2'C 1400MHz 00000000000000000000 1.3312V
19:28:12 48.3'C 1400MHz 00000000000000000000 1.3312V
19:28:22 49.9'C 1400MHz 00000000000000000000 1.3312V
19:28:33 51.5'C 1400MHz 00000000000000000000 1.3312V
19:28:43 52.6'C 1400MHz 00000000000000000000 1.3312V
19:28:53 53.7'C 1400MHz 00000000000000000000 1.3312V
19:29:04 54.8'C 1400MHz 00000000000000000000 1.3312V
19:29:14 55.8'C 1400MHz 00000000000000000000 1.3312V
19:29:24 56.9'C 1400MHz 00000000000000000000 1.3312V
19:29:35 58.0'C 1400MHz 00000000000000000000 1.3312V
19:29:45 58.5'C 1400MHz 00000000000000000000 1.3312V
19:29:55 59.1'C 1400MHz 00000000000000000000 1.3312V
19:30:06 60.1'C 1400MHz 00000000000000000000 1.3312V
19:30:16 60.1'C 1400MHz 00000000000000000000 1.3312V
19:30:26 61.2'C 1400MHz 00000000000000000000 1.3312V
19:30:36 62.3'C 1400MHz 00000000000000000000 1.3312V
19:30:47 62.8'C 1400MHz 00000000000000000000 1.3312V
19:30:57 63.4'C 1400MHz 00000000000000000000 1.3312V
19:31:07 64.5'C 1400MHz 00000000000000000000 1.3312V
19:31:18 64.5'C 1400MHz 00000000000000000000 1.3312V
19:31:28 65.5'C 1400MHz 00000000000000000000 1.3312V
19:31:38 65.5'C 1400MHz 00000000000000000000 1.3312V
19:31:49 66.1'C 1400MHz 00000000000000000000 1.3312V
19:31:59 66.6'C 1400MHz 00000000000000000000 1.3312V
19:32:09 67.1'C 1400MHz 00000000000000000000 1.3312V
19:32:20 66.6'C 1400MHz 00000000000000000000 1.3312V
19:32:30 68.2'C 1400MHz 00000000000000000000 1.3312V
19:32:40 68.8'C 1400MHz 00000000000000000000 1.3312V
19:32:51 69.3'C 1400MHz 00000000000000000000 1.3312V
19:33:01 69.3'C 1400MHz 00000000000000000000 1.3312V
19:33:11 69.8'C 1400MHz 10000000000000000000 1.3312V
19:33:21 69.8'C 1400MHz 10000000000000000000 1.2313V
19:33:32 69.8'C 1200MHz 10000000000000000000 1.3312V
19:33:42 70.4'C 1400MHz 10000000000000000000 1.3312V
19:33:52 69.8'C 1400MHz 10000000000000001000 1.3312V
19:34:03 69.8'C 1200MHz 10000000000000000000 1.3312V
19:34:13 69.8'C 1200MHz 10000000000000001000 1.2313V
19:34:23 69.8'C 1200MHz 10000000000000000000 1.2313V
19:34:33 70.4'C 1400MHz 10000000000000001000 1.3312V
19:34:44 69.8'C 1200MHz 10000000000000001000 1.3312V
19:34:54 69.8'C 1200MHz 10000000000000000000 1.3312V
19:35:04 70.4'C 1200MHz 10000000000000001000 1.3312V
19:35:15 70.4'C 1400MHz 10000000000000001000 1.3312V
19:35:25 69.8'C 1400MHz 10000000000000001000 1.3312V
19:35:35 70.4'C 1400MHz 10000000000000001000 1.2313V
19:35:46 70.9'C 1200MHz 10000000000000000000 1.2313V
19:35:56 70.4'C 1400MHz 10000000000000000000 1.3312V
19:36:06 69.8'C 1400MHz 10000000000000001000 1.2313V
19:36:17 70.9'C 1400MHz 10000000000000001000 1.3312V
19:36:27 70.4'C 1200MHz 10000000000000001000 1.2313V
19:36:37 69.8'C 1400MHz 10000000000000001000 1.2313V
19:36:47 69.8'C 1400MHz 10000000000000001000 1.3312V
19:36:58 70.4'C 1200MHz 10000000000000000000 1.2313V
19:37:08 70.4'C 1200MHz 10000000000000000000 1.2313V
19:37:18 69.8'C 1400MHz 10000000000000001000 1.2313V
Posted: Fri Mar 29, 2019 7:44 pm
by guillaumekh
Nice thanks @jahboater
Posted: Fri Mar 29, 2019 7:51 pm
by jahboater
Here is another run with the temp soft limit set to the default 60C.
Again its not showing any signs of it throttling further. I suspect with poor cooling (in a small case and/or in a hot country) it will throttle further and the voltage will go down further - but I cant achieve that here.
