RPIzW Stretch 24/7 running
Posted: Thu Dec 27, 2018 10:27 pm
by AndersUk
I'm running a Raspberry Pi Zero W 24/7 as a headless server - no screen, mouse or keyboard access. I'm using the latest cut of Stretch. It connects to the internet via wifi - doesn't need bluetooth.
What services can I drop from systemctl to get this as lean as possible? secondly, what's the best to drop services? systemctl disable? mask? other?
Trying to get a smooth reliable server - that can be rebooted back to an up and running state quickly & reliably.
TIA
Re: RPIzW Stretch 24/7 running
Posted: Fri Dec 28, 2018 12:57 am
by PhatFil
just dont start services your not employing.
whats currently configured to start up?
a little googleing should reveal whats what if you dont recognise the daemons running
fwiw my own headless pi-0-w server runs the full desktop version of stretch not the lite version, and hosts a mqtt broker web server docker and a couple of servers as well as node red.. its not slow restarting imho.. but i rarely use its resources directly beyond the odd terminal session to update and a couple of the hosted web interfaces.
Posted: Mon Dec 31, 2018 5:36 am
by BeauSlim
Assuming that you are actually running "lite" not the desktop version, there really isn't much to turn off. Maybe avahi if that's running.
Add "dtoverlay=pi3-disable-bt" to your /boot/config.txt to make sure bluetooth is disabled. Yes "pi3" on the zero.
Posted: Thu Jan 03, 2019 1:28 pm
by itsmedoofer
You didn't mention what you intended running, however I would echo what BeauSlim said, there is not a lot of fat that I have found in the lite image.
I have a ZeroW running Apache, its crude I know but a reboot took about 50 seconds until SSH was back up…
13:21:31.756 The SSH2 session has terminated with error.
13:22:19.971 Connection established.
HTOP shows me using about 60Mb Ram, with me connected...
I have had a play around with this in the past, could be handy for you
https://dietpi.com/dietpi-software.html
Posted: Mon Jan 21, 2019 5:54 pm
by AndersUk
I’m running a number of continuously running python scripts doing various tasks.
Thank you for the feedback - this is very reassuring.
