hiiiiiiiiiiiiii
Need Help with hc-06 and android
Thu Jan 24, 2019 7:54 am
For a project, i am trying to connect the raspberry pi with an android device so i can lock/unlock a door using a servo. The servo side of thing is what i can do with python but i need to be able to get the on/off signal (maybe a 0 or 1) from the android phone first. So, i got an hc-06 and now need help for the android app. I do not know how to use Android Studio or anything similar and need help.
topguy
Re: Need Help with hc-06 and android
Thu Jan 24, 2019 12:08 pm
Which model Pi are you using ? Why not use one with inbuilt BT and Wifi ?
Do you really need an app ?
Why not just make it a web-page: https://projects.raspberrypi.org/en/pro ... with-flask
hiiiiiiiiiiiiii
Thu Jan 24, 2019 12:27 pm
I am using Rpi 2B and the website is a great suggestion but i am trying to do it with bluetooth. Thank you for your advice and i also need the hc-06 as i am linking an arduino as well
MarkTF
Thu Jan 24, 2019 5:01 pm
I'd suggest taking a look at MIT AppInventor (http://ai2.appinventor.mit.edu/) which is a simplified web-based Android App Development environment. If you have some programming experience you should be able to work through the tutorials in a few hours.
There are any number of tutorials on the web for developing the Android side of bluetooth to HC-05/06 devices. e.g. https://roboindia.com/tutorials/sending ... p-inventor
hiiiiiiiiiiiiii
Fri Jan 25, 2019 5:58 am
Thank you....a project saver
Return to “Advanced users”
