sayhello
interfacing with matlab & simulink - is it free
Tue Jan 15, 2019 3:36 pm
hello - dont bother for this question.
i need matlab for a certain project.
is it free !? Found some information that it will cost money...
but here a introduction on using matlab with Raspi / or Adruino does not say anything bout fees:
MATLAB Support Package for Arduino hardware enables you to use MATLAB® to
communicate with the Arduino® board over a USB cable. This package is based on a
server program running on the board, which listens to commands arriving via serial port,
executes the commands, and, if needed, returns a result.
This support package is available for R2014a and later releases. It’s available on 32-bit
and 64-bit Microsoft® Windows®, 64-bit Mac OS, and 64-bit Linux®.
I will explain how to set up Matlab for Arduino development on chapter 2
http://www.labcontrol.xyz/dokuwiki/lib/ ... niawan.pdf
do you know anything bout the fees!?
scotty101
Re: interfacing with matlab & simulink - is it free
Tue Jan 15, 2019 3:37 pm
Matlab is most definitely NOT free.
The hardware support packages are free but require you to have a current and active MATLAB license for any of the products required by the hardware support package.
Joel_Mckay
Wed Jan 16, 2019 5:49 am
The open Octave is fairly similar to Matlab, and Julia is the super-computing option.
https://julialang.org/learning/
There are no shortcuts in learning how to write software, but python is a good place to start.
neilgl
Wed Jan 16, 2019 12:25 pm
Having looked at that link, it seems the only part needing Matlab is chapter 8 where he draws a graph in Matlab. All the other sections can easily be done using the standard Arduino IDE (free) on a PC or on the raspberry pi. The graph plotting part could be done in many other ways on the pi without Matlab.
sayhello
Wed Jan 16, 2019 2:57 pm
well i will take octave
https://de.wikipedia.org/wiki/GNU_Octave
it is free - and i guess that i can do all that i need to
Return to “Advanced users”
