merk
where/how to create config.txt openelec/berry boot usb stick
Tue Nov 20, 2012 4:27 pm
Title is a bit a mouthful, I know.
I danced between open elec/raspbmc and ended up reverting back to raspbmc since I wasn't planning on streaming files between computers, I'd rather just be able to stick a flash drive with content and have immediate access to it.
Anyway, so I used berry boot to install openelec to a usb thumb drive. Everything is great, menus are fast and I can access files I want from sticks fine. The only problem I encountered is the regular method :
mount /flash -o remount,rw...etc
Doesn't appear to be working, I'm assuming the issue is because I installed to a flash stick for memory speed. Is there a working routine for creating a config.txt if you installed the os to a usb stick? I'd like to be able to add codecs/overclock.
merk
Re: where/how to create config.txt openelec/berry boot usb s
Tue Nov 20, 2012 10:46 pm
Spent a few hours like a monkey and eventually discovered what I think was the config file raw on the sd card rather than the usb. I tossed in the settings for turbo (I have heatsinks and it keeps temps 20c below bursting into flames) I tested it for a bit by just leaving it as is. Saw that it was cycling after a bit (booting off/on) so I guess I found the right config :? .
Reduced the overclock a bit and it appears to be stable.
boomhaueruk
Re: where/how to create config.txt openelec/berry boot usb stick
Sat Jun 16, 2018 10:15 am
I've got exactly the same problem - but I can't find the config.txt!
Can you tell me where you found it?
edmund$ ssh [email protected]
[email protected]'s password:
# OpenELEC #
# http://openelec.tv #
OpenELEC (official) Version: 8.0.4
HornsbyPi:~ # ls
music pictures screenshots tvshows videos
HornsbyPi:~ # mount /flash -o remount,rw
mount: can't find /flash in /proc/mounts
HornsbyPi:~ # mount
proc on /proc type proc (rw,relatime)
sysfs on /sys type sysfs (rw,relatime)
dev on /dev type devtmpfs (rw,relatime,size=420532k,nr_inodes=105133,mode=755)
none on / type aufs (rw,relatime,si=69e515cc)
tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev)
devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000)
tmpfs on /run type tmpfs (rw,nosuid,nodev,mode=755)
tmpfs on /sys/fs/cgroup type tmpfs (ro,nosuid,nodev,noexec,mode=755)
cgroup on /sys/fs/cgroup/unified type cgroup2 (rw,nosuid,nodev,noexec,relatime)
cgroup on /sys/fs/cgroup/systemd type cgroup (rw,nosuid,nodev,noexec,relatime,xattr,name=systemd)
cgroup on /sys/fs/cgroup/blkio type cgroup (rw,nosuid,nodev,noexec,relatime,blkio)
cgroup on /sys/fs/cgroup/cpuset type cgroup (rw,nosuid,nodev,noexec,relatime,cpuset)
cgroup on /sys/fs/cgroup/net_cls type cgroup (rw,nosuid,nodev,noexec,relatime,net_cls)
cgroup on /sys/fs/cgroup/cpu,cpuacct type cgroup (rw,nosuid,nodev,noexec,relatime,cpu,cpuacct)
cgroup on /sys/fs/cgroup/freezer type cgroup (rw,nosuid,nodev,noexec,relatime,freezer)
cgroup on /sys/fs/cgroup/devices type cgroup (rw,nosuid,nodev,noexec,relatime,devices)
mqueue on /dev/mqueue type mqueue (rw,relatime)
tmpfs on /var type tmpfs (rw,relatime)
configfs on /sys/kernel/config type configfs (rw,relatime)
debugfs on /sys/kernel/debug type debugfs (rw,relatime)
tmpfs on /tmp type tmpfs (rw,nosuid,nodev)
fusectl on /sys/fs/fuse/connections type fusectl (rw,relatime)
/dev/mmcblk0p2 on /var/media/berryboot type ext4 (rw,nosuid,nodev,noexec,noatime,data=ordered)
HornsbyPi:~ # ls
HornsbyPi:~ # cd ..
HornsbyPi:/ # ls
bin etc lib opt run storage tmp var
dev flash media proc sbin sys usr
HornsbyPi:/ # cd flash
HornsbyPi:/flash # ls
HornsbyPi:/flash #
Return to “Advanced users”
