wfsaxton
Automated provisioning of Raspbian Questions
Thu Mar 21, 2019 4:59 pm
I'm trying to find out a way I can quickly and repeatedly provision Raspbian with CLI or ansible, particularly when it comes to enabling VNC server and SSH access.
I'm struggling, because it appears all "CLI" answers to these kinds of questions are to use 'sudo raspi-config' which is NOT a real CLI solution.
Any idea how I can do this with a REAL CLI command? Or perhaps I can create/edit a config file somewhere?
epoch1970
Re: Automated provisioning of Raspbian Questions
Thu Mar 21, 2019 5:06 pm
raspi-config is a script, you could read what it does if you're interested...
B.Goode
The shell (command-line) utility raspi-config is simply a shell script stored at /usr/bin/raspi-config
So it is 'easy' to inspect it to determine what underlying actions it takes on your behalf.
Andyroo
Thu Mar 21, 2019 5:08 pm
SSH can be 'turned on' pre-boot https://www.raspberrypi.org/documentati ... ccess/ssh/ Note this only activates password security for the user Pi - any further and you need to script it AFTER the machine is up!
VNC install details are https://www.raspberrypi.org/documentati ... /README.md
I just though VNC worked (not headless) out of the box if you did not need to get to the Pi over the internet (VNC Cloud) BUT I could well be wrong here as its been a few months since I needed VNC from scratch and normally link to my account out of habit.
There are numerous posts here asking for more scripting abilities for images - one day maybe...
B.Goode
Thu Mar 21, 2019 5:44 pm
Also, to add that raspi-config has a largely undocumented non-interactive mode, perhaps to provide an API for the full-gui desktop version of the configuration tool.
Clearly it isn't official documentation, but this 3rd party web page gives an idea of what is possible: http://www.knight-of-pi.org/raspi-confi ... -commands/
Andyroo
Thu Mar 21, 2019 8:57 pm
Only concern I have with this is when the config tool changes this may not work or the wrong option ends up being taken :cry: I think I would rather work out what the code does from it’s source as I can document my needs and handle any changes.
B.Goode
Thu Mar 21, 2019 9:13 pm
Well, that's why my provision of factual information was heavily qualified with Health Warnings like largely undocumented and Clearly it isn't official documentation
But while you are working out what the raspi-config code does from its source you could also look at how the nonint command line argument is processed... it is all there in plain sight for all to see.
mina
Wed Mar 27, 2019 2:21 pm
I provision my RPi (for MoodleBox https://moodlebox.net/) with Ansible. See the project repo here: https://github.com/moodlebox/moodlebox
HTH
Nicolas – Maintainer of MoodleBox, a Moodle server on Raspberry Pi
salsaman
Thu Jun 13, 2019 6:41 pm
Looking at a script's source code is not the way to fine a command's command-line interface. That is not "in plain sight for all to see."
It should report what to do with "man raspi-config" or "raspi-config -" or "raspi-config --help" or something, but there's no man page or help message.
It is disconcerting that raspi-config has a "nonint" option but no documentation whatsoever on how to use it.
Surely somebody has documented this somewhere. I found this thread looking for such documentation, and I will keep looking.
B.Goode
Thu Jun 13, 2019 8:22 pm
Maybe you should express your strong concerns on the Issues page for the code repository here: https://github.com/RPi-Distro/raspi-config/issues
They are more likely to come to the attention of a relevant developer there.
Return to “Advanced users”
