tutorial on my Raspberry Pi 3 but after successfully completing all the preparatory steps, the test fails to classify the 'go-kart' image.
On my Pi, I have Ubuntu 16.04.5 LTS installed (not Mate). Details below:
user@pi:[23:21]:~$ cat /proc/cpuinfo
Hardware : BCM2709
Revision : a22082
user@pi:[23:21]:~$ lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 16.04.5 LTS
Release: 16.04
Codename: xenial
I compiled the ComputeLibrary with 'opencl=1' but removed '-j2' as it was misinterpreted as a make target, using:
scons Werror=1 debug=0 asserts=0 neon=1 opencl=1 examples=1 build=native
Running the 'go-kart' test produced the following result, which is incorrect as it didn't classify the image:
user@pi:[22:17]:~/Programming/CNN/ComputeLibrary$ ./build/examples/graph_alexnet 0 $PATH_ASSETS $PATH_ASSETS/go_kart.ppm $PATH_ASSETS/labels.txt
Threads : 1
Target : NEON
Data type : F32
Data layout : NHWC
Tuner enabled? : false
Tuner file :
Fast math enabled? : false
Can't load libOpenCL.so: libOpenCL.so: cannot open shared object file: No such file or directory
Can't load libGLES_mali.so: libGLES_mali.so: cannot open shared object file: No such file or directory
Can't load libmali.so: libmali.so: cannot open shared object file: No such file or directory
Couldn't find any OpenCL library.
Test passed
From the error I realised that I didn't have OpenCL installed and possibly OpenGLES either, so I installed the following
sudo apt-get install ocl-icd-opencl-dev ocl-icd-dev
sudo apt-get install cmake libx11-dev xorg-dev libglu1-mesa-dev freeglut3-dev libglew1.5 libglew1.5-dev libglu1-mesa libglu1-mesa-dev libgl1-mesa-glx libgl1-mesa-dev
I now have /usr/lib/arm-linux-gnueabihf/libOpenCL.so but I don't have the other two. However, I do have /usr/lib/libGLESv2.so.
In the mean time, I'm rebuilding with 'opencl=0' to see if it works without the GPU boost, but I really want to utilise the VideoCore IV.
Update : Running the test after rebuilding produced:
user@pi:[ 1:45]:~/Programming/CNN/ComputeLibrary$ ./build/examples/graph_alexnet 0 $PATH_ASSETS $PATH_ASSETS/go_kart.ppm $PATH_ASSETS/labels.txt
Threads : 1
Target : NEON
Data type : F32
Data layout : NHWC
Tuner file :
Killed
What does "Killed" mean here?
How/where can I get libGLES_mali.so and libmali.so? I've seen some advice suggesting symlinking things but my situation doesn't seem to fit what I've seen. Also, do I need to build VC4CL still?
Any help would be much appreciated.
Cheers,
Nap