19:41:11 50.5'C  600MHz 10000000000000000000 1.2V
19:41:21 53.7'C 1400MHz 10000000000000000000 1.3250V
19:41:32 55.8'C 1400MHz 10000000000000000000 1.3250V
19:41:42 57.5'C 1400MHz 10000000000000000000 1.3250V
19:41:52 58.5'C 1400MHz 10000000000000000000 1.3250V
19:42:03 60.1'C 1400MHz 10000000000000000000 1.2313V
19:42:13 60.1'C 1200MHz 10000000000000000000 1.3250V
19:42:23 60.1'C 1200MHz 10000000000000001000 1.3250V
19:42:34 60.1'C 1200MHz 10000000000000001000 1.2313V
19:42:44 60.7'C 1200MHz 10000000000000001000 1.2313V
19:42:54 60.1'C 1200MHz 10000000000000001000 1.2313V
19:43:05 60.7'C 1200MHz 10000000000000001000 1.2313V
19:43:15 61.2'C 1200MHz 10000000000000001000 1.2313V
19:43:25 61.8'C 1200MHz 10000000000000001000 1.2313V
19:43:35 61.2'C 1200MHz 10000000000000001000 1.2313V
19:43:46 61.8'C 1200MHz 10000000000000001000 1.2313V
19:43:56 62.3'C 1200MHz 10000000000000001000 1.2313V
19:44:06 62.3'C 1200MHz 10000000000000001000 1.2313V
19:44:17 62.3'C 1200MHz 10000000000000001000 1.2313V
19:44:27 62.3'C 1200MHz 10000000000000001000 1.2313V
19:44:37 62.3'C 1200MHz 10000000000000001000 1.2313V
19:44:48 63.4'C 1200MHz 10000000000000001000 1.2313V
19:44:58 62.8'C 1200MHz 10000000000000001000 1.2313V
19:45:08 62.8'C 1200MHz 10000000000000001000 1.2313V
19:45:18 63.4'C 1200MHz 10000000000000001000 1.2313V
19:45:29 63.4'C 1200MHz 10000000000000001000 1.2313V
19:45:39 63.4'C 1200MHz 10000000000000001000 1.2313V
19:45:50 63.4'C 1200MHz 10000000000000001000 1.2313V
19:46:00 62.8'C 1200MHz 10000000000000001000 1.2313V
19:46:10 63.4'C 1200MHz 10000000000000001000 1.2313V
19:46:20 63.9'C 1200MHz 10000000000000001000 1.2313V
19:46:31 63.9'C 1200MHz 10000000000000001000 1.2313V
19:46:41 63.4'C 1200MHz 10000000000000001000 1.2313V
19:46:51 64.5'C 1200MHz 10000000000000001000 1.2313V
19:47:02 63.4'C 1200MHz 10000000000000001000 1.2313V
19:47:12 63.9'C 1200MHz 10000000000000001000 1.2313V
19:47:22 63.4'C 1200MHz 10000000000000001000 1.2313V
19:47:32 63.9'C 1200MHz 10000000000000001000 1.2313V
19:47:43 64.5'C 1200MHz 10000000000000001000 1.2313V
19:47:53 63.9'C 1200MHz 10000000000000001000 1.2313V
19:48:03 64.5'C 1200MHz 10000000000000001000 1.2313V
19:48:14 64.5'C 1200MHz 10000000000000001000 1.2313V
19:48:24 63.9'C 1200MHz 10000000000000001000 1.2313V
19:48:34 65.0'C 1200MHz 10000000000000001000 1.2313V
19:48:45 65.0'C 1200MHz 10000000000000001000 1.2313V
Posted: Tue Apr 02, 2019 6:09 pm
by Paul Hutch
I ran some some stress tests with a RasPi 3B+ with no heatsink and a sealed case, in an oven at 65°C ambient earlier this year to see how hot I could make it. I ran out of time and wasn't able to push it as far as I wanted but I did get it to throttle down to 600 MHz and the lowest I saw for a core voltage was 1.200V.
Posted: Tue Apr 02, 2019 6:53 pm
by jdb
There are three voltage/frequency setpoints for the 3B+
1.2V @ 600MHz - when idle or throttled due to 5V undervoltage or due to exceeding the 85C temp limit
"turbo" volts @ 1200MHz - when the temperature is above the soft temp limit and below the 85C temp limit. ARM frequency gets progressively ramped down to 600MHz between 80 and 85C.
"tubo+" volts @ 1400MHz - when the temperature is below the soft temp limit
The turbo/turbo+ volts are adjusted based on silicon characteristics, so tuned automatically on each individual board.
Posted: Wed Apr 03, 2019 1:13 pm
by jahboater
Says a lot for the thermal management of the 3B+ that you need all that to get it to throttle!
Posted: Wed Apr 03, 2019 2:51 pm
by Paul Hutch
<snipped excellent information>
Thank you for the info, one of the best things about this forum is how many RasPi engineers come to help us all out, keep up the good work. A big thanks to all of you, the rest of the RasPi staff, volunteer moderators, and regular contributors for making this place such a great resource.
